Question about Nintendo Wii Console
Cant get signal for menu to operate on wii
Tried sensor and controllers on another wii they worked new batteries installed into controller will i need to buy a new sensor or could it be the connections to the tv
    Problem Solver:
  • 11 Answers
Make sure the thing is plugged in the back and try the wii seettings and give me a good rating please
Posted on Nov 16, 2009
Daughter put wii controllers in a cup of water, took them out right away, the buttons work but the sensor isnt working well
Hi:
If the unit had batteries in the unit then major electronics came in contact with the water, seems the IR transmiter in the controller or the chip that controls the units operating mode has shorted and the unit is not sending signals to the IR receiver on the main wii console, at which point I would just purchase a new controler, another option you might try is opening the controller and cleaning out any residue that the water may of left behind.
Apr 27, 2011 | Nintendo Wii Remote Controller
Wii controller is not working, no lights at all coming on
Try this following steps: 1. Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen. 2. Make sure you are using fresh batteries in the Wii Remote. 3. The Wii Remote Controller should be used between 3 to 10 feet from the TV. 4. Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote. 5. Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves. 6. Radio frequency interference may cause the Wii Remote to work erratically.
Mar 30, 2011 | Nintendo Wii Remote Controller
Wii controlers won't respond
If the Wii will turn on and display the menu, then I would say try replacing the Wii controller batteries first. If after you replace the batteries and it is still not working, the next best thing to do is make sure the sensor bar is correctly plugged into the console. If it is correctly plugged in, then it may need to be replaced.
Mar 29, 2011 | Nintendo Wii Console
We have a Nintendo Wii and no the remote controls aren't working with the console. Ihave tried replacing batteries. Do I need new remote controls or a new charger for the controls?
If your remotes are showing power lights at the bottom when you press buttons, then you may have a problem with the sensor bar that receives signals from the remotes.
First, try unplugging and plugging back in the sensor bar to the Wii. If it still doesn't work, the next step would be to replace the sensor bar. You can find them just about anywhere you buy Wii accessories and they are fairly cheap.
Mar 02, 2011 | Nintendo Wii Console
My son was playing his wii and set down the controlers for about ten minutes came back to his game and its like it cant see the signal. I dont know what happened or how to fix it. I have tried unplugging...
Your Wii controller has a power saver function built into to turn off the controller and save battery life. If it's not recognizing the controller, try rebooting the Wii. If that doesn't work then your Wii controller needs to b re-synced.
http://www.ehow.com/how_2144692_sync-wii-remote-controller.html
If it's not powering up at all then the batteries need to be replaced.
Jan 06, 2011 | Nintendo Wii Console
Controllers will not work ,have tried new batteries no change
The problem might be the Wii Sensor bar or it could be something else blocking the signal but it's very unlikely. Try using someone else's Sensor bar if they have one and if that works then all you need to do is go out and buy a new one they usually cost about £15 ($23) so I hope this helps.
Apr 16, 2010 | Nintendo Wii Console
My wii controlls will not work
Check to see if the sensor bar is connected to the Wii. Use fresh batteries...they die suddenly.
Dec 26, 2009 | Nintendo Wii Console
Wii Controller
ok well there is a little compartment on the face of the wii that you have to open and it should reveal a red button which will set the wii to pick up any signals from a wiimote but to get the signal from the wiimote you need to open the compartment where the batteries go and there should be another red button you have to press and hold both the buttons at the same time and they should pick up each others signals.
Jul 30, 2008 | Nintendo Wii Console
Wii remote
Hey did you try holding the red button where you put the batteries and holding the red button where you put the SD card all unit have an button so it can read the sensor from unit to controller....
Jun 21, 2008 | Nintendo Wii Console
Nintendo Controller Will Only Work on Menu with Classic Controller
well iv had this problem it could be the remote you might have to buy a new thts what happened with my brand new remote for it or it could be that it has crapy batteries
Mar 01, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
42 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
