Question about Bell Technology iTeddy MP3 Player
When i connect the iteddy to my pc he battery icon does not appear and it is not charging
  • blackbeautya Nov 16, 2009
    help iteddy not charging when connecting to the pc nor is battery icon appearing
    solve the above
  • 4 Answers
Make sure you push the jack fully into the front of your iteddy as it has a extra notch compared to a speaker jack. and give it 10 mins as it has to get a small charge in to configure the battery
Posted on Dec 12, 2009
Gateway NV5378u lap top, brand new battery installed and status says 100% charged. When I unplug the computer it shuts off as if there is no battery. Could the new battery be defective?
There are a few things to check. The LED lights can tell you a lot. This will tell you more about the battery:
  1. On the taskbar, double-click the power cord icon or battery icon to open the Power Meter dialog box. Note: If the power cord icon or battery icon does not appear on the taskbar, click the show hidden icons button.
  2. Press Fn+STATUS to view the power status box, which opens in the upper-left corner of the screen. The power status box shows the current power source, the battery charge level, and the power management mode.
  3. Look at the battery charge indicator (if applicable).
    • LED green - Battery is fully charged.
    • LED orange - Battery is charging.
    • LED blinking red - Battery charge is very low.
    • LED solid red - Battery is malfunctioning. Note: This LED only lights up when the notebook is connected to AC power.
  4. Press the battery meter button on the battery. The battery meter lights indicate the percentage of battery charge remaining.
  5. Wait for a Low Battery warning message to appear.
If your battery charge indicator displays what looks like an inaccurate charge, you may need to recalibrate the battery.
To recalibrate the battery as mentioned, try this:
  1. Connect the AC adapter and then turn on the notebook.
  2. As soon as it starts and you see a startup screen, press the F2 key.
  3. In the BIOS Setup utility, use the TAB key to select the Advanced menu.
  4. On the Advanced menu, select Battery Auto Learning, and then press the SPACEBAR to select Enabled.
  5. Use the RIGHT ARROW key to select the Exit menu. On the Exit menu select Exit Saving Changes, and then press ENTER.
  6. At the Setup Confirmation prompt, select Yes, and then press ENTER.
  7. The battery recalibration process begins and a screen opens showing you the progress.
  8. When the recalibration has finished, and the message "Press [Esc] key to exit" appears, press Esc. The battery charge indicator now displays an accurate battery charge.
Hope this helps!!
Oct 20, 2013 | Computers & Internet
I've plugged the usb into the i teddy & pc but it will not charge
Since this device is probably about 4 years old, most likely the rechargeable battery within the iTeddy MP3 player has reached the end of its usable life.
This question has been asked on fixya previously here: (click here)
I'm surprised that this didn't come up as a possible resolution to your problem when you first arrived at this site. It seems that there were replacement batteries available for this toy; however, some soldering was involved with the fix.
Apr 20, 2011 | Bell Technology iTeddy MP3 Player
I have bought an sd card for my iteddy but when i put it in it doesn't recognise anything on it any advice?
make sure you use the iteddy software to convert films first.
the iteddy only accept 2gb as the largest sd card and not sure about sdhc cards.
Dec 04, 2009 | Bell Technology iTeddy MP3 Player
Cant move files from file convector as no icon coming up in my computer folder to move them to
make sure you have pushed the jack in all the way on the iteddy as it has a extra notch compared to a speaker jack. only when in fully will your pc find your iteddy as plug and play and add it as a extra hard drive in windows explorer
Oct 01, 2009 | Bell Technology iTeddy MP3 Player
My phone only works when it's plugged into the charger
New batteries are shipped partially charged. Before you start using your device, it is recommended that you charge the battery. Some batteries perform best after several full charge/discharge cycles. You can charge the battery in two ways: • Charging the device’s battery by connecting the power adapter. • Connecting your device to a PC via the provided Mini USB cable. Note: Only the AC adapter and USB cable provided with your device should be used to charge the device. Charging is indicated by a solid amber light on the left LED indicator. As the battery is being charged while the device’s power is on, a charging icon will be shown on the title bar of the Today screen. After the battery has been fully charged, the left LED becomes green and a full battery icon appears on the Today screen’s title bar. Warning! Do not remove the battery from the device while you are charging it using the AC or car adapter. As a safety precaution, the battery stops charging when it overheats. When the low-battery warning appears, do the following: • Immediately save your current data. • Synchronize with your PC or connect the power adapter to charge the battery. • Turn off your device.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jul 14, 2009 | UTStarcom Blitz Cell Phone
Iteddy blank screen when attempting to charge
I had exactly this problem, i found you can fix this problem by being careful you can:-
1 remove the belt clip and disconnect the battery very gently.
2 unscrew the back of the unit and remove it.
3 unscrew the circuit board, DO NOT DISCONNECT THE RED AND BLACK SPEAKER WIRE
4 where you can see the jack insert there are three pins, push these pins in gently.
5 reconnect the battery and plug in the jack, the screen should come on. If it does'nt try pushing down the pins once more gently of course, to ensure good connection to the jack.
This worked for me and only took ten minutes, good luck.
Jul 09, 2009 | Bell Technology iTeddy MP3 Player
ITeddy Battery Problem
When I first bought the iTeddy we did not check whether it works or not, wished we did! 2 months later when we gave it to our daughter for her birthday, it didn't work! Battery was flat and would not charge. Only worked if you plugged the unit into a USB Port to get the power. We'll searching around I could not find anyone talking about changing the battery. I went to Jaycar (electronics store) and found replacement iPod batteries. They were the same voltage (3.7V) and mAh (900mAh). I bought it in hope it would work, and YES it did! Charges up too! The battery was a "little" bigger, but that didn't concern me, but if it does you then maybe try a 3.7v with a lower mAh and that will fit. You will need to cut the wires and match the red with the red and the black with the black of the battery. Make sure you keep the plug of the iteddy so you can take the battery out by unplugging it. I used a soldering iron to fuse the wires together. Good luck!
Apr 30, 2009 | Bell Technology iTeddy MP3 Player
Is there any such thing as charging my mps nextar MA933a via the USB port? I just get sleepy z's on the display when I connect it to my computer.
Here is what I found:
Connected the player to the PC with and without prior power on successfully
OSD first displays message “Starting…” then:
Icon appears on screen with a picture of a computer monitor to right and mp3 player icon to left
When mp3 player is communicating with computer or sending information, an appropriate directional arrow appears between the two icons; when transferring files using Windows Explorer, the arrow reverses direction appropriately; when there is no activity either way, a series of “Z z z” ‘s appear on screen
Battery indicator icon also appears to right – new AAA battery resulted in a fully charged icon upon startup; no battery whatsoever resulted also in a fully charged battery icon appearing
-Tha Mp3 Doctor
Feb 02, 2009 | Nextar MA933A MP3 Player
W810i doesnt turn on or connect via usb
Charge the phone until it has finished charging, The first thing to do is to make sure that the phone is charged. Attach the charger and charge the phone for about 2.5 hours. Please note that the battery icon may not appear until after the phone has charged for 30 minutes. When the battery icon has stopped “flashing” the phone is fully charged.
Jan 17, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Bell Technology iTeddy  MP3 Player Logo
433 people viewed this question
Top Bell Technology Audio Players & Recorders Experts
venugopal durairajan
Computer Repairing
Computer Repairing
Are you a Bell Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
