Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100, power light orange
For the last three months I have had a recurring problem with my dell dimension 5100 desktop pc. When I turn it on it does not go through the standard sequence of green lights(numbers and HD symbol). The power light is just orange, no beeps or clicks. I have checked all of the connections to the computer and also inside the computer, they are all fine. I have been on to Dell customer support and they have gone through everything I have done and still no joy. In the end I just plugged everything out and left it for 3 days. When I connected it all back up, it booted correctly with no problems. It will work for a little while and then the problem occurs again. Again plug it out for a couple of days and I can get it working again. I would be grateful if anybody would have an idea what could be the problem here.
    Sergeant:
    Champion:
  • 317 Answers
Sounds like either a faulty cable or a bad motherboard, call dell again and tell them to send a technician out to look at it, they might be able to narrow down the cause of this problem.
Posted on Jan 09, 2008
I have found this kind of problem to be related to one of two things. It will be either the power supply or the motherboard.
Test points to try would be...
Power supply:
When the issue occurs, unplug the power cord from the computer and look for the red toggle switch (it will have 115/230 in white lettering) on the back of the power supply. Toggle this back and forth a couple of times making sure that it is PUT BACK TO THE 115 setting before plugging in and turning on again!!!!!!!!! Plug the power cord back in and if it starts up immediately, the power supply is going bad. This is only a temporary fix as it will quit completely in a rather short time.
Motherboard:
Shut the machine down, unplug the power cord from the computer, open the case and inspect EVERY CAPACITOR on the motherboard. Capacitors are the little round pieces with with a silver top stamped with a letter (T, K, X. Y etc..). Look for ones that are buldging or oozing. It will look like a battery that has gone bad with corrosion. Should you find a capacitor like that you should be able to call Dell and have them replace the motherboard even if it is out of warranty.
One thing to note would be, if your issue happens to be bad capacitors, your machine will just shut down as if someone unplugged your computer without warning. When you start it back up again you should get an error saying your "System was shutdown due to a thermal event". This is the classic tell tale sign of bad capacitors.
Unfortunately either way you will end up having to call Dell for a replacement part of a power supply or a motherboard. Hope for the latter because if it is a capacitor problem, Dell should replace it for free. Plus the motherboard is one of the more costly expenses of computer repair.
Good luck.
Posted on Jan 27, 2008
6ya staff
SOURCE:
1st, my desktop (dell Dimension 5100) had been not used for several months. When turned on, the green error code lights 3, 4 and a flashing battery appeared, along with a beeping noise. I read up on the...
I assume your new computer has IDE controller on the motherboard.
Yes you can install your old hard drive into your new computer as a Slave hard drive.
If the old hard drive is installed on the 2nd IDE controller and it is the only device on the controller then the jumper and be master or slave, but connect the hard drive at the last connector on the IDE cable.
Oct 18, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Unable to turn off computer except at the strip
is important update perfoming, or virus Malware spreding (trying to acess bios)
Jul 11, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100 - usb ports on motherboard are broken
Flashing Amber is normally power supply
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
The USB ports are part of the motherboard
Jun 08, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Need to purchase recovery disk for pc desktop DELL DIMENSION 4550
You can do it two ways:
1) call Dell and order a recovery CD--their contact info is on dell.com
or
2) use a regular Windows CD and install the system using the product number affixed to the case. Then go to Dell at support.dell.com to download the needed drivers.
Oct 08, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 - Will not turn on
open cpu cabinet.
Reattach ATX power supply connection to motherbord. ATX from SMPS to motherbord.
then check if it still not power ojn then clear cmos.
Pul away your cmos cell for 15 minutes from motherbord then check .
ALso change cmos cell if it is old.
Jun 26, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
I have a Dell Dimension 5100 Desktop that will not turn on.
hi...try to open side cover then find the memory then pull out and clean the pin connectors using Paper Eraser only..thanks...
May 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Hard Drive Upgrade on Dell Dimention 5100 Desktop
are you replacing it, or simply adding one to your desktop?
best place to get that information is www.dell.com
click on accessories
Feb 27, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
1,063 people viewed this question
Ekse
Clive
Clive
Alun Cox
