Question about LG Art Cool LA121CNP wall/window Air Conditioner
LG Reverse cycle ducted (in ceiling) airconditioning works normally on heating and coooling and then cuts out after 2 days and shows error code 61.This is in 3rd floor apartment. The system can be reset by switching power off at meter box and switching on again but only runs for approx 1 - 2 days and gives the error code 61 again. The motor is in a plant room in the apartment building.
  • 400 Answers
Error code CH61 - CONDENSER PIPE HIGH PRESSURE. This can be due to overcharging of the system or the condenser clogged with dust or an obstruction, or condenser fanmotor not working. Hope this helps.
Posted on Nov 18, 2009
    Master:
  • 439 Answers
Before messing around with refrigerant charge, the condensor must have free airflow across it, you can check this yourself, clean the condensor with a brush, pressurized air, or water hose.
Posted on Apr 23, 2015
Error code 1477 on Miele T8322 Drier. What does this mean?
not sure bout the code. but it seems to indicate that the dryer is shutting down at certain heat levels. Thus u may have issues with ur cycling thermostat or thermal cut off or even ur venting and duct system.
Jan 28, 2015 | Miele Dryers
I have a 2013 Brisk air 1500 ducted A/C. The problem is after several hours of cooling the fan will shut off but the compressor will continue to run (humming) After shutting of unit at thermostat and
sounds like the fan over heat, you may want to check the fan relay and wiring for corrossion and capacitor as it may not be shorted but lower in value and making the fan over heat and triggering its build in safety cut off..
Jan 06, 2015 | Brisk Air Heating & Cooling
F6 error code first time star unit show f6 code
good day I have a problem with my aircon its ECOAIRE aircondition with error F6
Sep 09, 2014 | Electrolux Heating & Cooling
Why won't my dryer heat up sometimes?
It may be a cracked ignitor. check the ignitor and look for any white spots. these can be an indication of a crack which can cause intermittent problems. Replace if necessary. Hope this helps.
Bob
Jul 18, 2014 | Maytag MDG16PD Gas Commercial Dryer
I have a panasonic reverse cycle ducted air conditioner Panasonic model cu 71c 5 2hp. The word "check" is flashing on the display - when I press the check button, error code " F00"...
F00 fault is a short circuit or grounding out in the low voltage (safety) circuitry. Check in your thermostat (Y1). Hope it's helpful?
Jan 05, 2011 | Panasonic Heating & Cooling
5mint cooling 5minuts heating
The reverse valve and silenoied are bad, you need to change them or replace the condencer.
May 04, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Hi we have a ducted reverse cycle air conditioner 6hp we turn it on for heating it shows E1 after awhile we have no book thanks
system error.call a service tech.you cant do anything until thay arrive for a inspection.
Jun 07, 2009 | Heating & Cooling
Error Ch 26
1.check indoor unit wiring.
2 check cirkit board
3 check selector switch
Mar 25, 2008 | LG LSC183VMA Split System Air Conditioner
LG Art Cool LA121CNP wall/window Air Conditioner Logo
833 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
