Question about Xerox Office Equipment & Supplies
OEM ID Mismatch Message on my 4025
I have a Xerox 4025 and just ordered a compatiable toner cartridge. I don't have the owners manual but when I put in the cartridge I am getting a message saying the "OEM ID Mismatch" is there a way to fix this
  • 208 Answers
SOURCE: cant get rid of blinking error message, nothing works
  1. Find the pink Clear button on the Control Panel.
  2. Find the button below the word Auto. Under image quality
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.It may be clear Copy quality, or image quality
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Dec 05, 2007
  • 53 Answers
SOURCE: xerox 5305 copier excess toner
sounds like faulty drum cleaning blade,which is usually contained in the replacement drum module.I would be inclined to take the drum unit back where you got it (unless you replaced it with a second-hand one) 99% certain the problem is contained in that module
Posted on Feb 27, 2008
  • 4 Answers
SOURCE: OKI C3200N laser printer, low toner problems
For each toner there is an individual toner sensor. There is a real good possibility that the metal contacts on the sensors have become dirty. Typically, a little bit of canned air directly on the sensor contacts will resolve the issue.
After removing a toner cartidge, look to hte left side of where that cartridge rests. The sensor is located there.
Posted on May 23, 2008
SOURCE: toner not set insert toner message
Yes that paper trick also worked for me. Thanks for putting it up!
Posted on Nov 09, 2008
  • 2072 Answers
SOURCE: I am using the workcentre and it says toner supply failed
You wont find any tape on the cartridge. There is none. That is an improper message. It is possible the ink cartridge will solve it, but it is more likely that one of the springs located in the copier where the back of the toner cartridge inserts is bent and not making proper contact with the toner cartridge. I have seen that cause that very problem several times.
Because you are receiving that message about the tape. That strongly suggests that you need to have the machine firmware updated to the current version. Sound like the machine you have has an older version of the machine firmware.
You can find the firmware and installation instructions at Xerox.com. It will be under Drivers and Downloads.
Posted on May 30, 2009
CRUM ID 093-926
That error signifies an unsupported black toner cartridge. Verify oem Xerox cartridge, try reseat cartridge. If not cartridge it will be the MCU Board, part number 960K60951.
http://www.iteminconline.com/960k60951_062k23373-960k60951-xerox-workcentre-wc6015-engine-controller-mcu.htm
Jan 31, 2016 | Xerox 6015/NI New Workcenter 6015/NI Laser...
09-800 Invalid Toner Cartridge Message
Verify that you are using oem Xerox toner cartridge. If you're using an Oem Xerox cartridge and still getting this error it could also be the Crum Board, part number 140N63302.
Apr 11, 2013 | Xerox Phaser 3635MFP/X Multifunction...
I have a TG9035 and a Okie B6300. They look alike. The toner cartridges look the same. When I place the Oki cartridge i get an ID mismatch. Are the cartridges interchangable?
The print engine will be the same (supplied by Xerox) the control boards were for both TG and Oki printers designed by part of TG before bankruptcy in 2009.
Importantly the toner cartridges have a chip on them to identify to the printer which cartridge is inserted, the chip on the cartridge will more than likely be the only difference. Hence you see the Missmatch message when you insert the cartridge in the wrong printer.
Oct 04, 2012 | Genicom Tally Intelliprint 9035n
The secretary ordered 3rd party toner cartridges for a Xerox Phaser 6130. After replacing the black cartridge the "invalid cartridge" message comes up. Is there a way that we can use the 3rd...
If you get the "invalid cartridge" message, try completely turning off and unplugging the unit. Then remove the cartridge, close the door and after at least 30 seconds, restart the unit. Then reinstall the cartridge. This worked for me!
Sep 26, 2011 | Xerox Phaser 6130 Laser Printer
Printer is coming up with id mismatch after putting new toner cartridge in goes away when old one is put back in?
The toner for the 9035 has a 'chip' to identify the toner is correct for the 9035, ie the toner is the correct manufacturer and model.
If you are getting the "ID Mismatch" error you either;
  1. Have a faulty chip on the new toner cartridge, I guess the best option would be to go back to the supplier.
  2. The toner cartridge is a copy / refill etc and has the wrong chip fitted, again going back to the supplier would be the best option.
  3. Locate the contact for the chip on the new toner cartridge and ensure these are clean from any toner dust etc which may prevent incorrect contact with the printer.
Nov 22, 2010 | Tally Intelliprint 9035 Printer
Phaser 4510 replace toner message won't print until new toner installed - new toner installed and still has the replace toner message
  • This product can be configured to use a metered or non-metered Toner / Print Cartridge. A non-metered machine requires a non-metered cartridge be installed to operate, while a metered machine can accept both a metered or non-metered cartridge to operate.
  • Make sure the correct cartridge is used for the machine. If you are receiving metered print cartridges but the machine will not accept them, contact your reseller or supplier to ensure that your machine is properly set up as a metered machine, and that the metered PIN has been entered
  • Make sure you don´t have any stickers on the toner box.
  • If you sure all paper and stickers are out then reset the nvm values from the device in order to reset the printer information.
Aug 27, 2010 | Xerox - PRINTERS - PHASER 4510 (N) LASERPR...
Do the reset chips really work on the cartridges of HP 2500N laserjet printer
Yes, reset chips really work on laser printer cartridges, if you have a know good source for the chips and if you know what your doing, you can't put a new chip on an old cartridge, the chip is what registeres how may prints you will get out of the cartridge if you put a new chip on an old or 1/2 empty cartridge of course it will say it's full but then try and print.It will register as a full cartridge but it can only print with the amount of toner that is actually left in the cartridge, be careful there are alot of remanufactures out there that don't put new chips on or that do but don't fill the cartridge full, or replace all the wipers and drums, they just dump some toner in and say here you go, Only buy your remanufactured cartridges from a reputable company, do your research on them first or you'll be sorry
Aug 14, 2010 | HP LaserJet 2500N Printer
Need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
Aug 08, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Lexmark E238: Lost manual. What does second light from bottom mean? Printer won't start.
could mean that it a mismatch carteridge
  • Explanation of the Cartridge Mismatch error
  • Clear or Confirm the Error Message
  • Check the Printer and Toner Cartridge Region Settings
  • If the Toner Cartridge and Printer Regions Do Not Match...
  • If the Toner Cartridge and Printer Regions Match
  • Jul 13, 2008 | Lexmark Office Equipment & Supplies
    Magenta cartridge empty
    When you take the toner cartridge off the imaging unit, is there magenta toner in the open slot of the IU? Assuming that there is nothing wrong with the toner cartridge, you are possibly looking at a bad engine control board.
    Jun 11, 2008 | Xerox Phaser 7300DN Laser Printer
    104 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    CheckitRight
    CheckitRight
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
