Question about Kenmore 62602 Electric Dryer
Had changed heating element, dryer is working for two weeks, now the dryer is not heating again ?
    Scholar:
  • 86 Answers
Could be your high limit thermostat, your breaker box not providing a full 240 volts, or the heating element went out again, ...(this happens). Good luck...
Posted on Nov 17, 2009
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
I have a samsung DV337AEG/XAA Electric Dryer which three weeks stopped heating up. We replaced the heating element, along with the thermostat. after that it heated up for 20 minutes then stopped, replaced...
This one isn't going to be easy, you've already replaced the major things. I'm guessing there's a crack in some connector, or other defect, that heats up like the element and opens up- giving the same symptoms. It could be a faulty connection in the power feed to the element connector, or any other connection en route to it. You might see something suspicious. If you have some electronic skills, you might run the dryer until it happens, then quickly disconnect it, and while it's still hot, ohm out all power connections and wiring that could affect the element. You might get lucky and find the open line, being able to hone in on the bad connection, etc. Good luck!
Mar 25, 2010 | Samsung Dryers
Heating element is not working
I would say it could be one of two things. The heating elements could be bad, not likely though as the were working when the dryer was reset. You may want to try changing your circuit breaker, as your heating elements work off of the 2 phase 240 voltage while everything else in the dryer works off 120V. Check the voltage on each phase of the breaker in your electric panel see if your putting out the full 110-120V per phase.
Jan 09, 2010 | Frigidaire GLER331A Electric Dryer
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Upper limit problem
check for shorted heating element ,coil will make contact with heater tank and bypass t-stats.If your limit is a thermal fuse you must change lower tstat as well.
Jun 17, 2009 | Whirlpool LER5636P Electric Dryer
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Dryer will not heat
Check to make sure you have 240V at the outlet. If you do, check the continuity of the element and thermostats. If still no heat, it could be the temperature setting switch, the timer or the motor.
Feb 19, 2009 | Kenmore 65924 Electric Dryer
Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Jan 18, 2009 | Kenmore 60172 Electric Commercial Dryer
Dryer wont heat
if you already replace the heating element . it may be loose or it get damage . you can open the dryer from the back . and ck if the 220v is coming in . or the thrmstate is no goog . most likely you heater when dad again. good luck . and let me know if you need to find any parts for it .
Apr 04, 2008 | Dryers
Kenmore 62602 Electric Dryer Logo
53 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
