Question about Palm AT&T C/PHONE PALM CENTRO S64801
My palm centro wont turn on how do i get it to turn back on?
SOURCE: my palm centro wont turn
hey i had the same problem but just a tad different, my phone just wouldt turn on in general so i plugged in the phone and just started messing with the keys, i dont know if that will help but its worth a try
Posted on Jan 29, 2009
jamers2004
  • 96 Answers
SOURCE: I drop my phone centro palm into water! I charge
Get a bowl of rice. Remove the battery from the phone. Leave the phone back open. Put phone and battery in the bowl of rice, cover and leave overnight.
The rice will hopefully soak up any water inside the phone and battery. If this doesn't work there may be permanent damage to the phone from the water and charging afterwords.
Posted on Mar 02, 2009
  • 9 Answers
SOURCE: replace the keypad on a palm centro
first off you need a t6 screwdriver. this is a special screwdriver with a star shaped bit specifically used for the screws in your centro. if you don't have one, you can buy one off ebay cheap or maybe even borrow one if you go into your local cell phone shop. they probably could even help you replace it if they're nice, even if you didn't buy the keypad from them.
start by taking out your stylus, your battery, and the little rubber plug thing on the opposite corner from your stylus. it just kinda pops out if you get under it with something pointy like your nail. set these things aside somewhere safe. there are six screws to take out, one under where the stylus was, one under where the rubber bit was (there are three holes here, the middle one is the screw hole), and four more that are super easy to see with the battery cover off. take out all six screws and put them somewhere safe too. then gently pry the back housing up from the bottom and pull it downward with a little wiggle and it will come right off. there is a smaller separate piece that surrounds the hotsync cable port and charger port and this comes out too. set these aside.
the next piece we will take out is the motherboard. you will need to disconnect the screen and the keyboard. they are actually under the motherboard but connect to the top side. lay your phone facing down on the surface in front of you and there will be two pieces of black tape toward the bottom of the exposed motherboard, one on either side. gently pry them up, folding them back toward the edges of the phone but do not remove them completely. this makes it easier to replace them later. under the tape are connectors for the ribbon cables that connect the screen and the keypad. there is a small grey bar that locks the ribbon cable in place. gently pry them up, flipping them toward the center of the phone. then gently pull the end pieces of the cables out of the connectors. they will kind of just point up toward you, not flop back over the edge of the phone.
lift up the motherboard by the bottom, like where the hotsync cable goes. pull the motherboard down toward the bottom of the phone while gently (or it will break off) lifting up the part of the housing that covers the speaker and the camera. set the motherboard aside.
now there is a kind of sticker that looks like gray mesh covering the back of the screen and the keypad. pull this up gently from the bottom wherever you can get an edge started to pull it up. you can stop pulling when you get to the part where it's just covering the back of the screen because you won't need to get under there. the flat ribbon cable that goes to the screen might stick to the mesh, and that's ok, just push the whole thing up out of the way.
now you can lift up your phone and gently push the keyboard back through from the front. it will kind of pop out. it helps if you hold the phone facing down still and use your thumbs to kind of push the sides of the phone out a little so the keypad can just pop back. at this point you should have the part that is the keyboard with the cable sticking out of it, and if this is the part you need to replace, ignore the next paragraph. if it's the actual arrow and power keys, read on.
the green and red buttons (or power and talk) and the 5-way navigation button are all connected together and you can replace this whole piece by just pushing it out from the front, and setting the new one in it's place. it's easy to get mixed up, so just in case, the green button is on the left front and the red button is on the right front.
now there's just putting the phone back together. pop the keypad back in (check the front to make sure it looks right and it's popped in all the way). re-stick the mesh back down over top of it. make sure you have both cables showing and they didn't get stuck under there. take the motherboard and slide it back under the speaker cover (lift it up and wiggle), and make sure the cables don't get caught under it. it takes a fair bit of wiggling to get it sitting in there flat. reattach the cables by sliding the ends into the little slot. if you look carefully, there are little guide lines on the keypad cable that come just to the edge of the connector when it's all the way in. flip the little gray bars down to lock the connectors in place and restick the tape. put the little plastic piece from the bottom back on (it only fits one way) and then put the back housing on and push on it until it kind of clicks into place. replace all the screws, the stylus, the battery and the cover. you're done!
Posted on Jul 03, 2009
SOURCE: my palm centro was hot cyncing intself
I just googled this issue b/c my daughter got a hold of my phone and somehow (as only an 8 month old can) hotsycned my phone. O
ut of total frustration at the thought of having to replace my phone, I took the battery out and left it on the counter for about a minute. It works fine now.
Posted on Aug 19, 2009
VinayT
  • 1884 Answers
SOURCE: Palm Centro will not charge. Red lite comes on
Jim,this shows that the charger and the charging circuit are fine and kicking. Only the battery is debatable. If an old battery then it has gone. even not so old battery could be the culprit. so, replace it.
Posted on Sep 08, 2009
Palm Centro Freezes on Power Up
try clearing up your web history, sms, or unwanted software....on the browser, click on blazer top left corner, click on history and clear all..tested if it doesnt work back up your phone and perform a master reset
Mar 23, 2010 | Palm Treo 500 Centro
My palm centro was hot cyncing intself
Aug 04, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Why does the centro turn on and off by itself
http://forums.palm.com/t5/Support-Downloads/Palm-Centro-ROM-Update-for-Freezing-Issue/td-p/165101
Jun 27, 2009 | Sprint Palm Centro Smartphone
Palm centro wont turn on
I had this same problem during hurricane ike. I thought that it was because the cell towers were down or something, but I eventually had to take it to the sprint store because nothing was working. I've had to get 2 replacement phones since then, so..good luck!
Mar 11, 2009 | Palm Treo 500 Centro
I drop my phone centro palm into water! I charge the phone and the red light turns on but my phone wont turn on at all. What can i do
Mar 02, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
My palm centro kayboard light wont come on.
Have you tried the option key + menu key? It turns dims the screen and toggles the keyboard backlight on and off.
Dec 04, 2008 | Palm Treo 500 Centro
HELP ME WITH MY PALM CENTRO
I am having the same problem.
Aug 25, 2008 | Palm Treo 500 Centro
Palm AT&T C/PHONE PALM CENTRO S64801 Logo
395 people viewed this question
Top Palm Cell Phones Experts
fhonwizards
wayne chamberlain
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
