I have a Toshiba TV Mod 30HF85C, Chassis M3SAT. The buttons on the TV work but the remote will not operate the TV. Have you any suggestions Dale Lambert D & D Electronics
  • dianne42 Nov 16, 2009
    We are a repair depot and have this TV in for repair. We have tried a new remote and have replaced the receiver remote sensor. Have you had any other problems similar to this for this model. Could it be out of frequency. Thanks.
  • 350 Answers
The remote sensor or the remote itself may be bad. The cheapest and easiest solution to try:
I would just get a universal remote and program it for the TV with the code they provide. You can pick one up for around $10 at practically any store. Walmart and Kmart seem to be the cheapest. A factory replacement remote is a rip off.
I hope this helps and good luck!
Posted on Nov 16, 2009
  • CURT
    CURT Nov 16, 2009
    This has worked in the past with infrequent results, but it is worth a try. Remove the batteries from the remote, and go through each button and hold them down for about 2 seconds. If not and the remote sensor has been replaced you will need to make sure there is 5 volts
    on the sensor b+ line and that it is clean and has no AC in it or any
    noise. You will also need to trace the data line and make sure you
    have a good strong data signal comming out of the sensor all the way to
    the microprocessor.
    If the signal is good all the way to the micro, then replace the
    microprocessor. All these checks cannot be made with a meter. They
    must be made with an oscilloscope. Good Luck!
Need a remote control for a Toshiba TV/DVD Combo model MD9DM3
please I have a tv / dvd toshiba mod conbination md9dm3
no remote and I know that reference is to see if I get it or if I recommend a universal serve me
thanks carlos mymail is:
delaroche53@hotmail.com
Oct 16, 2010 | Toshiba MD9DM3 9 in. TV/DVD Combo
My remote will not work anymore.would stop every once in a while now not at all. Put new batteries in it and nothing in the way. My cable remote will not work as far as volume and power. Is it the remote...
Your need to replace the TV remote receiver. PN: 72795949. It will be located in the front of the chassis along and the control button board. This part is about $1. If you need a basic soldering tutorial, I have one in my Tips & Tricks. I hope this helps.
Mar 17, 2010 | Toshiba MW20FN3 20 in. TV/VCR/DVD Combo
Front buttons on TV no longer work or thr remote control
Double check the wire plugs from where they connect to the front keyboard panel and the main chassis
Jun 18, 2009 | Toshiba TP61G90 61" Rear Projection...
Need Toshiba remote access code for this product so I can use a universal remote to operate the VCR and DVD
remote codes are set by the manufacurer of the remote not the tv. if there are any others not listed in instructions for remote, the manufacturer of remote would have them. most combo unit are not able to be programmed into universal remotes due to the fact that there are alot of specialized function buttons on original remote. you can obtain a replacement remote thru toshiba
May 16, 2009 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
THE MENUE KEEPS POPPING UP WATCHING TV.
remote is bugged out has water damage!try unplugging batteries in remote for test!
Feb 26, 2009 | E-Machines eMachines Desktop PC
I can not get any remote to work on my toshiba 32a33 t.v.
Hi, I have same problem with olderToshiba 1999, Model CE27T11. I learned that a spider web, a bug dropping - live in Florida, or just plain dust can interfere with operation. Right now I am trying to disassemble the chassis, I have half of it off, but wires are holding it to the tube assembly. I took all the screws off, popped the back off, and now am at a standstill. The "dust" is interferring with the signal... to & from the remote. So I have been told...
I intend to vacuum it, and dust with micro fiber cloth, once I get it apart, the key is to not break any solders, so try not to blow the dust off, as this can break the solder. I too have tried a new Toshiba remote, a universal remote, and rebuilt and cleaned the old one. It is frustrating when it quits working and you cannot get it to work, no matter what you do.
Feb 20, 2009 | Toshiba 32A33 32" TV
Wharfedale lcd2010a
The TV is Manufactured by a company called Vestel in Turkey and will operate on the AK45 chassis remote control,if you try the codes for Bush or Alba one will operate it nut not of course menu functions but no problem there is a menu button on the side of the set.
audiovservices@fsmail.net
Apr 18, 2008 | Televison & Video
Can't get cable remote to operate GE 19TVR62
I found these remotes control VCR's only when programmed into the DVD button. It even says on page one of the manual that the DVD button is for DVD's, TV/VCR's, VCR's, etc. I got code 607 to control my GE VCR (using the DVD button). If that doesn't work, try 572 647 563 609 644 645 or 531.
Dec 11, 2007 | GE 19TVR62 19 in. TV/VCR Combo
Volume Issues with Television
toshiba 35a44 I had in shop would not turn on initially,when Qa01 was replaced I was able to turn tv on, but after a couple of minutes volume went all the way down, vol display bar on screen and power and menu keys would not work, remote control function did not mater. after replacement of QA02 mpu no results. desoldered volume down and up keys and sprayed chassis with flux remover on both sides of chassis and sumerged vol keys in alcohol solutions for 10 minutes, restored them in chassis and the problem was corrected. QA01 and QA02 did not had to be replaced there was a contaminant problem on solder flux that was causing the problem. kbzon
May 11, 2007 | Toshiba 35A44 35" TV
Televison & Video Logo
Top Televison & Video Experts
