Question about KitchenAid Refrigerators
IWater does not dispense.
I have a kitchenaid frig, model #KSRS25FGBT02. The water is not dispensing. I have changed the filter and tried it without the filter and it still only drips, with a little more sometimes. Then water started leaking under the frig and coming out on the floor in the front. I took the grill off and realized the defrost pan was full. I do have a low hum when I push the dispenser lever. Ice dispenser is fine. Thanks
    President:
  • 1,218 Answers
Good day,
The hum is normal. That's the water valve in the rear of the machine being activated.
Lots of plumbing to be checked.
Water line starts at the dispensing outlet in the door, and runs thru the door to the bottom of the hinged side.
From there it goes to the filter,
'From there it travels under the machine into the cooling reservoir mounted back of the fresh food section behind the crispers.
From there it travels back out and runs to the water solenoid mounted on the back rear of the machine.
One of these lines or their fittings has failed.
It's a look-see repair.
Also, there is a remote chance the water line running inside the freezer door froze, causing this problem, and would require the machine be shut down (unplugged) and the door be allowed to defrost completely.
Posted on Nov 16, 2009
Samsung Frig water dispenser makes loud humming sound when dispensing water. This began after changing water filter.
Check to see if you have rotated new filter in the engaged direction.
I have had a few filters that were defective and were not fully charged. If you have the reciept, take old filter back to retailer and see if you can exchange it for another one. Also, make sure you have the right filter model number. You can check the model number for the filter with your refrigerator model number at Searspartsdirect.com
Hope this helps
Dec 13, 2014 | Samsung Refrigerators
How and where do you change water filter
From the KitchenAid Manual:
The water filter is located in the upper right-hand corner of the
refrigerator compartment.
Replacing the Water Filter
To purchase a replacement water filter, model 67003523 Part
Number 4396395, contact your dealer or call 1-800-442-9991
U.S.A. or 1-800-807-6777 Canada.
IMPORTANT: Air trapped in the water system may cause water
and filter to eject. Always dispense water for at least 2 minutes
before removing the filter or blue bypass cap.
1. Turn filter counterclockwise to remove.
2. Remove sealing label from replacement filter and insert the
filter end into the filter head.
3. Turn the filter clockwise until it stops. Snap the filter cover
closed.
4. Flush the water system. Depending on your model, see
"Water Dispenser" or "Water and Ice Dispensers."
NOTE: The dispenser feature may be used without a water filter
installed. Your water will not be filtered. If this option is chosen,
replace the filter with the blue bypass cap.
http://www.kitchenaid.com/digitalassets/KFCS22EVMS/Use%20and%20Care_EN.pdf
May 16, 2014 | KitchenAid KFCS22EVMS French Door Bottom...
Water dispenser on fridge not working - water pressure fine, could the line be frozen and why would that start happening all of a sudden?
Check to see if the water reservoir in the bottom of the frig is frozen. If it is, you will need to turn the frig temp down.
Dec 04, 2012 | Refrigerators
My water dispenser does not give me water
1st make sure you got water to the frig.
defrost the frig by turning it off for 2 days with the doors open. Sometime the water freezes inside the door and the water dispenser doesnt work. the turn back on and see if you have water. every 6 months you should change the filter (it could be the problem too)
Mar 27, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
The water dispenser stopped working but the ice dispenser still works just fine on my KitchenAid Superba KSRG25QFB side by side
First Question, Have you changed the water filter???needs to be done every 6months. dirty water filter can keep water from flowing through system......also nasty to drink.........
Jan 09, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Kitchenaid no water, but ice
first thing i would check here is my water resivoir, on these models it has a tendency to freeze,, hit the tank and upper line with a hair dryer for several minutes then give the water a try....
barring that it may be time to change your water filter even if the sensor has not picked it up yet
Oct 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker and water dispenser not working
well there is two things it could be low water pressure or ur ice maker is defective try replaceing the ice maker this should work if not u need to get a frig repair man out to help u because if the problem is in the frezzer door it is not easy to fix on ur own
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Hotpoint CSX22GR water dispenser not working
Sounds like to me your filter needs replaced...how long ago have you changed them?
Jul 18, 2008 | KitchenAid KSCS25FKSS Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Water does not dispense from the door but there is water to the filter fitting
connect the water line in to the solenoid [with out the filter] to see if u dispensing water
Dec 01, 2007 | GE Monogram ZISx420DR 42-inch Side by Side...
Refrigerators Logo
162 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
