Question about Motorola Mobility RAZR V3m Cellular Phone
Just bought a new razr v3m with the memory slot and I install the card in the slot and it does not show up on the phone anywhere what can I do to get it functioning so I can use it with this phone it was working with my old phone and now its not even showing up on this one>
How input the sim and memory card in v3m verizone wireless from v cast motorazr
Open the flap at backside . remove the batter and insert the SIM card.
Memory card slot is on the left side.
Aug 18, 2010 | Motorola Mobility RAZR V3m Cellular Phone
How do you bring up pics from a memory card from an old phone to a new phone without erasing them (new phone is Motorola razr v3m)
There are two ways to do this, you either transfer the picture from you old phone to your new phone through bluetooth, or just take out the memory card from you old phone and insert it in the new phone.
In some cases, the picture might be to large to display in your motorola, so i will advice you send the picture to you computer and compress it to a reasonable size (maximum 500kb) and put it back in the memory card and it will definitely show.
Jan 15, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Razr v3r
Hi folks - I took apart and totally destroyed my Verizon branded RAZR V3m. There is NO SIM card. Instead, there is a memory chip hard wired to the circuit board. From what I saw, this memory chip is preprogrammed with the phone number and carrier features. The card picture referred to above is for the micro SD card. This card is just for additional memory - for pics, video, and music, dependent on the carrier. I also went to the Motorola web site. They're unlocked RAZR V3's have a SIM slot underneath the battery. Bottom Line? If your RAZR V3 doesn't have a SIM card slot under the battery, forget it. You can not change carriers.
May 17, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Doesn't read my SanDisk memory card
Here's what you do;
go back to the store, smack the clerk upside the head for giving you bad advice, and trade the 4gb for a 2gb.. (or the razr for another phone). The V3m doesn't support SDHC cards; only SD ones. SD are 2gb and below, while the HC (high capacity) are 4gb and up.
Sucks, doesn't it..
Mar 06, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Trans flash card
The razor only supports upto a 2 gig sd card.
Aug 29, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Removal of sim card from Motorola RAZR V3m Cellular
The RAZR v3m doesn't have a sim card. The arrow is showing how to insert a micro SD memory card.
Jul 24, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Installing a 2GB PNY Micro SD Card
Only the Sprint version of this phone supports memory cards over 1 Gigabyte. Sorry. But if you have a Sprint phone comment back to me using the comment box below. Thanks.
If you don't have a Sprint phone you need to acquire a 1GB card and use that. Hold on to your 2GB card as it will be usable when you upgrade at the end of your contract period.
Regards,
Worldvet
Jun 11, 2008 | Motorola Mobility RAZR V3
Where do you put the Micro SD card in a Motorola V3 Phone.
I know of a solution, but it is dangerous to your phone and it will probably void your warranty ifyou break it.
1) open the back of your razr, revealing the battery and the sim card.
2) do you see the small screws that hold the lower part of the phone on? there located on the edge of the phone.
3) unscrew these and take off the black casing that both holds your SIM card in place, and prevents you from putting in an SC card to your phones motherboard.
4) place the sd card onto the pannel of your motherboard, making sure that it fits properly.
5) put everything back together and your done, you now have a thrid storage device on your phone.
Feb 26, 2008 | Motorola Mobility RAZR V3
Location of SIM card in Motorola Razr
Are you guys serious....
Verizon & Alltel (which happened to recently finalize the merge) use CDMA. CDMA does not use SIM cards.
AT&T, T-Mobile, etc. use SIM cards - wheter they are 3G networks, TDMA, etc.
Jan 02, 2008 | Motorola Mobility RAZR V3c Cellular Phone
SD Card causing problems?
The V3m has an inherent flaw with the Sd Micro Memory Card. Installing the card, which fits extremely tight can damage the electrical contacts in the micro chip socket. This can result in low battery life due to a short to metal chassis of phone and not being able to communicate properly with memory chip. I had my first Razr V3m replaced by Sprint after only 2 days of ownership.When I got my new phone I carefully filed the tab on the Sd Micro Chip so insertion and extraction is much easier.
Nov 20, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Mobility RAZR V3m Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
