Question about Simer 1/6 Hp Submersible Utility Pump
Simer submersible utility pump Model 2300-03 motor sticks. Only pushing the impeller makes it to work. Is there a repair kit relating to this problem?
  • 317 Answers
Take screws off the screen on the bottom of pump.....clean well
Posted on Nov 17, 2009
How do I troubleshoot a Simer 3/4 hp submersible deep well pump
Check power at well head. then turn power off and disconnect wire nuts. check continuity on leads to motor should read about 500,000. Check each lead to ground for shorts.
Oct 14, 2014 | Simer 2873G Submersible 4" Well Pump,...
I have a Simer 2305 and the pump will run but does not when the water is low?
Pumps such as the Simer 2305 do not pump water totally down to ground level. They are designed so they do not suck up debris , sediment, etc, which can clog and ruin the pump. So if your pump leaves an inch or so of water, that is normal.
Mar 15, 2014 | Simer 2305 Geyser II 1-4 HP Submersible...
Brand new Simer pump Model 2330-03 runs 10 seconds shuts off, turns back on, runs 10 seconds shuts off, etc., etc. Why is this happening?
Sounds like a faulty switch on the float. Try to hold the switch up by hand and see if it stays running, if so you may need to lube the switch. If not then it sounds like a manufacturer defect and needs to be returned.
May 07, 2011 | Simer 1/6 Hp Submersible Utility Pump
Model 2305 pump. Housing is cracked. Can I buy
since the pumps cost is only about $40 i doubt that they make after market housings for it and i could not find any
Sep 25, 2009 | Simer 1/6 Hp Submersible Utility Pump
What kind of is used in a simer submersible
The Simer brand of submersible dewatering pumps rely on being fully submersed in water for proper cooling and for the seals to remain water tight and effective.
According to the manufacturer, there is no oil used in the pump, other than a very small amount that was used in assembling the pump at the factory, so you shouldn't oil the pump, but rather follow the recommendations as to making sure the pump is installed properly.
Here's the owners manual for your particular pump (Model #2300) so you can check the troubleshooting FAQ's and so you can also contact the manufacturer, should you need replacement parts or need to make a warranty claim, etc.
http://www.simerpumps.com/pdf/1000001370.pdf
Hope you find this Very Helpful and best regards!
Sep 17, 2009 | Simer Plumbing
I have an Simer pedestal pump and the part that connects to the impeller from the motor is broken. I can not find a repair part or part #. Can you help me? THX
there is no repair parts all you can do is change the pump,, go with a submersable zoeller pump best on the market for the price aprox 100,
Mar 15, 2009 | Flotec 1/3 Horsepower Economy Pedestal...
Simer 1/6 Hp Submersible Utility Pump Logo
460 people viewed this question
Top Simer Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Simer Garden Expert? Answer questions, earn points and help others
