Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Valve clearances for jd la valve adjustment only John Deere Tractor Model L A doesn't cut it with this web site so that is the reason for this approach
  • rsmyshrall Nov 17, 2009
    It's a john deere made tractor in their own facilites two cyl upright flat head, valves in block. The model is LA made from 1941 to 1947.It is not a lawn mower type tractor, it is a normal farn tractor
  • Bill
    Bill May 11, 2010
    Briggs twin or single?
0.08mm-0.13 mm- intake top 0.13mm-0.18mm- exhaust bottom
Posted on Nov 17, 2009
Compression in a 1966 john deere tractor its a 2020
is this a multi cylinder diesel farm tractor or what
remember that questions go global and you have to be specific in details as a jd unit 202 in your country may be a 1212 or what ever in another country
however moving on , if it has more than 2 cylinders , the problem can be a head gasket blown between adjacent cylinders , cracked head or valve problem ( burnt or incorrect valve adjustment)
same ideas apply to petrol engines as well
Dec 15, 2015 | John Deere Garden
Im after a manual for a john deere 2300 modal
Most JD manuals are at their site.
Dec 16, 2014 | John Deere Garden
How do you change the drive belt on a john deere d110 riding lawn mower?
You can look at the manuel that came with the mower or if you did not get one, go to the JD mower web site and look up you model and download the needed documentation. If that is not possible contact the local JD mower dealer and get a copy of the mower deck docs and look at the instructions for belt replacement.
Jul 31, 2014 | John Deere Riding Lawn Mower. D110 42 in....
JD Model 445 - Plastic gears. After replacing the new camshaft I need to adjust the valves. Does anyone have the specifications?
Remove the plugs. Turn the engine so the pistion is at top dead center for cylinder. Clearance should 0.010 when adjusting rocker to valve. Repeat for other side. I just replaced my cam shaft if a 1993 JD445. I'm planning to run for a couple of hours then check cleanace again. Hope this helps, Gerry
Jul 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
JOHN DEERE TRACTOR - MODEL A - SERIAL 642202 CLUTCH REPAIR
Try the John Deere web site, I think they will be able to help. donnyb60
Mar 21, 2009 | John Deere Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
470 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
