Normally if this happens the safety circuit of the TV may be activated. This is triggered by an internal problem. Start first with the common which is problems with the power supply circuit (the circuit right after the power chord). Check for leaking or swollen capacitors, burnt parts or loose parts or solders. If there are none there, you need to check the same items on the main board. If you find bad capacitors or burnt parts, take not of the label of the part as you would need to replace them with the same part.
The screen on your laptop goes black after every few seconds.
It resumes after a mouse-click or after a key-press.
Solution
Click on Start --> In search bar, type power options and press Enter.
"Select a power plan" window will be opened.
Click on "Change plan settings" next to "Balanced (recommended)".
In "Turn off the display", select "Never" from the drop-down menu under both the options "On battery" and "Plugged in".
Now click on "Save changes" button.
hope this helps
