Question about Husqvarna Designer I
I have the quilters 150x150 hoop and I need an update to use it, the button on my embroidery machine is grey I think it needs to be dark blue
  • 201 Answers
Dark grey, actually, but you don't need the upgrade. Set the hoop size at the machine for the 150 x 240 hoop and the 150 x 150 hoop will work. Just be sure that the design starts in the centre i.e. don't move it up or down at the machine Embroidery screen. Before you begin sewing, check that the design will fit in the hoop without bumping the sides of the hoop. Use the Check Size button which is on the second screen of the Embroidery Screen (touch More on bottom right of first screen). The Check Size button is the one on the bottom right - the first button to the left of "More". Touch it once, hoop moves to top left of design; touch again hoop moves to bottom left of design; again hoop moves to bottom right; again hoop moves to top right.
Make yourself a note so that when you next take your D1 in for its regular service, get the hoop upgrade done at the same time. You need to have at least version 2.1 of the machine software installed - your tech. can do this for you too. It is a really minor adjustment so should not add much to the service cost. Be sure to take the embroidery unit in too when you go for the service.
Posted on Nov 28, 2009
What is the symptom of a broken hoop
Sounds like you might be having problems with the machine not wanting to start sewing an embroidery pattern or not recognizing the hoop size. If the former, and the embroidery is full size (say 100x100mm), try reducing the embroidery slightly (say 98x98mm). If the latter, your embroidery unit may need slight adjustment to correctly identify the hoop. Its not an elaborate adjustment but you will probably need a profession to accomplish it.
Mar 23, 2014 | Husqvarna Viking 1
What do you do if your hoop misaligns during embroidery?
you may have to take the machine to a sewing machine shop & have
it checked to see if it needs to be realigned
Jun 11, 2012 | Brother Sewing Machines
Brother PE770 Hoop size programming stuck on small hoop option
Your machine would be able to perform 5 X 8 embroideries. The hoop size on this machine is recognized by the machine itself, depending of the embroidery file size. So it the embroidery is small, it will indicate that the small hoop is needed.
But U can use the large hoop, position the embroidery where U want then perform another embroidery on the sams hoop.
TRICK : the embroidery size exceeds the hoop? reduce it in X and or Y using this function on the machine
Jun 10, 2012 | Brother PE770 Computerized Sewing Machine
In the middle of stitching a design - and when I came to a color change, the new color began stitching 1 to 2 inches below where it should. The screen showed the correct place, but the needle was way too...
If the design isn't too big, try rotating it in the hoop and stitch it sideways. If it works in that position, you probably should have the embroidery unit cleaned. I recommend the embroidery unit be serviced every 5 years. It may need it more often depending on your environment.
Dec 11, 2010 | Husqvarna Designer I
I have a Do All Quilter's Hoop which I can't use
I'm a bit amazed that a Husqvarna technician was unable to do the minor adjustment to the embroidery arm - he needs to contact Husqvarna headquarters and ask for instructions. Meantime, you can still use your hoop (which by the way is my favourite hoop - it's a little beauty!). Tell your machine you are going to use the Large Hoop (6" x 9.5" or 150mm x 240mm) even though you are really using the 6" x 6" or 150mm x 150mm Do It All Hoop. Provided you have centred your design before loading it on your USb stick or floppy drive, it should work. However, just to reassure yourself, use the Check Size button on your touch screen to test the outside size of the embroidery and be sure it is not going to foul on the hoop borders. (It is the one on the second screen (press More to access this) once your have loaded your design - looks like little double arrows pointing to the corners of a square. Each time you press this button, the needle will zoom to each outer corner of your design in turn.
Jul 10, 2010 | Husqvarna Designer I
Machine says that I don't have an embroidery hoop attached, but I do.
First turn off and disconnect embroidery unit and hoop from the machine. Plug machine back in and connect the embroidery unit only and turn the machine on. Reattach the hoop and test to make sure it's secure. Your hoop might not have been attached snuggly enough or you might need to put on the small hoop.
Dec 22, 2009 | Bernina Artista 180
The embroidery arm is not working properly. When i try to use the embroidery feature, the arm starts in the wrong area and the machine tries to put the needle through the embroidery hoop. The arm is also...
You definitely need to take that in for service. The machine has a feature that lets it know which hoop is on the machine so is can't sew outside the hoop area, so if it does, you'll need a technician to make it right.
Oct 15, 2009 | Husqvarna Designer I
Update for 150x150 hoop
If you have a light gray button then you need to have the embroidery unit upgraded. The hoop will fit on the machine, but the machine can not recognize the hoop. The new hoop holder that needs to be installed will have a second sensor trigger allowing the machine to recognize more hoops. The original holder only has one trigger and can only recognize earlier hoops.
Contact an authorized Husqvarna repair center to have your embroidery unit upgraded.
Nov 26, 2008 | Husqvarna Designer I
180E Hoop problem
Joan, there are 3 micrositches on your embroidery unit arm. these switches are depressed when you attach the hoops, it appears from your comments that one switch is not functioning. This could be simple, it is out of alignment or more complex it is broken. Either way you need to take it to a professional for repair.
Dec 21, 2007 | Bernina Artista 180
Embroidery stick
You need the USB Manager software to view the files. Have a look at all the software that were supplied with the machine. Load the embroidery software on your laptop and then open the USB manager.
When it opens it will show a light blue screen and grey icons to the left. Click in "disk", then click on "read disk" and you should be able to see your designs. The grey icons will turn orange were designs are stored, and the grey ones indicate empty space for more designs.
Enjoy your fantastic machine
Dec 18, 2007 | Husqvarna Viking 1
Sewing Machines Logo
266 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
