Question about Whirlpool GU2400XTP Built-in Dishwasher
Dishes are cloudy, not clean - Whirlpool GU2400XTP Built-in Dishwasher
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 16, 2009
Dishwasher dishes cloudy and makes loud buzzing soundf
I am not sure about the buzzing but cloudy dishes is caused by
hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jan 03, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
Dishes come out cloudy. do i need ro clean my may...
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
May 19, 2010 | Maytag MDB7100AWB Dishwasher
The middle cleaning arm is not spinning and the dishes are cloudy and not getting as clean.
the spray is probably clogged due to hard water. that is also the reason for the cloudy looking dishes. go to www.dishwasherfilter.com and get there new system to fix this problem once and for all.
Feb 12, 2010 | GE Profile PDW8600J Built-in Dishwasher
My dishwasher is now leaving my dishes cloudy. What causes this?
Make sure that the rinse-aid(jet dry) container is full. If it is full have you noticed if it's level has not dropped. It is possible that the rinse-aid dispenser is plugged. This will cause the dishes to be cloudy. You can also try running the dishwaher empty and add a cup of vinegar to the bottom before your start. There is also this stuff called "dishwasher magic" that you can try running in the dishwasher to clean it. Try using a soap with the rinse-aid in it or install a basket with a rinse-aid tablet and see if that helps clear up those cloudy dishes.
Nov 08, 2009 | Frigidaire Dishwashers
Cloudy and dirty dishes after washing
I found this for you on YouTube. I don't think that you want to go to the extreme lengths that this guy did, but he does show how to disassemble the inside portion of your washer so you can get to the parts that need cleaning. This should get you back up and running, with sparkling dishes, and a big smile on your face! There are also oyher videos there, some selling products that may help.
http://www.youtube.com/watch?v=JhchaOhpQQo
Best regards, --W/D--
Aug 08, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Not cleaning dishes, leave a cloudy film on silverware
the problem is hard water. you need a dishwasher filter and your problems will be solved. you can get one at www.dishwasherfilter.com and it is guaranteed or your money back. you will love the way your dishes come out.
May 31, 2009 | GE Dishwashers
Cloudy dishes
Hi there.
You will need to get some cleaning detergent so you can clean the jets and the internals of the machine, once the clean has been done you should end up with clean dishes.
Good luck and thanks for using FixYa!!
May 11, 2009 | Kenmore Dishwashers
My 3 year old
Try a different detergent such as the electrosol tablets. Also might add vinegar to an empty cycle to clean dishwasher, or with dishes.
Oct 15, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Cloudy Dishes
there is a new product out that filters the water going into your dishwasher. the film or cloudy white look is caused by hard water. this filter eliminates the problem and is very affordable. you can get it at dishwasherfilter.com. i was amazed how clean my dishes came out after the first load.
Nov 03, 2007 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
181 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
