Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
I have a motorola SBG900 and i cant seem to fine my user id and pass word to get to my configuration page i keep reading these other options that keep saying type in admin for the user name and motorola for the password but it doesnt work
  • 2,263 Answers
Is there any computer connected to the router?
If not then you will need to connect the computer to the router and the access the router setup and you will find the password there if you don't know the password to access the router then you will need to reset the router and reconfigure the router.
Click Here for more info
Posted on Dec 05, 2009
Can't log into 192.168.0.1
The article I read suggested 192.168.100.1
admin (no capitals)
motorola (no capitals)
And no need to get your breathing rates high in case you have changed the username/ password of Motorola SBG900 and forgot them, as you can just reset the Motorola SBG900 router by press-and-hold the reset button with a straightened paperclip for about 15 seconds.
http://modemly.com/Motorola-SBG900-router-setup
Feb 15, 2018 | Arris SURFboard SBG900 Wireless Router...
I need to open port for xbox live
Starting the SBG900 Setup Program
1. On a computer wired to the SBG900 over Ethernet or USB, open a Web browser. Do not attempt to configure
the SBG900 over a wireless connection.
2. In the Address or Location field, type http://192.168.100.1 or http://192.168.0.1 and press ENTER to display
the Log In window:brymz.jpg
3. In the User ID field, type the User Name; the default is "admin" (this field is case sensitive).
4. In the Password field, type the Password; the default is "motorola" (this field is case sensitive).
5. Click Log In to display the SBG900 user configuration and status windows:
6. Then click on "Gateway" located at the left corner.
7. Then click on "Port Triggers".
8. Then choose "custom"
And from there:
ADD NEW SPECIAL
APPLICATION
Name Enter the unique name for the port trigger. This is typically the protocol.
Enable Select this box to enable the custom port trigger.
Protocol Sets the transport protocol for the port trigger - TCP or UDP.
Port Range Sets the port range for the port trigger. Type the start of the range in the
(From:To) left field and the end in the right field.
Session Chaining Enable session chaining if the application needs to open one or more ports in
different ranges to operate properly. The options are Disable, TCP, TCP/UDP.
Session Interval Sets the session interval for the application:
• If the port triggers detect traffic on the Port Range within the Session
Interval, it is considered to be related to the initial session.
• If the port triggers detect traffic on the Port Range after the Session Interval
expires, it is considered to be a new and unique session.
Address Replace Sets the address replacement method for the application.
Multi Host Select if appropriate for the application.
Add Click to add the port trigger to the PORT TRIGGERS TABLE.
PORT TRIGGERS TABLE Lists all port triggers you defined and their parameters.
Hope it help you....
Sep 13, 2011 | Arris SURFboard SBG900 Wireless Router...
Trying to secure my wep, tried the loggin admin, motorola but will not log me in.
Couple of things you can do....
In the User ID field, type admin (case sensitive) and press TAB. In the Password field, type motorola (case sensitive) and click Log In to display the SBG900 Setup Program main window
If you are still having problems, try the following:
  1. Press the reset button on the rear panel. Resetting may take 5 to 30 minutes
  2. Try the login again, if that fail try from a different browser.
Mar 06, 2011 | Arris SURFboard SBG900 Wireless Router...
Need modem reset - unable to access using original user ID and password.
Press RESET button for 10 seconds it is in back side of router then all settings defaults.Then you can configure it with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Oct 10, 2010 | Arris SURFboard SBG900 (49402201900) Modem
How do i put a password on my wireless motorola router?
Use the Wireless > SECURITY — basic Page to encrypt your transmitted data. Choose one of:
If all of your wireless clients support WPA encryption, we recommend using WPA instead of WEP because WPA:
• Provides much stronger encryption and is more secure
• Provides authentication to ensure that authorized users only can log in to your WLAN
• Is much easier to configure
• Uses a standard algorithm on all compliant products to generate a key from a textual passphrase
• Will be incorporated into the new IEEE 802.11i wireless networking standard
For new wireless LANs, we recommend purchasing client adapters that support WPA, such as the Motorola
Wireless Notebook Adapter WN825G, Wireless PCI Adapter WPCI810G, and Wireless USB Adapter WU830G.
