Question about Fujitsu Siemens Computers & Internet
Laptop FS Amilo Pi 1556 no booting / Corrupt bios
Does not boot anymore, does not reach post.
Screen remains black (even no backlights)
Leds are blinking
No fan
CD drive and HDD working
Only one long beep and then the process starts over again
I think the bios is corrupted and I need to revive my laptop with a crisis recovery disk. The problem is that I do not know the key combination to enter the crisis recovery mode.
Thanks in advance!
2 Suggested Answers
  • 10 Answers
SOURCE: Laptop freezes on Win XP boot or shuts down before booting starts
go through the following steps in the weblink and check the steps what ever you can perform:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?cc=us&lc=en&dlc=en&docname=bph06569
Posted on Feb 18, 2009
Boots up but stalls at the black screen with '(c) Microsoft Corporation' and the sliding green loading bar.
hi this problem sounds like you have a corrupt bios or firmware installed, the simple solution is to go to the manufacturers website and try and download the updated software plug in the device and either roll back drivers or upgrade them please contact me if this does not help
Feb 28, 2013 | Fujitsu Siemens 20v 3.25a 65w For Fujitsu...
Chiedo cortesemente come accedere alla batteria tampone x resettare password di bios . grazie anticipatamente
To reset the BIOS password read the information from this link. In case of your laptop the easiest method would be using software from Hiren's Boot CD.
Per reimpostare la password del BIOS di leggere le informazioni da questo link. In caso di computer portatile il metodo pi? semplice sarebbe utilizzando il software da Hiren's Boot CD.
Jan 07, 2011 | Fujitsu Siemens AMILO Pro V2000 Notebook
POST and BIOS Question: Dead laptop I`ve been given a Fufitsu Amilo L6825 laptop which is faulty.( It fails to get by the POST test so doesn`t even reach the BIOS option.(It switches ON, fans run but black...
Since you swapped everything, the last option will be the on-board power supply. If it has failed, then nothing will work. As a guess, I would assume the 1.8v power supply for the CPU has quit.
May 26, 2010 | Siemens Computers & Internet
Fujitsu amilo simens Pi1536 and Pi1556 bios password chip locatio
Hi ,
Replacing the existing BIOS chip with a new one you can buy from your specialized electronic shop or your computer supplier. It's a quick operation if the chip is inserted on a base and not soldered to the motherboard, otherwise you'll have to unsolder it and then put the new one. In this case would be more convenient to solder a base on which you'll then plug the new chip, in the eventuality that you'll have to change it again. If you can't find the BIOS chip specifically made for your motherboard, you should buy one of the same type (probably one of the ones shown above) and look in your motherboard manufacturer's website to see if there's the BIOS image to download. Then you should copy that image on the chip you bought with an EPROM programmer.
Important
Whether is the method you use, when you flash the BIOS not only the password, but also all the other configuration data will be reset to the factory defaults, so when you are booting for the first time after a BIOS flash, you should enter the CMOS configuration menu (as explained before) and fix up some things.
Also, when you boot Windows, it may happen that it finds some new device, because of the new configuration of the BIOS, in this case you'll probably need the Windows installation CD because Windows may ask you for some external files. If Windows doesn't see the CD-ROM try to eject and re-insert the CD-ROM again. If Windows can't find the CD-ROM drive and you set it properly from the BIOS config, just reboot with the reset key, and in the next run Windows should find it. However most files needed by the system while installing new hardware could also be found in C:WINDOWS, C:WINDOWSSYSTEM, or C:WINDOWSINF .
ERNZ
Jan 16, 2010 | Fujitsu AMILO PC Laptops
Fujits amilo pro v2030 will not boot up
Are you getting the BIOS info on the screen?
If you can access the BIOS check all the setting.
Hard Drive installed, Boot Sequence and so-on.
If you get NOTHING on the screen but can hear it "running", try plugging in a Monitor, you may have to find the monitor key, usually = hold "Fn" + Press "F5" to switch screen to monitor to both.
Oct 08, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Can nor remove bios password from a amilo laptop
Take out the battery for longer. It seemed to reset by indication of checksum error, but for an odd reason its still passworded. Remove battery and this time short the battery contacts on the motherboard and make sure no power or battery is in the machine. Then replace the battery and give it a shot.
May 06, 2009 | Fujitsu Siemens Computers & Internet
White as pink, black as green
boot up your laptop and take a magnet in your hand and revolve around the screen the screen might go crazy but all the colors will be back in a while. :)
Mar 23, 2009 | Fujitsu AMILO PC Laptops
Fujitsu siemens Amilo D 7830 CMOS battery keeps dieing
As an update to this, I've been able to boot it up a few times since posting this, but it never gets as far as being able to boot up an entire operating system before freezing.
Nov 19, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu siemens amilo pro v200 problem!
this could be a corrupt usb controller or web cam driver; but before we get too deep when it is booting up press F8 and you will get a menu, one of which will say, start windows with 'last known good configuration', highlight line the press enter for a restart. If no luck with boot up come back.
Jan 15, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Computers & Internet Logo
603 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
