Question about Rival CF275 Deep Fryer
Deep Fryer doesn't get up to a proper temp.
Tried the deep fryer for the first time, Put the thermostat up to 375 degrees and the temperature only went to 339 degrees and the batch of food was ruined. Why can I do?
  • 57 Answers
Posted on Jul 17, 2008
What are the normal fluctuations of oil temp for a 40 lb Imperial fryer. If I set the temp at 350 the oil heats to 375 and will come back on at 325 to 330. Is this a normal temp swing or bad thermostat?
The temperature fluctuation you describe is quite normal. A 25 degree rise after burner shut off is within factory specs, but you do not want more than a 25 degree shift. If you lower the oil level and look at the bracket that holds the thermostat bulb, make sure there is no build up of carbon or gunk. This can insulate and cause greater fluctuations in temp.
Feb 03, 2015 | Imperial Kitchen Appliances - Others
I have a vulcan deep fryer and when i turn the knob up to 400 max it heat the oil but will cut off if i turn down to 375. the unit has been off. what part is needing to be replaced.
I'm unclear, if it has reached 400 you would expect it to be off at 375, until the temp drops below 375.
If I have misunderstood then apologies.
May 13, 2014 | Vulcan EF3 Deep Fryer
Fryer only heats to 260df after 30 min. Used 4 times.Having trouble taking it apart to get at the thermostat.What do I need for tools?
Describe your DF200 FryMate™ Plus Cool Touch Deep Fryer Problem
Only heats to 250*...making doughnuts calls for 375*
May 07, 2011 | Black & Decker DF200 FryMate Fryer
Fryer overflows often, turned thermostat down from 350 to approx 340 but food does not cook then. could the thermostat be bad? 10 degrees should not make that much difference.
Does the fryer have a" temperature reached light"? If so switch the fryer on and with the thermostat dial starting at its lowest setting increase the temperature setting in small increments. When the light indicates temperature reached, increase the thermostat dial temperature. Continue until maximum temperature reached.
If (starting from cold) the temerature reached light only shows when high up on the thermostats temperature scale, then unfortunately the thermostat needs replacing.
Hope this helps.
Mar 04, 2011 | Dean D50G-C Deep Fryer
Fryer does not shut off when temp .is reached
I assume it is a gas model. There are 2 thermostats. One is adjustable, you set your temp, it sounds like it has gone bad.. The second thermostat is the high limit thermostat. When it reaches 450 degrees F, it will shut down the pilot and main flame to prevent a grease fire. It may be possible that someone has hooked the thermostat up wrong. Next time you fire it up, disconnect one of the thermostat wires that has the temperature knob. If the flame goes out, the thermostat is bad,
Oct 04, 2010 | Imperial IFS40 Deep Fryer
I put it on any temp and it heats to 550 degrees
Replace the thermostat, P5047588. If the fryer is not shutting off, both main burner and pilot, when it overheats, also replace the high limit PP10084. The high limit usually shuts the fryer off at about 425-450F. Check your thermometer. A fryer should never get up to 550F.
Feb 24, 2010 | Pitco Frialator 35CS Deep Fryer
My fryer will not heat up consistently. If i press the reset button, it heats up. But after heating up to a certain temp it shuts down and stops heating. There is power to the unit, it seems like a problem...
It probably is a problem with the thermostat. The reset button is probably a high limit. The high limit is a safety device to turn the fryer off if the oil gets too hot. Normally they will "trip" somewhere between 375 - 450 degrees F for commercial fryers. I would suggest placing a temperature probe in the oil and see what the oil temp is when it trips. If it trips at a temp below 375, it is a bad high limit. If the thermostat is set at 350 and the temp goes over 400 then the thermostat is bad.
Feb 03, 2010 | Kitchen Appliances - Others
The deep fryer does not heat up to 375 degrees. It only heats up at the lower temperatures. Can you explain what might be wrong with the fryer
Hello. It is likely that the thermostat on this fryer is off. try turning it to a higher setting and testing the temp. with a separate theremometer.
Nov 24, 2009 | Office Equipment & Supplies
High limit kicks out fryer and pilot light can
Since you've mention the pilot light goes out at 400 degree F, then we are talking a gas Deep Fryer. The deepfryer usually use at 350 degree F for chips or else. Because the oil will start breaking down its quantity of frying very quickly over that temperature. Most people set at 350 degree F. Now we comes back to your problem, First you should have a deep fryer thermometer they espcially made for deep fryer, (You only mention 400 or better ) that make me think you're only guessing. Knowing the temperature is very important, most Hi limit is set at 420 degree F.
To me it seen the Hi Ltd control is working and that is why it cutting out the pilot when it reach its limit but we don't know what temperature that when the hi limit cutting out at.
When you have a thermometer, put it in the cold oil and turn the temperature to 100 degree F to see what the temperature control cutting out at. slowly increase your setting until it cutting out at 350 degree F . If you set at 250 degree F and the thermometer already reaching 350 degreen F then don't go any further , your temperature control is defective and need to be change a new one.
This is only the first step, you still have to check out the Hi ltd control to see how good its condition is,so far your information say it cutting out at 400 or better. But you've to be sure, because it is a safety control. Hope that will help you , God Bless.
Jul 05, 2009 | Pitco Frialator SG14 Deep Fryer
What temperature do I set the dial on the unit to fry a large amount of chicken in the deep fryer?
375 degrees. However, make sure the internal temp. of the chicken reaches 180 degrees.
May 06, 2009 | Kitchen Appliances - Others
Rival CF275 Deep Fryer Logo
253 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ric Shull
Ric Shull
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
