Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
AS THE POOL GET HOT, IT IS STARTING TO SHUT OFF THE GAS SUPPLE. AT 100 DEGREES , THERE IS NO POWER TO THE POOL HEATER
  • Dale Cobb May 11, 2010
    what type of heater and control system do you have?
    Champion:
  • 246 Answers
CHANGE THE COMPUTER BOARD MAKE SURE YOU GET THE NEW MODEL OR UP GRADE KIT
Posted on Dec 07, 2009
Ihave a 175000 btu Lite 2 Jandy Pool Heater model # LD175P. It takes approx 3 hrs to go from 48 degrees to 100 . Why so long?The spa is 7ft in diameter and normal spa depth.Should I have a more btu heater?...
That seems to be a pretty good heating rate. You're talking about 52 degrees in 3 hours. If you want quicker heating, you will need a higher output heater.
Gary
Jan 06, 2011 | Jandy Pool & Spa
I have an RP 2100 pool heater and the minimum temperature set point is 65 degrees. Every time the pool/spa temp falls below 65 degrees, the heater automatically turns on. How can I either disable this...
Do you have an electrical switch that turns this heater on/off?
Can the heater be unplugged?
Is the heater on a separate circuit breaker that can be shut off for the season?
Nov 27, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
HEATER RUNS (HOT EXHAUST) WATER IS CURCULATING ( CAN FEEL AND HEAR) BUT WATER IS NOT WARM OR HOT ?
As hot water leavs the heater it mixes with cold water so what you feel at the pool side is barley warmer than the pool. This is ment to keep from scalding people in the pool or spa. 7-11 degrees is the max on the outlet.
Apr 24, 2010 | Hayward H Series Pool & Spa Heater 400k...
My heater ignites and blows really hot exhaust
The water is mixed on the back side of the heater and will exit the heater at 7-11 degres hotter than it came in. This will keep people from being scalded at pool side. So what you have sounds normal.
Apr 05, 2010 | Hayward H Series Pool & Spa Heater 400k...
QCA Opal hot tub display reading OH.
The tub experienced an overheat situation. This may be due to leaving the t stat turned all the way up and not monitoring or the hi-limit sensor is defective. The hi-limit sensor will shut down the heating cicuit if temp gets above 105 D optimally.the fact that the heater light is on is a good sign that things are working at this point.Whether or not a suitable temp(100-103 D) will be arrived at is to be seen. If spa heat kicks off before set temp is reached then replace hi-limit sensor.
Apr 10, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Sta Rite Sr333na Max E Therm Pool & Spa Heater gauge stuck?
Anytime the heater is reading the water temp to be above what it actually is, especially 126, the problem is the Thermistor, or Temp Sensor, for the heater. This is a very easy part to replace. The Thermistor is located on the manifold, on the left side, between the top two bolts.
Sorry this is a late response! Hope that it helps!
Apr 10, 2009 | Sta Rite Sr333na Max E Therm Pool & Spa...
Pentair Heater shuts off prematurely when warming spa
check gas pressure could be running out or overheating
Mar 06, 2009 | Pentair MINIMAX NT TSI IGNITER
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
117 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
