Question about Xerox XG-71D 17" Flat Panel LCD Monitor
The green power light flashes slowly and there is no signal on the screen, not even the Xerox logo
  • 113 Answers
Is this a crt or lcd monitor, reseat the memory in the pc
Posted on Nov 16, 2009
No picture on startup , continuous flashing green and orange led
Seems that way. Fact that you saw the logo on screen eliminates the inverter board.
Nov 08, 2015 | Sony XBR-52LX900 BRAVIA LX900 Series 52 3D...
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
Xerox Phaser 8200 goes through post then hangs.
Sounds like a RAM problem. Go to the back of the machine, You will see  2 large, thumb Screws, Twist them about half a turn and remove the main board. Remove and reinsert the memory stick. If that does not fix it the main board or the electronics module has probably failed.
Mar 03, 2010 | Xerox Phaser 8200 Laser Printer
The monitor will not turn on. When power button
First--was it working?
Did it suddenly stop?
When you see the LG logo, then it goes away, does the power light turn from green to amber? Sounds like that doesn't happen.
So--if you are getting a signal, you should see something.
If there is no signal, then the power light should change from green to orange.
With no lights at all, I suspect a faulty monitor.
Feb 22, 2010 | Computers & Internet
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Samsung Sync Master 914 has no picture. When power supply is only in, green light flashes slowly. When both power and vga are in, green light flashes more quickly. I hear a faint clicking sound coming...
I would check the caps with ohm meter. Make sure they all show increasing resistance. Caps can be bad without looking bad. Check output voltage on the power board, should be around 12V. If all that checks out then I'd look next at the backlight bulb. I'v repaired many monitors and the problem was almost always overheated caps on the power board. Post back and let me know.
Dec 03, 2009 | Computers & Internet
Xerox XA7
ccfl tube is destroyed or fuse on inverter board
Sep 01, 2008 | Xerox XA7-192i 19" LCD Monitor
No picture for a while, green flashing light
That is a defect with those monitors...you should get the returned to the store...if you can't then you may have to do some soldering dude...it is a power issue with the monitor itself...you will need to find the replacement capacitor inside..but still the best advice is to return the product
Oct 31, 2006 | LG Flatron L1715S 17" LCD Monitor
Xerox XG-71D 17" Flat Panel LCD Monitor Logo
256 people viewed this question
Top Xerox Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
JC Meredith
JC Meredith
Mark Magill
Mark Magill
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
