Question about Sport & Outdoor - Others
I have pantera 90cc ATV, one minute it was running the next it died. it had plenty of gas in the tank, it is my first ATV so I do not know what to do. has spark. can you help?
Get a new one
Posted on Nov 06, 2010
I have a 2000 honda foreman that starts up for about 60seconds then dies.won't start back up.can you please help.
Need Help, Dies and won't re-start - Honda TRX Forums: Honda TRX ...
www.trx450r.org > ... > 450R Performance and Mods. > Engine
Mar 20, 2010 - But, it will warm up (still not hot!!!!) and die. Or when I'm riding. .... vent, if not, it is the petcock or clogged tank.... it only takes 60 seconds to perform this check. .... Then randomly it would start again the next day or something.Missing: 2000
engine starts and runs, then dies and won't restart - Honda ...www.hondaforeman.com > ... > Foreman 450May 16, 2011 - Hi all, I'm new to this forum, and new to 4 wheelers. I recently bought a 04 Foreman 450. It would start real easy, but smoked like crazy. So I put ...Need Help, Dies and won't re-start - Honda TRX Forums: Honda TRX ...www.trx450r.org > ... > 450R Performance and Mods. > EngineMar 20, 2010 - But, it will warm up (still not hot!!!!) and die. Or when I'm riding. ... Thanx to: Venom/KBR (Mixxer/Kam), Rage ATV (Dee), Sredum (Chris), and many ORG members .... the petcock or clogged tank.... it only takes 60 seconds to perform this check. .... Then randomly it would start again the next day or something.250x starts, runs for seconds then dies [Archive] - ATV Riders Forumwww.atvriders.com/vbb/archive/index.php/t-283850.htmlFeb 19, 2007 - 12 posts - ‎6 authorswell as the title states i have a 1988 honda trx250x atv, have had it for ... do the same five second run and die, while idling and quick reving up i ...How to fix a gas lawnmower that starts then dies - YouTube? 7:37https://www.youtube.com/watch?v=caa0WrpxqyUMay 3, 2011 - Uploaded by SmallEngineRepairGuyThis is a how to video on what to do if your gas mower starts up then dies after a couple ... How to fix a gas ...
Jan 06, 2016 | Honda Cars & Trucks
I have a 1998 Baja 90cc atv when I try to start it the motor cranks but won't turn over I tryed spraying engine start into the air intake but all it does it back fire threw the exhast and carb
Backfire indicates a timing issue. The timing chain keeps the valves closed when ignition fires. When the chain gets loose, it can jump one or more teeth on the sprocket and cause this problem.
May 10, 2015 | Cars & Trucks
Hey plz tel me why my xl110 dies on me every +- 1km wen i ride.then i hav2 runstart it again 2 reach my destination.i kick myself blue in da face bt no help.wen i just idle da bike;after a few minutes just...
Sounds like the gas tank isn't venting.
If air isn't allowed to enter the gas tank to replace the gas flowing out, vapor lock happens.
Next time it dies, remove gas cap and see if it starts quicker/easier, and runs longer.
If so, then you have a plugged vent.
Jan 16, 2014 | 2010 Vuka XL 125
300cc atv
check for a venting problem in the filler cap. Check for crimped fuel line . Check to see if there is a filter in the tank at the fuel line fitting.
Jul 29, 2013 | ATVs
My Polaris Sportsman 90 ATV has 70lbs of compression on the engine is that enough ? It does not start .
70lbs for a 90cc should be good, but 80-85 is better. Compression drops from piston rings wearing out, most of the time. Piston rings wear out from old oil...every time. Rule of Thumb: 5 tanks of gas, change your oil !!! It's not a car !!! A car has 5 quarts of oil which takes about 3 months to break down (2,000 miles or so), 90 cc engine has a half a quart, which takes about 3 weeks to break down (based on everyday use) SO...5 tanks of gas, change your oil..
as for the not starting thing, check for spark (should be a blue spark ONLY, any other, replace plug, orange won't ignite gas) if you haven't been riding for a while, open the drain screw on the bottom the carburetor and drain the water out. Ethanol turns to water when the gas sits too long...
Apr 09, 2010 | Polaris ATV
Gasoline in the airbox, muffler (2006 Suzuki Vinson ATV)
usually when the needle and seat are stuck, the gas will run out of an overflow on the side of the carb, unless those are plugged for some reason, then obviously the gas will flow where ever it can. is the machine 2 or 4 stroke?,
May 31, 2009 | Swisher Atv Tru Plow
2006 Arctic Cat ATV dies after about 15 minutes of riding
Sounds as if the gas tank is not breathing properly. The next time you run it, when it's about to die, loosen the gas cap. It should begin to run again. This is a sure sign that your gas cap is clogged. Clear gas cap of debris, or buy a new one.
Jim
May 30, 2009 | Swisher Atv Tru Plow
It Sounds like your Stator is going bad.
I would have it checked/Diagnosed by a Local Shop.
May 12, 2009 | Sport & Outdoor - Others
6yr old Craftsman Lawn Tractor - Koehler 18 HP Auto. Sputter&Dies
Try running it again and when it starts to die remove the gas cap and see if it starts to run better. It's possible that the gas tank isn't venting correctly. If that doesn't work post back and we'll try to come up with some other solutions.
Apr 22, 2009 | Craftsman Garden
Sport & Outdoor - Others Logo
717 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
