Question about Emerson InSinkErator W-152 Point-Of-Use 2-1/2 Gallon Water Heater...
2 month old Lochinvar Electric 30 gal heater hot water has rotten egg smell. Do not have water softener system. Well water with a lot of iron.
  • sue_tisdale Nov 17, 2009
    It is not a new well, and none of the other residents of this mobile home park without water softeners have this problem. Well is 3 years old and very deep. But no one else has this complaint. I am a widow and do not have a dish washer. Laundry maybe 2 times a week. Dishes minimal. HELP!!!!!
  • 317 Answers
Is it a new well.......it may go away after a while...its sulfer....sometimes when you drill well too deep you get sulpher water......
Posted on Nov 17, 2009
What could be the problem causing the rotten egg smell in the water? We have changed the anode rod.shocked the well.no sulfur. We have kinetico softener. Use iron out salt. Water heater 2 yrs old.
Some water softeners you can increase the back wash time on the unit to clear out a smell or bad taste , rotten egg smell can be sulfur. You may need a well flush but seek a well company on that for there advice as its not cheap .
May 16, 2017 | Water Water Heaters
Egg smell from hot water
You either have water with a high sulfur content or need to flush your heater. you should flush your heater every year anyway. you can turn off the water and electric to the heater. and totally drain the tank when it is totally drained add more water and drain some more. then refill the tank and run a hot water faucet the tub is best to eliminate any air in the system then turn the electric back on this should solve the problem if it does not you probably have sulfur in the water and would need water treatment or filters to help
May 06, 2014 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I replaced the anode rod in my electric hot water heater but still get the rotten egg smell. Any suggestions? The heater is over 22 years old, 80 gallon.
Clean the tank with hydrogen peroxide as outlined in following link.
You may also need well company to shock-treat the well with clorox, or whatever procedure they recommend for local area.
http://waterheatertimer.org/Replace-anode-rod.html#H2O2
Aug 08, 2012 | Water Heaters
What is the purpose of the magnesium rod inside the water heater (bock)
These anode rods, sometimes made from aluminum, prevent corrosion. The rod emits ions that line the tank and help prevent corrosion. The rod isn't solid magnesium or aluminum; it has an iron core. If your hot water smells of sulfur (rotten eggs), the anode rod has gone bad or there is a presence of hydrogen sulfur gas that is overwhelming the rod. Usually replacing the rod will stop the odor, but sometimes chlorination of the tank is necessary.
Oct 25, 2011 | RTO Bock Water Heaters 32E 32 gal 104,000...
Hot water is flowing from the water heater into
boiler type? Combi,standard,if your boiler is a combi the non return valve onto your heating line may be defective thus hot water slippng back through cold line best of luck
Oct 27, 2009 | Water Heaters
Smelly water from electric hot water heater 40 gal.
turn the power off and flush it out by letting the tap run for an hour or so
i think it could have lime scale in it or the element is about to blow if its the type that you can get the top off look inside it you may see the fult even kettle cleaner may be needed to clean it out, but dont go drinking that water???
Oct 24, 2009 | RTO Bradford White M-1-20U6SS 19 Gallon...
Atwood heater problems
The smell is from the (anode rod not sure of this term is exact) in the water hater. Smells like rotten eggs. You have to remove the rod in the top of the water heater. This will void the warranty of the heater. The soot is due to flame adjustment. this should be done by a professional.
Jun 18, 2009 | RTO Atwood Water Heater - 6 Gal LP
The hot water smells like rotten eggs., only the hot water
its the mag rod in water heater-if your not using alot of hot water,and water is sitting in heater it will smell like rotten eggs-u can remove mag rod from water heater.it is in top of heater-
Jan 08, 2009 | General Electric GE SmartWater Household...
Emerson InSinkErator W-152 Point-Of-Use 2-1/2 Gallon Water Heater... Logo
141 people viewed this question
Top Emerson Water Heaters Experts
Donni Steen
Gil Shultz
ray gallant
Are you an Emerson Water Heater Expert? Answer questions, earn points and help others
