Question about Jenn-Air JCD2389G Side by Side Refrigerator
Fridge freezer door ice maker
I have a problem with a JENN_AIR model JC2228GEHB fridge freezer with door ice maker, the ice making tray will not fill with water, the water solenoid tests ok,can you advise on what controls the solenoid or any other possible causes
  • GUNNO Jan 09, 2008
    water does dispenses from door, ice making tray will not fill
  • Anonymous Mar 15, 2014
    Jennair French door bottom freezer disengage ice maker
    President:
  • 1,314 Answers
The ice maker controls the seloniod the icemaker wire arm must be all the way down .just because the seloniod test good doesnt mean the valve seat isnt stuck the water valves open by your house water pressure if your filter is dirty this can also lower the pressure if the icemaker module is bad this also can cause it if you pull the front of the ice-maker off you will se a bunch of holes if you get a piece of 10 Gage house strip about 1/4 inch off either side and insert it into the holes marked t and h that will test cycle the ice maker they will be close together don't get shocked if the ice maker cycles and doesnt fill and the ice maker fill tube isn't frozen replace the water valve if the ice-maker doesn't cycle replace the brown motor module
Posted on Jan 09, 2008
The ice tray is not producing ice and we have the handle up. I think the ice makeer has frozen itself over. Can the ice make be removed or thawed out without unplugging the whole fridge?
the handle needs to be in the down posit. ans if up it shuts the ice maker off. .. you can defrost the ice mker with a turkey baster & hot water . use towel under icemker .. mm
Aug 10, 2010 | Jenn-Air JFC2089HP Bottom Freezer French...
I have a Jenn-Air Refig with the freezer on the bottom. The ICE maker is not working and I think it might be frozen. How do I disconnect the ice maker so i can thaw it out?
Why not do a quick thaw and move the frozen goods over to the firdge for a few minutes and grab a blow dryer. This should give a temporary fix until you can pin point the problem. Be kind to me please with a Thumbs up. I am a long ways away and can only help a little. Raz
Apr 09, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jen Aire Fridge ice maker fingers are below the
This one you have to take out the ice maker and run hot water from the kitchen sink into the tray to get the ice out. need model number if you want detail explaination how to. or just use a hair dryer that will work to!!! if fingers dont rotate after defrost ice then the gears are stripped, replace ice maker
Mar 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Water is leaking out the bottom of my brand new Jenn Air French door model JFC 2089 HE. Why?
likely a lot of condensate has been collecting in the catch tray, and it hasn't been able to evaporate off. You may have to slide the fridge out, and empty the tray by hand.
Nov 02, 2009 | Jenn-Air JFC2089HE French Door...
4 year old jenn-air refrigerator not making ice
first please check you water delivery chanel behiend icemaker, it may freeze up... second you water valve on bottom part on the back is duel( one valve for water dispencer and another one for ice maker) you have to check if it is a power going to that icemaker valve, unplug icemaker inside freezer and plug back now check for power but you have acting fast, ask somebody for help... and third it could be icemaker it self... good luck for additional questions please totalcarefl@yahoo.com
Sep 09, 2009 | Jenn-Air JCD2295HES Side by Side...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
ICE MAKER MOTOR RUNS CONSTANTLY AND WONT' TURN OFF ICE IS FULL
It's not too difficult to remove the ice maker. A few screws and the unit will unplug from the fridge. Then you can see why the bar is not turning it off. If it's really broken, check pcappliance.com for parts or a replacement unit. Meanwhile the fridge can keep on working, and you can use trays to make ice.
May 03, 2009 | Jenn-Air Freezers
Q: Does the water for the ice maker go thru the in-fridge filter?
the water should go thru the filter first then to everything else.
Jan 02, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
205 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
