Question about FIC K7MNF-64 nVidia nForce 2 Socket A mATX MB w/Snd, VID LAN Motherboard
I am just trying to purchase a new battery .. for the motherboard..cmos.. can't find out what type I need to get. There was not one on the board, and my pc keeps shutting down when I get on the internet. I keep losing my settings as well. I was told by someone it just needs the battery.
  • 113 Answers
3.0vdc-3.5 vdc battery number CR2032
Posted on Nov 16, 2009
Cmos battery problem
If you change the Date and Time and when you next boot up your computer the Date changes to some previous date then the CMOS/BIOS battery is flat and it needs to be replaced. Most motherboard use a 3 volt coin size lithium battery type CR2032 you need to check which type od BIOS battery your motherboard uses.
Jul 16, 2012 | Intel Desktop Board D410PT with integrated...
ASUS P5GZ-MX: Cmos Settings Wrong - Tryed New Cmos battery and setting time a date howto fix ?
It may just be that the new battery needs to be charged. I would leave it switched on for 24 hours to check. If this doesn't fix the problem, it could also be a failing BIOS chip or the charging circuit for the CMOS battery has failed. If the BIOS chip is not socketed or the cmos charging circuit has failed, you will need to replace the motherboard or find an electronics engineer to replace the failed components, this will probably be more expensive that a new board.
Jun 13, 2012 | ASUS P5GZ-MX Motherboard
I have an intel g41 motherboard....every time i switchon d pc...it shows check cmos error and the time and date are set to defaluts
This error occurs when the BIOS battery is flat. Replace the BIOS battery, most motherboards use a lithium battery type CR2032, this is a coin size battery. Check the BIOS battery type used on your motherboard before you purchase the battery.
After replacing the battery go to the BIOS setting and set the Date & Time etc. and you will not have this CMOS error.
Aug 10, 2011 | Intel Motherboard
HP Desk Top Pavillion a815n - what type of mother board battery does it use?
The motherboard battery is the CMOS battery that has a part number of CR2032 and can be acquired at your local Walmart or Target type store. You will need to remove the side panel of the computer to get to the motherboard and just look for a round battery should be silver looking. Remove it and replace it with the one you purchased if it needs replacement that is.
Apr 07, 2011 | HP Pavilion a815n (PS512AA) PC Desktop
How to change battery on asrock k7s8x motherboard
A coin-cell battery (CR2032) usually powers the real-time clock and CMOS memory. The battery is 3 Volts, 3/4" in diameter and has an estimated life of three years. When the computer is plugged in, the standby current from the power supply extends the life of the battery.
Just open the desktop, locate the CMOS (Coincell) and remove using screw driver. Replace the battery with CR2032 or an equivalent one.The following brands are used interchangeably for this item: Energizer (ECR2032), Duracell, Panasonic, Eveready, and 3M etc, which can be purchased from any local electronics store.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Feb 03, 2011 | Asrock K7S8X-R3 Motherboard
Motherboard crash bios
1st remove ur mother board battery and clear cmos and press reset when machine start then shut down and change a new battery and fixd cmos. i hope ur problem will solv
Mar 17, 2009 | Computers & Internet
BOOT falilure after RAM installation
Did you make sure that the new RAM was compatible with the motherboard? ...?
Some RAM manufacturers are not compatible with certain motherboard manufacturers....
Aug 20, 2008 | PC Chips M810DLU (M810DLUV75C) Motherboard
Failed to take out motherboard
Hi Bhauryal,
Just want to now, do you mean you can't find the battery on the board or removing the battery didn't work?
If its the battery, it is usually a round flat coin like shinny thing on the board with a plus sign on it (like the batteries used on some watches), although there are some very old boards that use a different type of battery which looks like capacitors or small drum like things (but these type of batteries are not used on modern board designs anymore). If you really can't find the battery on your board, I suggest you check its documentation, you can try downloaing it from the motherboard's manufacturer website.
If you mean that removing the battery didn't work, it means that your board's CMOS has the capability to hold a charge to save the settings for a longer period of time, if your board has a CMOS reset jumper, I suggest that you use that instead, you will usually find it near the battery or BIOS chip. There are some PC manufacturers (especially branded ones) that implement a different method of BIOS reset so I suggest that you consult the PC manufacturer on how to do it (e.g. for DELL PC's you remove the CMOS jumper, power on the unit for a few seconds, power off, return the CMOS reset jumper again). Hope this helps.
Cheers and best regards,
May 06, 2008 | Dell C600 (002UH) Motherboard
Computers & Internet Logo
64 people viewed this question
Top FIC Computers & Internet Experts
David
David
John Anderson
John Anderson
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
