Question about KitchenAid Dishwashers
Whirlpool dishwasher DU945PWPQ0 stuck on ''light load''
A Whirlpool dishwasher model DU945PWPQ0 is stuck on a ''light load''. Nothing else can be selected. Otherwise works fine.
5 Suggested Answers
SOURCE: Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Posted on Feb 19, 2009
  • 423 Answers
SOURCE: whirlpool dishwasher du945PWPQ0 won't run, no led lights
If you have used a meter to check that the power circuit is live clear to the connection under the dishwasher then:
It is ~possible~ that (even though it is hard wired) a tripped GFI outlet in the kitchen has tripped and opened the circuit that this diswasher is connected to. Locate all GFI outlets in the house and reset them.
Seperate from that, you have a failed diswasher on your hands. If you have an extended waranty, well done. Otherwise, you need to decide between repair and replacement.
Posted on Mar 28, 2009
SOURCE: Whirlpool model KUDSO1FL not starting cleaning
I fixed the problem by hitting Hi-Scrub then Economy Dry in sequence four times in a row. All of the lights came on, I am assuming to reset it the program, then went off and the start button was highlighted. I then pressed cancel and then selected the program that I wanted to wash with and pressed start. It worked like a charm.
Posted on Feb 02, 2010
  • 1010 Answers
Before you do anything, please make it sure you have power at the machine. Remove the front cover plate, (you do not need pull out the dishwasher.)
On the right side is the connection, where the wire comes in. Check if you have power there. If you have check the door latch (inside the door)
Posted on Mar 10, 2013
Du945pwpq0
Check and see if your aloud to use loc-tite sealant.
May 31, 2012 | Whirlpool Dishwashers
Was running and stopped now does nothing
does it mean the lights are all out and the buttons when pressed do nothing.
have you checked if the mains fuse or circuit breaker is not tripped.
Jul 20, 2011 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Dishwasher clean light is blinking
indicates a problem with dw not heating the water. various causes. dw should be thoroughly checked, if nothing found wrong, reset computer
Jan 03, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool Dishwasher Stuck in Cycle
Hello FishNYC22, we're sorry to hear about your Dishwasher. Unfortunately we are not able to provide technical assistance. If you would like for us to schedule service for you then please email us your name, phone number, address, the model and serial number and the website you were contacted on (Fixya.com) to Whirlpool_Digital@Whirlpool.com.
May 09, 2017 | Whirlpool DU806CWDB Dishwasher
Whirlpool dishwasher du945PWPQ0 won't run, no led lights
Mar 18, 2009 | Whirlpool 24 in. DU948PWPQ Built-in...
Kenmore Model 587 -- Will not run - Power lights come on/wontrun
Hello I am V- Mari and i own a Kenmore dishwasher model Number 587.1574590 and it doesn't work at all. The power light comes on and it seems to make noise, but it does nothing. Is there a recall for these models or free fix help please respond to miss_vmari@netzero.net. I would like to solve my dishwasher problems as soon as possible. Thank you!
Dec 12, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kitchenaid dishwasher will not start
sounds like theres something stuck in the drain pump.hope this helps.
Mar 05, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
121 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
