Question about Datamax DMX I-4206 Printer
Will this printhead work in a datamax DMX 1-4206 p/n KPW-104-8TBB4-DMX2 (724)
3 Suggested Answers
  • 54 Answers
SOURCE: datamax dmx-m-4206
check for the flatness of the printhead across the platen.
also check to see if the head is not worn(will be white colored at the head heat elements.
also check to see if the platen is severly worn.
Posted on Feb 25, 2009
  • 10 Answers
SOURCE: How to improve the resolution for Datamax I-4208?
1. If your printhead doent have burn element no need to change and if your platen roller is uneven change it.
2. check the setting of your darkness both printer and the job data
3. check the quality of your ribbon and label if this is match. some cheap ribbon is poor on quality.
Posted on Apr 15, 2010
DATAMAX E-4203 ONLY PRINTING HALF OF THE BARCODE
I doubt the sensors would have anything to do with only printing half a label. I'm not familiar with the E-class series of printers, but the common causes of that problem that I've seen before with the larger M & I class printers can be:
1) A piece of label or ribbon is stuck on the printhead.
2) The printhead is not seating properly on one side, causing the printhead to be too far away from the label & platen roller to apply enough pressure in order to print.
3) A printhead cable is not seated fully somewhere and not supplying the signals properly to that half.
4) The main logic board is bad.
5) The printhead is bad.
6) There is a software problem or label configuration setting that needs to be corrected that controls the print width.
Feb 26, 2014 | Datamax DMX E4203 Printer
Dmx-4204 and zpl
You can't, on this obsolete model. zpl is "Zebra Printer Language." This model of Datamax is dpl only ("Datamax Printer Language"). Most current models of Datamax printers are dpl and zpl compatible.
Jul 23, 2013 | Datamax E-CLASS DMX-E-4204 Label Printer
Only blank label prints out. Any reason? If it's the termal how do I do the clean? Any operator's guide? Thanks Gee
g_atsebha: If label is correct, then clean the printhead using alcohol isopropilic or maybe the printhead need adjust.
Roberto Martinez
padrino99@prodigy.net.mx
Aug 22, 2011 | Datamax DMX-I-4208 Label Printer
Wrinkles in ribbon using Datamax H-4212 printer
Definitely. possible solution match the width of your label and ribbon. if your ribbon is wider for .5 inch it should be good.
1. check your spindle alignment, printhead alignment and rotate the green knob on the printhead while printing so that you'll see the difference.
Jan 29, 2010 | Datamax DMX I-4206 Printer
We have several Datamax I-4208 printers and a few of the older I-4206 models. It would appear the replacement printheads are one in the same for both models be we cannot get either of our spares to work in...
Some changes were made on the I Class units and the new printheads do not work correctly in the discontinued 4206 models. You need part number DPO20-2262-01 for your I-4206.
Jan 18, 2010 | Datamax DMX I-4206 Printer
Printhead leaves impressions but no print
Sounds like you've run out of ink? If not then the ink has become dry and clogged the head.
Try using a alcohol solution (white spirit or a strong liquor like vodka will suffice) with a piece of paper towel to clean the head of the ink cartridge, then try printing a few times until it works well.
Otherwise, sounds like the cartridge needs repalcement.
Jul 02, 2009 | Datamax DMX I-4206 Printer
Datamax dmx-m-4206 printing half of the label
Jan 15, 2009 | Datamax M-4206 Thermal Printer
Printer does not print after change of Printerhead
Put the original printhead back in and test. If the original printhead prints even with missing elements then the new printhead may be bad.
Apr 24, 2007 | Datamax DMX I-4206 Printer
Datamax DMX I-4206 Printer Logo
541 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
pkwc
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
