Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
COULD THIS BE A POWER SUPPLY PROBLEM?
I WOKE UP AND COMPUTER WAS ON BUT THE SCREEN WAS BLANK SO I JUST TURNED OFF THE COMPUTER AT THE TOWER. THIS TOOK MORE THAN ONE TRY, AFTER A FEW MINUTES I TRIED TO TURN IT BACK ON BUT IT WON'T POWER UP. WE HAVE CHECK ALL THE POWER CORDS AND UPLUGGED FROM THE WALL AND REPLUGED BUT ALL WE GET IS A LIGHTLY FLASHING YELLOW LIGHT ON THE POWER BUTTON.
  • tracyeds Dec 13, 2008
    I am having the same problem. Is there a solution?
    Sergeant:
    Champion:
  • 317 Answers
Call Dell and tell them, It sounds like it could be a power supply issue, however it could also be a bad motherboard as well.
Posted on Jan 09, 2008
I have an Asus M4A89TD Pro/USB3 Motherboard that I'm using to build a new PC. After I finished assembling the tower I turned it on and began setting my BIOS. I only set the date and time when my whole...
I would re-seat the power connector from the power supply to the motherboard. If you are able to test the power supply output, that would be helpful as well. The problem as you describe it points towards the power supply failing.
Apr 01, 2017 | ASUS Computers & Internet
PC would not power on? My PC wouldn't power on today, I checked all plugs on surge protector inc the fuses all seemed ok. I took all plugs out turned power off at socket for five minutes and put all plugs...
The tower has a self contained power supply module that is the problem, it must be replaced for a new one, you need to bring the tower to a computer repair store for service, because they have to install the correct power supply for your model.
Jan 25, 2011 | Computers & Internet
Hi. Have just turned on my HP Pavillion m8000 and the screen and it does nothing. The screen is getting no signal and even though the computer is on, it isn't starting up as usual. Help!!! I've checked all...
hi
it could be that your power supply (from tower) is not working -- does the fan blow out air ?
if not replace the power supply. If the power supply is on but no video on screen showing , it could be your mainboard inside the tower, thats if no noise is coming from the tower.
what were the circumstances when you worked on he computer ? was it plugged in overnight while running or was the power cord attached to tower while plugged into wall ? if so, it mnay have experienced a power surge and blew the mainboard.. too much current going to tower could blow the power supply, causing the mainboard to have received excess current
go to this link and rewview some infromation about your PC issue(s)
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=3328509&taskId=110
let me know what lse i can do -- i await your reply to some of the questions above
regards.
Dec 16, 2010 | HP Computers & Internet
No power to tower. Pressing power on button on front of tower fails. Is there some kind of reset or fuse to look for?
There is no easy fuse. Did the computer get turned off at the back? Some power supplies have a switch on the top of the tower. Did the power strip get turned off? Have you verified that the outlet has power?
If this is not the problem, it sounds like a blown power supply. Do you have any lights on the system? If not, take the tower to a local computer shop and they can very quickly diagnose a failed power supply.
Sep 07, 2010 | Dell Dimension 4550 PC Desktop
I turned on the computer and blank monitor screen.
have you checked if monitor cables are properly seated? have you tried a different known good video cable? also try a different outlet for the power supply for the monitor. lastly, try a different monitor and hook it to your tower. if it has a good display, then you should replace monitor, if still it has same issue, thenyou may want to consider changing your videocard.
Apr 03, 2010 | Dell Inspiron 531s Desktop Computer
Power button blinks and then goes blank. the power on the computer was turned off immediately and the computer never powered down properly.
had the same problem, its actually an issue with the motherboard, but just to eliminate that possibility, just get your computer power supply (you will find this inside the tower) checked first by a qualified technician
Sep 25, 2009 | Dell Dimension 8400 PC Desktop
Black screen when i turn on computer.
Do a power drain :- Disconnect every cord from the back of computer tower while the pc is oiff and then press and hold down the power supply button in front of the tower..
have u tried updating the bios any time before?
Secondly,is it possible to go to the safe mode or the screen goes blank even before that?
Jun 27, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Blank Screen
Hi
Pls check with another monitor or another comp to check if it is a problem with the monitor or with the computer.
If it is a problem with the monitor, get the monitor serviced.
If it is problem with the computer, check with the power supply.
If the power supply is working, then reseat the cable that goes from the power button inside to the motherboard. Also try reseating the RAM, CMOS battery and the video card.
If the above steps doesnt work, then the computer needs to be serviced.
Feb 18, 2008 | Computers & Internet
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Sleep mode
I turned my power off from monitor and tower and turned them back on simutaneously with the F8 key. It worked.
Dec 17, 2007 | HP Pavilion F1703 17" LCD Monitor
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
74 people viewed this question
Alun Cox
