Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
WD640 Hi, My WD640 is not letting out water. Can this be repaired and if so how?
  • Hotpoint Master
  • 3,463 Answers
Turn off water supply to inlet valve, and disconnect the hose at the inlet valve.Get a bowl or bucket, and put hose in to same.
Turn on water valve, and water should flow in to bucket.
If it doers not, then thye prob is with the supply.
If it does flow o/k, then prob is in the washer.
Could be faulty valve, or the valve is not getting a mains supply., \check for blocked inlet valve filter.
Please rate my solution.
Thanks.
Posted on Nov 16, 2009
My hotpoint aquarius washing machine wont pump out the water
HI.
You need to check the pump filter.
Remove lower rear panel of washer.
Remove large black hose fastehed to bottom of drum
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Check drain out let hose is not blocked.
Please rate my solution/.
Thankyou.
Jan 28, 2010 | Hotpoint Aquarius WD640 Front Load...
WD640 aquarius super silent won't spin or drain
hi there......most likley cause is a blocked or defective drain pump....if the water cannot get out of your machine due to the faults above it wont rinse drain or spin
regards Sir Galahad
Aug 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Nov 23, 2008 | Hotpoint Aquarius WD640 Front Load...
H20 errors on Hotpoint WD640
this is normally a water valve problem
Jun 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Fabric conditioner drawer full of water!
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 24, 2008 | Hotpoint Aquarius WD640 Front Load...
Test display
hi there let your machine do the compleat test cycle again then when it gets to the end press and hold the start/cancel button and the on/off button at the same time for at least ten seconds.
hope this is of some help
Dec 14, 2007 | Hotpoint Aquarius WD640 Front Load...
Display panel
Check to see if any water remains in the machine . SOME MACHINES IF They DO NOT DRAIN OUT ALL THE WATER WILL CONTINUE TO run until all water is drained. Also check for suds in machine if machine senses suds it will try to re rinse the clothes.If your machine has a filter at the bottom clean it out .
Oct 09, 2007 | Hotpoint Aquarius WD640 Front Load...
No draining of water
poss blocked hose or debris in pump.
May 29, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
96 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
