Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
I have the S model and I have only used time,
I have the S3501 and I have only used 1 timeworked great! However, the second time I got it out, the base is heating up,took off attachments, definetely steam is coming out but somewhere between the base and the attachment, no water is disbursing out to make the pads wet???
  • Euro-Pro Master
  • 43,501 Answers
Pads do not get wet...just a bit damp...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 24, 2010
Roomba 560 fully charges. Runs for 2 seconds fully green and just stops. And lights up red.????
Set him on the floor, after powering him off and then back on, and press the "Clean" button three times. This will reset him.
Sep 11, 2014 | iRobot Roomba 560 Robotic Vacuum
What? I have a Dirt. Devil easy steam carpet shampooed model CE 6300 HD. It was working great and then just stopped spraying out cleanser/water! Is there a manual or does anyone know how fix this problem?
Hello! You may need to prime the trigger to get the solution to start flowing. To do this, recline the handle and pump the trigger about 30 times. Then, turn the cleaner on and hold the trigger in for 30 seconds. The solution should begin to dispense. Be sure you are only using the cleaning products specified for use with this unit. Hope this helps! If you still need assistance feel free to reach out to use here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
May 09, 2014 | Dirt Devil Easy Steamer Upright Wet/Dry...
Model discontinued
Unfortunately you may have to try a vac shop or order online. Parts for these older Eurekas (other than bags and belts) are becoming ahrder to find.
Sep 16, 2013 | Eureka Vacuums
I found a salton tweety and sylvester waffle maker, but there are no instructions. The light just stays on all the time when plugged in. How do you know when the waffles are done?
Try letting it warm up for at least ten minutes. Then add waffle batter and leave closed for about five minutes and check the waffle. If it is way over done try three minutes other wise adjust your time in thirty second increments. You should have great waffles in three or less tries.
Good Luck,
Gil Shultz
Jul 19, 2011 | Vacuums
Where to Purchase this model
I understand that this model has been highly rated online for a while, however another model which has a 2 year warranty and is black in color is the F5912-900. These are a great steam cleaner at a fair price. The Dual V is a step up but will have better extraction and easier to connect the hose and tools. and you will not need to pre-mix the solution. I have the F5900-900 model and it works just fine for me, it is just getting the correct steam cleaner to fit your needs and requirements.
To answer your question, most of these can be purchased at your local department stores or major retailers. a complete listing can be found at the hoover web site.
Mar 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
We have a Bissell Proheat Cleanshot 2X Model 9500 Steam carpet cleaner. The first time we used it things were great. The second time we used it it left tracks in the carpet. We have no idea what caused...
First things first. It's only the second time you have used the machine, so it must be fairly new. If you have a receipt and the unit is less than a year old you should take it to an authorized Bissell repair center and have the machine inspected under warranty.
Otherwise, The jets on this unit clog easily, there are two of them and you can locate them under the recovery tank towards the front of the machine, and blow them out with an air compressor. To prevent the jets from clogging in the future make sure to flush all shampoo out of the machine with clean water when done using it. That is most likely your problem.
If it is leaving black streaks on your carpet it could be coming from a burnt belt or melted brushroller part, in which case inspect the belts and brushrollers and replace the damaged pieces.
I hope this helped
Good Luck
Nov 21, 2008 | Vacuums
Lost Suction
Usually when there is no suction, one cause is the lid to the recovery tank is not on all of the way in the back. Also if you have that foam filter on the underneath side of the recovery tank lid, it needs to have a 1/4 in or so gap from the top of the filter to the top of the lid. Some models also have a duct that sits in front of the recovery tank, and if it isn't there, you have no suction.
Apr 20, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Electrolux EL7055 just stopped
They aren't quality machines, they are made by Eureeka, not Electrolux. Aerus/ Electrolux is really the way to go!
Sep 27, 2007 | Electrolux EL7055A Bagless Canister Vacuum
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
283 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
