Question about Nokia N95 Cellular Phone
I can't enter my lock code. i'm using N95. help!
I can't enter my lock code. i have removed my sim and memory cards. i have repeatedly entered my 5-digit lock code but it does not work. i've tried switching the phone on and off but it doesn't work. HELP! Thanks!
Forgot phone lock code for GT-S5233S
Unlock Code
#*7337#
Entering Code instructions
1. Take out the SIM card from the phone and switch the phone on.
2. Enter the unlock code into your handset.
3. Now replace your SIM card and turn the phone on.
4. Your handset should now be unlocked.
Alternative Solution if the above fails
Unlock Codes
Code 1: *7465625*28782#
Code 2: *7465625*28638#
1. Remove SIM Card from handset
2. Enter Code 1 into the handset
(Your handset will display "auto subset lock activated")
3. Enter Code 2 into the handset
a) Enter an alternative network SIM card into your Samsung and reboot.
cool.gif The new network should be displayed in handset window.
c) If the process is repeated with yet another alternative network SIM card,
you may be requested to input a security or pin code to enable the use of
the new SIM card.
d) Enter 00000000 (8 zeros) which should enable the SIM to be accepted.
e) Finally once again enter 00000000 (8 zeros) and this should permanently
unlock the Samsung.
Final alternative Solution if the above fails
Unlock Code
#7465625*638*7337#
Jan 19, 2013 | Samsung Star GT-S5233 Cell Phone
How to know my pin code of my nokia N95???what are the procedure???
Hello m_cjharold,
With regard to PIN Code, it is the code of your SIM card. (example: AT&T, Cingular, Vodafone, Globe, Smart etc.)
If ever you have no idea what it is or if you forgot it, you can contact your service provider for the PUK code wherein you can enter once you used all the chances to enter the PIN Code.
To make sure, if your N95 is unlocked, meaning you can use different SIM Card, try using another SIM card and it should work fine. However, if it asked for Phone Code, it means you need the Security Code of the Nokia N95 not the PIN Code.
I hope this was helpful.
Thank you,
Jack
Feb 17, 2011 | Nokia N95 Cellular Phone
I need a puk code for my nokia n95 phone. I am
PUK is not your phones code. its the sim code. if you enter three times wrong PIN number then the sim asks u for a PUK to unlock the sim card. if u enter 10 times wrong PUK code then your sim will get corrupted and u cant be use that sim anymore. to solve this problem. you have to contact the sim vendor or customer care to retrieve the code from them. u have to give 16 digit sim no: while they ask for conformation. after getting the PUK no. keep that Number in safe place for future use.....
Nov 05, 2009 | Nokia N95 Cellular Phone
I forgot my security code n95
after months without my n95 and hours of scannin the internet i have found the solution to the lock code!!!! if u hav totaly 4goten the code u will need to flash the fone but...... if like me you are 100% sure the code u keep entering is correct then here is how to fix it!!! when changing your code u would have enterd a 6 digit code and re-enterd it to make sure it is correct yes? all went fine! wen entering it again it faild? thats where the problem lies. enter only the the 1st 5 digits of ur code and all should be fine!! if this fails turn off ur n95. press and hold the green key, the # key and the 3 key all at the same time as turning the fone on. keep them held untill the the lock code needs to b enterd. then repeat the 5 digits of ur code. unfortunatly u will loose contacts and msgs etc but it works! have fun!
Jun 19, 2008 | Nokia N95 Cellular Phone
I 4got my n95 pone code
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
"Confucius he say...Man who walk thru airport turnstile sideways going to Bangkok."
Apr 09, 2008 | Nokia N95 Cellular Phone
Unlock Nokia N95 8GB
plz give nokia n95 master cod
Apr 05, 2008 | Nokia N95 Cellular Phone
Forgot lock code nokia n73
i lost my lock code how to clear it
Mar 27, 2008 | Nokia N73 Cellular Phone
Mobile hasbben lock
hi, i need the code to unlock my nokia n95 8gb ,so i can use it on other networks, many thanks
Feb 25, 2008 | Nokia N95 Cellular Phone
My phone have PIN code blocked
You should get your PUK number from your service provider... no one else have it
Dec 28, 2007 | Nokia N95 Cellular Phone
N95 unlocking
When you have the unlocking codes for your N95
1. turn phone off
2.take the battery off and the sim card out.
3. putt battery back in
4. switch phone on
5. enter unlock code using non predictive text.
Nov 12, 2007 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
37 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
