Question about Estate TEDX640JQ Electric Dryer
The dryer would not start, it was dead, opened and slammed the door shut, it worked fine. 2 days later it went dead again, sounds like the door switch, any ideas?
    Scholar:
  • 86 Answers
Sounds pretty good, actually. Insert screwdriver on either end of bottom/top panel and lift. Find the door switch and bypass it for a quick fix (just remember that dryer will operate when you open the door - not recommended if small children are present in the home). My advice is to replace the switch.
Posted on Nov 17, 2009
Why is battery draining ford 2002 Taurus SES
Remove negative cable from battery, connect a test light to negative terminal, opposite end off light to negative battery post. ( let sit for 3 to 5 minutes). Then start pulling fuses, when the light goes out that's your bad circuit. God-Bless! Its worth a try.
Oct 01, 2015 | 2002 Ford Taurus
When I open the door while the dryer is on, it doesn't shut off.
you have a bad door switch, replace it and it will be fine
Apr 20, 2012 | Amana Dryers
Dryer was running I opened the door took clothes out shut the door but not all the way just till it was in the full up position. Then went back later and put some clothes in and hit the start button and...
i had this same problem it sounds like a thermal fuse its usualy a small device white mabe with 2 wires connected to it on the back of your dryer there might be a cover plate but you shouldn't have to tear into your dryer, you can also check em with an Ohms tester,to see if the thermal fuse is working properly
Jan 03, 2011 | Dryers
Dear Expert, When I went to turn on my Roper dryer it made a humming sound for a few seconds then quit, without out the dryer ever starting. I then had my wife depress the start know while I held the...
check and see if there is any thing in the dryer vent if not.open the door hold the door switch in like the door is shut.have your wife push the start switch in and turn the drum counterclock wise if it starts then the motor has gone bad if it hums still its still the motor.if it does start stop the dryer and try restarting several times sometimes they get a dead spot and it may work for years or may die tomorrow but these are a couple of things to try good luck
Dec 19, 2010 | Dryers
How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
Nov 17, 2009 | Kenmore 63942 Dryer
Dryer won't come on
Was it the dryer door he slammed shut or the house door? If it was the dryer door, then TheMobilian's answer is on the nose. If it was the house door that was slammed and it tripped the circuit breaker to your house, then you have something else entirely going on. Does your dryer have an electronic control panel (totally smooth surface), or does it have the knobs and buttons? What model number do you have?
Jul 08, 2009 | Whirlpool LER4634J Electric Dryer
Car shuts off for no reason when I shift
It sounds like you have a bad Ignition Control Module. When they are cool they work fine, but when they get hot, they **** out.
Feb 06, 2009 | 1990 Honda Accord
Fridge has problems
sounds like the defrost clock may be going bad and or a door switch. Look for a hole that has whatr looks like a big screw that you can turn.
Oct 21, 2008 | Frigidaire FRS26R4A Side by Side...
Estate TEDX640JQ Electric Dryer Logo
217 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
