Question about Microwave Ovens
E-Wave over the range microwave has blown main fuse
My 6 yr old Ewave over the range microwave has just blown fuse behind control panel. I replaced the 20A fuse, but it blew immediatly upon plug in. I see no burned /arcing places inside. What can I check, or is it toast?
My Ewave has stopped heating eventho it appears to be running. Is is possible the power has been reduced or does the microwave need to be replaces
Posted on Feb 17, 2010
I have a GE JTP85. The front panel is dark and both the oven and microwave do not work. Is there a fuse that could be blown? If so where is that fuse located?
Every microwave has a fuse. It's either located behind the control panel (over the range units) or near where the power cord enters the cabinet.
Nov 19, 2016 | GE Microwave Ovens
Ewave microwave
Over the range microwaves are generally the same as far as the rear dimensions but you will still need to install new mounting brackets and drill new holes in the cabinet. Each brand is slightly differnt in its mounting.
Nov 25, 2013 | Microwave Ovens
Samsung microwave not working
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
God bless you
Apr 02, 2013 | Samsung Microwave Ovens
My emerson microwave will not power on
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open. Use the VOM
God bless you
Apr 02, 2013 | Emerson Fans Emerson MW8115SS Microwave...
Sharp carousal convection smart+easy does it have a fuse just died
use the VOM, God bless you
Apr 01, 2013 | Sharp R1880LSRT Over-the-Range Microwave...
My microwave shows nothing on display and will not turn on
see this causes and fix it. God bless you
Sep 27, 2012 | Maytag Appliances Over-the-Range Microwave...
Whirlpool GH5184XPS-7 microwave oven dead, no power.
The problem is in the magnetron or the inverter board.
May 27, 2012 | Whirlpool Microwave Ovens
Oven light only, everything else dead. no display. ewave mod. kot131uw
Usually means the internal 20A fuse is blown because the magnetron is shorted. If it's over 5 years old, it's probably a goner. You can check the fuse by removing the access panels but be sure you've unplugged it from power first.
Jun 12, 2009 | Microwave Ovens
Blown Fuse on a Microwave
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Let us know if you need further help with torubleshooting.
Nov 28, 2008 | Kenmore 62702 Microwave Oven
Microwave not functioning
The fuse is usually located behind the control panel, sometimes near the switches, or on the chassis floor. In some models it may be mounted in the line noise filter.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 12, 2008 | Maytag MMV5165 Microwave Oven
Microwave Ovens Logo
1,339 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
