Question about Motorola Mobility RAZR2 V8 Cellular Phone
My phone does not star apear
err.a3,1202
Simlock
Unlock Cell Phones
Your cell phone may be locked to a particular cell phone provider and in this case it needs to be unlocked to use with a different cell phone service provider.
To get the security code/restriction code to unlock the cell phone from the current cell phone provider so you can use the SIM card with a different phone provider, Please click on this link and follow my instructions :-
http://www.fixya.com/support/r4049238-unlock_cell_phone
If your phone provider does not help you then these WEB sites it provides security codes for a small price.
http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw
http://www.mobileunlocksolutions.com/
http://www.superunlockcodes.com
http://unlockcellphonecode.com/
May 04, 2013 | Samsung Star GT-S5233 Cell Phone
Ir1024 given error 000
turn onn the mechine press star button of additional function and press 2 then 8 for same time then press star select copier option then function then clear then err then ok restart the mechine it will work
hope soloution help you
Sep 05, 2012 | Canon Office Equipment & Supplies
Canon ir1024 given error 000
Erro na sharp mx 3100n U2-80
On the control Panel, press the keys #*C* (pound, star,clear,star)to enter test mode. Enter number 16 and press the copy button. On the touch screen press "execute" and "yes". Press CA to reboot. The error code should clear.
Aug 03, 2012 | Sharp MX-2700N Color Copier
What dose it means Error : E000000-0001
Reset the error in service mode. Press the head key (the head with the star inside) then 2+8 together and then the head key again. This will get you into service mode. Then select 'COPIER' then 'FUNCTION' then 'CLEAR' then select 'ERROR' or 'ERR' press 'OK' then switch the machine off and on again
Nov 11, 2009 | Cell Phones
Can not enable predictive text on sony ericsson t303
when you trying to send message hold down the hash key and chose english and this will give you predictive text back.
Jul 19, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Eonon E838 Bluetooth Won't Pair (blue err)
did you fix your problem?
i have had the some problem!
Jun 02, 2009 | Car Audio & Video
Error code 000002-0010
You need to clear this fuser roller heat rod error in svc mode.
Additional Functions="star"
2and8= hit both keys same time.
Svc mode= star 2and8 star
copier/functions/clear/err/ok
reboot
If there is areal problem with fuser heat rods it will code again.
Nov 08, 2008 | Canon imageRUNNER 5000 Copier
Won't Star keeps flashing Pause and Err
that was just happening a few seconds ago with mine and i just tried pusing the control button and the options button at the same time for a few seconds... i reopened the door and pressed start again...it's running now... good luck
Apr 20, 2008 | Frigidaire Affinity ATF7000E Front Load...
Motorola Mobility RAZR2 V8 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
