Question about Zebra LP 2844 Thermal Printer
There is a white line through middle of label
There is a white line going down the middle of the label. Do I need to clean the heads or run a test page?
  • 748 Answers
You should clean the head with every transfer ribbon change using the cleaning pen supplied with the printer, or with isopropyl (IPA) alcohol cleaner - dampened cotton swab.
If you want, you can open the printer, unwind some of the ribbon to give it a generous slack, clean the head under the ribbon, then wind it back taut.
If you use thermal labels without the ribbon, the head is exposed and can be easily cleaned as above.
If this doesn't help, it means that your printhead is damaged, or the roller against which it is pressed (underneath the labels) has uneven surface - look for a dent or impression around the roller in the spot you observe the white line.
Unfortunately, the head has a tendency to get damaged over time, especially if you use thermal labels without a ribbon (more abrasion); it can also be easily damaged if someone tries to clean it with hard or sharp tools - it has thousands of tiny spots that heat up to form an image, and they are rather delicate.
Posted on Nov 16, 2009
Printing white lines on label
Missing elements in print head, replace print head.
Nov 05, 2013 | Zebra ZP 450 Thermal Label Printer
When I print my labels, there are lines that run through it
The lines(voids) are being caused by elements that are worn off the printhead. No energy is getting there to release the ribbon, causing a void area. To see the full extent, just create a label, using your widest label, that prints a thick black line. You will easily see the "void" areas as white lines.
This is common over time due to the constant contact with the ribbon. The elements wear down just like the tires on a car from the constant contact with the road.
The only way to correct is to install a new printhead.
Apr 28, 2010 | Zebra Z4Mplus Label Printer
Good morning, having problems with zebra printer 110xilll Plus. white streak down middle label. V
You can try cleaning the print head with Isopropyl Alcohol, if this doesn't fix it - you printer will require a new Print head
Jan 20, 2010 | Zebra 110Xi III Plus Thermal Printer
White vertical line runs through a shipping label
The problem is that the printhead is damaged and will have to be replaced. Assuming there are no other letters in the TLP2844 model number you gave then the part number for the printhead is G105910-053 and will cost around $100. Hope that helps.
Aug 26, 2009 | Zebra TLP 2844 Label Printer
White line going down printed page
Hello sir; you need to clean print head and cartridge seat, follow the steps; turn power on open top cover (as when you replace cartridge)let the cartridge carrier move to the center the UNPLUG the power the carrier will stay in the middle you can it freely, move it away from seat should find alot ink stick, remove it, clean out wipper blade and print head it should take care of your problem.
Jun 04, 2009 | HP Office Equipment & Supplies
#5 black ink cartridge skips through the middle occasionally
Replacing the print head
The print head may need replacing if, after all print head and ink tank troubleshooting has been performed:
  • The nozzle test appears broken or to have horizontal white streaks.
  • One or more of the colors is missing from the Nozzle Test.
  • The colors are incorrect on the Nozzle Test.
  • A print head error is indicated on the unit.
  • The printer powers off when the print head is installed.
I hope it helps!!!
Nov 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Possible print head failure
to test , press pause botton and turn on (press 5 sec.)
he print a "pause test".
check if print, if stop on ich gap and if come some lines across the print (if apear some lines, need new print head.) this step just pause wen print some labels, and then still print until turn off.
Turn off and turn on the printer to work normal.
To calibrate media, go on the setings to "sensor profile" and/or "run manual calibration, follow the steps. (dont forget to take the ribbon from the sensor.)
let the test run until finish.
May 02, 2008 | Zebra Z4Mplus Label Printer
EPSON Stylus CX3810 thin white line in every printed line
Hi there the likely thing is that there is a small blockage in the print heads not allowing the jet to fire and causing a blank line. You could remove the print head turn it upside down using a soft cloth clean the print head also use a alcohol based fluid to aid you.
Try this if it's doesn't work then the print head will need replacing you will be able to buy online.
Thanks J
Jan 12, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Epson Photo R265 Lines every 2.5 cm
check if those lines matches the positions of the rollers inside the printer - you can see some of them by opening the cover
Dec 24, 2007 | Epson Stylus Photo R340 InkJet Printer
Zebra LP 2844 Thermal Printer Logo
1,128 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
