Igniter kicks the burners on, but about the time the main fan turns on, the burners blow back out. blowing cold air out as a result. plz help!!!
  • 89 Answers
From what you are saying, I would bet you have acrack in the heat exchanger.See if you can watch the burner when the fan comes on. You should see the flame blow out and either move away from the flame sensor or onto a a rollout switch. I'm afraid the only remedy is to replace the heat exchanger or the furnace, depending on the age of the furnace.
Posted on Nov 17, 2009
My furnace works on ac and blows on ac but on heat it does not blow but i hear a humming sound coming from the furnace
Most furnace operating on Oil or gas will heat the combustion chamber before starting fan to prevent cold air draft at start-up, can last a minute or two. Eiter the main flame does not come on or the chamber thermostat have fail. Try to modify fan option on room thermostat from auto to on. Cold air coming out: burner problem or no more oil or gas, warm air: burning chamber thermostat problem, leave room thermostat fan option to on until repair.
Jan 02, 2014 | Comfortmaker Heating & Cooling
I have an older Carrier furnace type 58ss. The main burner will not ignite. Operating look ~ thermostat set @ 78 deg, switch furnace on, inducer fan running, pilot light clicks and ignites, inducer still...
power to gas valve ok .. Replace gas valve after checking gas valve coil for continuity/resistance... with valve removed ...and power to valve ... try blowing thru valve from supply side ... stuck valve.... replace...
Nov 01, 2013 | Heating & Cooling
Brivis Buffalo 15 not blowing air.
This sounds like a flame proving fault, so what's more than likely happening is the unit isn't sensing the flame. You'll see a small metal rod sticking down infront of the burner on the opposite side as the ignition source. Remove that rod, and clean it with some scotch bright. If you know how to work a volt meter you can test this part. Take the wire off the flame rod, place your meter leads in series with the wire and flame rod and set it to micro amps DC. Fire the unit up, and when your main burner lights you'll want to see a minimum of 1micro amp DC. If you're getting a higher reading than that and it still cycles I'd be suspicious of the grounding of the burner, or the ignition control! Good luck, let me know if you need any more instruction!
Apr 18, 2013 | Heating & Cooling
I have a Dayton Furnace Serial# swglm033942 and need some information; My furnace is installed in the attic and sometimes it will not blow hot air. I have tried to start it and the burners start up, but...
Please have this checked out by a technician. If there is a crack in the heat exchanger it could do just as you described. The blower blows air into the combustion chamber and blows out the burners.
Jan 07, 2011 | Dayton Gas Furnace Heater
The furnace will light up and the fan will blow but the flames cut out before my house reaches temp. i have the thermostat set at 70 and the house will not get above 55. i have tried turning the propane...
First, for those of you who might not know, "What is a flame sensor?" A flame sensor is a safety device. When your furnace's main burners ignite (light Up) the flame sensor picks up the heat from the furnace's main burning and says, "YES," and sends a signal back to the main furnace control board saying that it is OK to let the main burner stay on. Or if the main burners do not ignite, the flame sensor does not pick up the heat and says, "NO" to the main control board, Shut That Gas Valve and Main Burners Down! Thank God we have safety controls like the flame sensor. Most of the time, after turning your furnace's power off, you may clean the flame sensors with light sand cloth, emery cloth or steel wool. Reinstall the flame sensor and you are back in business! Over the years flame sensors can build up a light coating of burned-in dust and dirt. This insulates the flame sensor so that it doesn't sense the heat of the flame well enough, so by cleaning it you have almost restored it to its new condition. Seldom, but sometimes they do go out completely.
Dec 08, 2010 | Coleman Heating & Cooling
My Heater blows cold air
is this a gas furnace if so does the burner ignite
Nov 25, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
