Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
1974 John Deere 2030 diesel tractor and the engine dies
I have a 1974 John Deere 2030 diesel tractor and the engine dies after running a couple of minutes. I've had the fuel pump rebuilt, but still having the problem. It starts runs great for a couple of minutes and dies like you've turned the switch off. Let it set a couple of minutes and it'll start and run another minute or so and it'll die again. Any help would be greatly appreciated.
  • Anonymous Mar 14, 2014
    Engine will turn but not start
    Engine will turn over but not start what could the problem be.
    Problem Solver:
  • 17 Answers
I will assume you have bled the fuel system per the owners manual to ensure no air lock in your system. This is especially critical after replacing the injector pump.
The next step is to ensure you fuel filters are good and flowing and last but probably the problem is the screen on the petcock (fuel shut off) in the fuel tank. Remove this shutoff valve and clean the screen with a fine wire brush and carburetor cleaner.
Posted on Nov 17, 2009
I have a 1996 John Deere 455 diesel It started running only 20 minutes before it dies for no apparent reason. After about 10 minutes it will pop right off again. The engine runs strong, no hesitation
The fuel injection pump has a fuel supply from the fuel filter and a fuel return line from the fuel injections to the fuel tank. This fuel return line is kinked or restricted in some way . Repair fuel return line and it will run. Check return line and fitting on injection pump also. If it is an electrical problem it is most likely the operator presense switch in the seat overheating and loosing connection then cooling off after a few minutes.. Check it out.
Jan 03, 2017 | John Deere Garden
What makes 2030 diesel engine fire
injector pump right behind the alternator shaft driven off the front crankshaft ? why?
Nov 11, 2013 | John Deere Tractor Side Screen...
John Deere L120 runs for 15 minutes, bogs down and dies. A few minutes later starts right up, runs for a few minutes and dies again. I have changed the fuel filter, all fuel lines, air filter, cleaned the...
Is this an older machine ? If so try finding the points its usualy on the front lower part of the engine behind the cover, if you see that then it needs its condensor replaced, lookes like a round battery.
If this is newer or you can also try changing the spark plug sometimes they heat up and fail.
Sep 17, 2012 | John Deere Garden
I ran my john deere 790 out of fuel.how do i restart
With diesel, sometimes you have to bleed air out before it will run again. Typically you disconnect the fuel line going to the injector pump, manually activate the fuel pump, or turn over until fuel comes out, then release one or more of the injectors, and turn engine over again. Normally that bleeds enough to start and then the rest of the air gets pushed through.
Feb 13, 2011 | John Deere 4020 Gas & Diesel Tractor...
John deere 2140 had gas put in it instead of diesal what going to happen
Don't run it until you've completely drained and flushed and refilled the fuel system, tank, lines, pump...
Don't run it! Diesel fuel is more of an oil whereas gas is more volitile... Avoid starting or running to prevent any damage to your engine!
Jun 11, 2010 | John Deere 4020 Gas & Diesel Tractor...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
I have diesel in my oil on my 2030 john deere tractor
it can be one of three problems fuel pump leaking injectoin pump or a injector over fueling
Apr 03, 2010 | John Deere Tractor Side Screen...
John Deere LA145 B&S 22Horsepower engine starting and running
You may simply need a new fuel cap,vacuum in the tank will rob your fuel and stall it engine,try taking off the fuel cap and see how it runs.If this does not help you may need a new fuel pump,which runs off of crank case pressure and should take over from the choke once the tractor has started.
Jan 19, 2010 | John Deere 420,1020,2010,2020,2510,2520...
The engine runs and then stops after running. I wait and then it starts and runs again for about 1 minute and then stops again.
I have a old 2010 Diesel did the same. It was the fuel return line from the pump to the fuel tank. It's a short ? 10" long line.
Replaced it, now it runs for ever.
Barry
Jul 12, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
1,245 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