For more information about the benefits of WPA, see the Wi-Fi Protected Access Web page:
http://www.wifialliance.org/OpenSection/protected_access.asp.
Configure on the SBG900 Required On Each Wireless Client
If all of your wireless clients support Wi-Fi
Protected Access (WPA), we recommend
Configuring WPA on the SBG900
If you use a local pre-shared key (WPA-PSK) passphrase, you
must configure the identical passphrase to the SBG900 on each
wireless client. Home and small-office settings typically use a
local passphrase.
Configuring a RADIUS server requires specialized knowledge
that is beyond the scope of this guide. For more information,
contact your network administrator.
Otherwise, perform Configuring WEP on the
SBG900
You must configure the identical WEP key to the SBG900 on each
wireless client.
Feb 15, 2010 | Arris SURFboard SBG900 Wireless Router...
Motorola router nat not open for xbox live
Configuring the Firewall for Gaming
By default, the SBG900 firewall is disabled.
If, as recommended, you enable the firewall, refer to the game’s documentation to ensure that the necessary ports are open for use by that game.
The pre-defined SBG firewall policies affect X-Box LiveTM as follows:
LOW: XBox Live data can pass through the firewall. No user action is required.
MEDIUM or HIGH: To enable X-Box Live traffic to pass, you must configure:
• Choose Custom on the Firewall > POLICY — basic Page • UDP 88:88 and UDP/TCP 3074:3074 on the Firewall > POLICY — advanced Page
Configuring Port Triggers
Because the SBG has pre-defined port triggers for games using any of the following applications, no user action is required to enable them:
• DirectX 7 and DirectX 8 • MSN Games by Zone.com • Battle.net®
For a list of games supported by Battle.net, visit http://www.battle.net.
You may need to create custom port triggers to enable other games to operate properly. If you set custom port triggers and enable the firewall, you must customize the firewall to allow traffic through those ports.
To create custom port triggers, use the Gateway > PORT TRIGGERS — custom Page.
SB900 USER GUIDE
The motorola guide has more information relating to port triggers.
If you download the pdf file, go to page 27 for Firewall settings and Page 35 for Gaming Settings..
More indepth information is there.
Hope that helps
Mike
Sep 20, 2009 | Arris SURFboard SBG900 Wireless Router...
Sbg900 router, login problem
try to configure the browser settings, follow the steps below
1. Go to internet options and select the security tab
2. Highlight Internet and click customer level button
3. Scroll down to the very bottom, under user authentication select automatic logon with username and password
4.rest customer settings to medium
Jul 16, 2009 | Motorola Computers & Internet
I cant reset my Motorola SBG900!
Ok in the back of this unit or bottom there is a reset button or hole that you need a pin needle to access. Press it in for 15sec and let it reboot. Once it reboots, open a web page and type in 192.168.100.1 or 192.168.0.1 This will bring up a log in page. The login is admin and the password is motorola.
May 24, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Cant lock my signal was trying to find a alternative way because i lost the disk??? i have a SBG 900 and any one can get on my internet signal
There's another option to configure the security or encryption using your SBG 900
Connect your computer to one of the LAN ports
Access the configuration of the modem (example 192.168.254.1)
The if you got the configuration page open find the wireless settings and configure the WPA or WEP security using your modem.
Mar 08, 2009 | Arris SURFboard SBG900 Wireless Router...
Motorola SBG900-SiS191 Ethernet Controller
Setup your IP addresses correctly by checking available IP addies in router.
You will have to know your router addie and your available wireless addies (in router). For this you need to enter router configuration (read manual).
Open network properties, tcp/ip properties, check "use following ip addie and enter something like 192.168.1.5 depending on what your router is setup as available.
Enter same subnet as your router.
Enter DNS server addies from you ISP.
Feb 02, 2009 | Arris SURFboard SBG900 Wireless Router...
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
421 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
