Question about Acer Aspire 5735-6694 Notebook
How do you use laptop with bluetooth mobile phone
How to activate bluetooth
How to Use the Bluetooth in the Gateway Laptop
ou may have bought a new Bluetooth-capable device like a Bluetooth mobile phone, and may want to load some ringtones or media files that you have stored on your Gateway laptop. This might be the first time you are ever attempting to communicate with a Bluetooth device using your laptop. Normally, Bluetooth has to be enabled on both the devices attempting to communicate. It is no good if Bluetooth is enabled on only one of the devices. All attempts at communicating via Bluetooth will fail. However, if Bluetooth is enabled on both the devices, bringing the two in close proximity is enough for the devices to detect each other. While this is what should happen and it happens most of the time, sometimes the devices need a helping hand. Here's where you come in.
Instructions
1Enable Bluetooth on the mobile phone. This procedure is dependent on the make and model of the mobile phone. You need to see the user manual accompanying your mobile phone to see how to enable Bluetooth.
2Turn on your Gateway Laptop. Check the area next to the clock in the System Tray. There should be an icon with a stylized "B" on a blue background. This is the Bluetooth icon. Double-click on this icon and select "Enable."
3Go to Control Panel. Locate "Bluetooth Configuration" and double-click on it. A window should pop up.
4Select the Accessibility tab. Check the option "Let other Bluetooth devices discover this computer." A check mark should appear against this entry.
5Select the Local Services tab. Startup type for all services should be set to "Auto."Select "OK" and click. Wait for a few seconds. Your laptop should have Bluetooth enabled by now.
Tips & Warnings
If your laptop does not detect the mobile phone even now, turn off the phone and turn it on again while keeping it close to the laptop.
Jan 07, 2012 | Gateway MD7820U (L-LX.W730X.007) PC...
I have S5350 model mobile, how can i transfer photos from mobile to my laptop?
Try to connect it in bluetooth connection. (Wireless connection.). Or try to connect your phone in USB connection. (Wired connection) For wireless connection:
-open your first your bluetooth connection. (phone and laptop) -send the the files/photos via bluetooth connection. -accept the files from your laptop.
For wired connection: -connect your usb to your phone -set your phone connection to mass storage -connect to your laptop, if your laptop detect your phone, search your files, then copy it.. =)
May 21, 2011 | Cameras
Hi, My Samsung mobile is GT-C3303. I have problems in connecting to the bluetooth device on my laptop machine to transfer the music files. I have tried both 0000 and 9999 and 1234 but nothing is helping...
you have to pair your samsung phone to your laptop first before you can start sending and receiving files through bluetooth.
an option is, turn the bluetooth on your laptop on, then the bluetooth of your mobile phone on. on your phone, search for devices, then once you see the name of the bluetooth device of your laptop, tap it then choose connect or pair, you will be asked for a passkey (you can input anything try 0) or in some devices wait until a pop screen appears which will contain the passkey usually 5 to 6 digits. then click ok
another option is (i tried this using my samsung corby wifi and a samsung n150 laptop and it works just fine) make sure that the bluetooth on your laptop and phorne is turned on. on your laptop click on the bluetooth icon or click the file you want to send, then right click, then choose send to bluetooth, your laptop will then search for available devices, just choose your mobile phone then automatically there is a popscreen which has a passkey, then click ok. on your phone you will be asked to allow to connect thru the laptop, just click ok, then make sure that the passkey matches between your phone and laptop. (usually it is automatic, you just need to click ok) you should be able to send and receive files thru bluetooth on your phone and laptop
Apr 20, 2011 | Samsung Star GT-S5233 Cell Phone
Want to know how I can listen to my music through my bluetooth
bluetooth is a type of wireless connectivity between supported devices. you can share music files with other mobile users through bluetooth , and you may use a bluetooth wireless headset to listen to the music files being played through your bluetooth enabled systems such as laptop and may also be supported by yuor phone.
Jan 17, 2011 | Cell Phones
How do I connect my phone to my laptop using bluetooth. I have a usb cable but do not seem to get either to recognise each other
You should switch on your bluetooth on on both your laptop as well as mobile. Then you have to open the configuration of bluetooth settings on your laptop.And then search for a new device in which your mobile will be recognized and then you can select your mobile phone to transfer and do anything you want
Dec 19, 2010 | Motorola Mobility RAZR V3
I want to connect my mobile phone to my accer through bluetooth
install the bluetooth software on your laptop bro and configured it.
Sep 15, 2009 | Acer Aspire 5315 Notebook
Bluetooth conection
Make sure You have a Bluetooth device on your laptop[of course that is necessary].Now i recommend you to use WIDCOM bluetooth software.It is theeee best for bluetooth device handling.
Also make sure that the bluetooth device on your samsung blackjack is working.That can be done by asking your friend having a bluetooth enable phone to search for your mobile via bluetooth,be sure you turn on your bluetooth device on your mobile and make it visible to others.
Make sure after intalling the software (WIDCOM) the drivers are successfully intalled.Then pair it with your mobile.So simple isn't it
Please rate me my name is Karatela
Dec 01, 2007 | Toshiba Satellite A105 Notebook
Files from my phone to acer laptop
Most acer laptops have the bluetooth front button but very few have it installed. No device means yours is not bluetooth enabled and you will have to purchase a usb bluetooth adapter, class 1 being a 10 metre distance connection, class 2 being a 30 metre connection distance.
Apr 19, 2007 | Zoom BLUE TOOTH USB WLS ADPT- CLASS1...
Acer Aspire 5735-6694 Notebook Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
