Question about Toshiba Satellite 1005-S157 Notebook
Toshiba Satellite 1005-S157 shuts down periodically by itself. Replaced fan/heatsink. Still shuts off.
  • ezman604 Nov 16, 2009
    Replaced the fan/heatsink. Also applied thermal paste to CPU before installing new fan. Fan does run when first booting and if it gets hot enough, so thermestat is also working.
    I will reseat the CPU just in case. As far as RAM, if it is failing, you generally get a BSOD with error message. Hard drive also, and possibly just a flashing cursor, not a complete shutdown.
    I agree it seems to be a thermal issue, shutting down to prevent damage. But the cooling fan is running, prior to it shutting off.
  • 458 Answers
You need to check a few things... when the fan/heatsink assembly were replaced, did you make sure that the thermal pads on the CPU and GPU are NEW/Good.... Make sure that the Heatsink GPU pad Firmly sits in the chip....
You can test the thermal controller by using a hair dryer or heat gun.... Point it onto the heatsink pipes and see if your fan spins when the pipes get hot, then remove and see if the fans slow after a minute...
You might have faulty RAM or Misseated RAM... Pull The RAM chips and reseat them...
Also Make Sure Your CPU Is Locked Down....
Periodic Shut Downs Can Be Caused By Quite A Few Different Things...
Typically it's due to Thermal Damage
Though Failing RAM or A Failing Hard Drive, Overheated Video/GPU Chip, Or Even Failing CPU can as Well Cause This Issue...
Posted on Nov 16, 2009
How can i reset bios for satellite 1005-s157??
DOWNLOAD PCCMOSCLEANER FROM PCCMOS.COM
BURN THE ISO IN A CD
BOOT FROM CD
Dec 06, 2010 | Toshiba Satellite 1005-S157 Notebook
Tip
Fix OVERHEATING Notebook
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A135) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
on Mar 15, 2008 | Toshiba Satellite A135-S2276 Notebook
I have a Satellite 1005 S157 and would like to know what I need to do to be able to use wireless. Do I need a card? USB drive? Software? Thanks.
If you are talking about wireless networking, all I did was buy a wireless PCMCIA card and install the drivers on the CD or buy a usb network adapter and do the same. I am still running Windows XP Home on my system and with bringing the ram up to 512 MB which is the maximum, it still does what I need it to do.
Nov 24, 2010 | Toshiba Satellite 1005-S157 Notebook
My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.And from yestarday it is shetting down after 30seconds after...
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It's nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
I decided to use a shop vac to suck the dust out and it worked. I tested it by letting the machine run all night and it worked. It's been a couple of weeks now and I'm glad I did it. I was ready to take the machine apart, now I'm glad I didn't. I'd suggest you use a heavy duty shop vac to clean out the fan and heat sinks first.I agree. Try to fix the problem without taking the laptop apart first but I would recommend using a powerful air compressor instead of a vacuum cleaner.
If your laptop is still under warranty, you can take it to any Toshiba Authorize Service Provider and fix the problem at no charge to you.
Toshiba Satellite A15 Clogged Heatsink
Toshiba Satellite A35 Clogged Heatsink
Toshiba Satellite P15 Clogged Heatsink.
Aug 25, 2017 | Toshiba Satellite A205-S5855 Notebook
I used the Windows XP recovery disk for my desk top computer on my Toshiba Satellite 1005-s157. I do not have the recovery disk that came with the system. How do I correct this? Can not get online plus no...
go to start/all programs/accessories/systems tools / system restore and restore to an earlier date.........go back 2 months at least (when your laptop was working fine) ....the system will shut down & reboot up and prompt you with are sure this okay to do click ok.........
Jul 24, 2010 | Toshiba Satellite 1005-S157 Notebook
How to adjust screen brightness on Toshiba Satellite 1005-S157
You can adjust the the screen brightness by hold down the FN key and hitting F6 or F7. F6 will decrease the brightness and F7 will increase the brightness.
Jul 13, 2010 | Toshiba Satellite 1005-S157 Notebook
Toashiba 1005-S157 won't turn on.
remove the batteries for 2-3minuty, check if it works,
Enter the BIOS, set the boot order of devices on the 1-HDD, 2-CDROM
Sep 09, 2009 | Toshiba Satellite 1005-S157 Notebook
the only thing you can do is buy and load a new copy of windows xp Home .
this will install and overwrite any and all files passwords & etc so you can format and use this computer if its factory operating system was xp home this is what you need to buy to unlock this computer but make sure you purchase a full version not an upgrade version of XP HOME
Jan 22, 2008 | Toshiba Satellite 1005-S157 Notebook
I dont know what i have on my toshiba
Yikes, look up password recovery on Google, you can download a bootable floppy disk program that can get past this. In the System control panel, you should see a list of system,hardware , device manager that is on the laptop, look for a device under network adapters or modems
Toshiba Satellite 1005-S157 Notebook Logo
252 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
