Question about Alpine CDA-9884 Car CD/ MP3 Player
Not holding presets.
Hello, My problem is that when I turn off the ignition and turn it back on it erases the presets and the cd also starts over from track 1. Is there something I need to hook up differently to make the HU memorize my settings? Please let me know. Thanks
KB
  • banghusky Nov 23, 2009
    I hooked it up exactly how the Ford manual said it should be done. But I'm going to go ahead and switch them and see if it works. I havent had time but Ill give it a shot and let you know.
    Thanks for the reply. I really appreciate it.
  • Daniel Kozachek
    Daniel Kozachek May 11, 2010
    Are you using a wiring harness? or are you doing the wiring yourself?
    Sergeant:
  • 436 Answers
You need to change the yellow and red wires at the back of the radio round.
Posted on Nov 16, 2009
How do I enter the code I'm my blaupunkt car radio
Switch On Ignition (No Need To Start Engine)
Press & Hold Preset " AS " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press & Hold Preset " AS " Until the Unit Beeps
Apr 04, 2013 | Car Audio & Video
Hello i recently just got this Pioneer car cd player and it's started to frustrate me a bit. I've connected it all up as the instructions have said and the first immediate problem was that i...
did you hook the constant power wire up? its the yellow wire coming out of the deck. if this was not hooked up the deck would work fine, but it would not hold the time, or preset stations either
Aug 09, 2011 | Pioneer DEH-1300 CD Player
When i turn off the ignition and on again the unit loses its radio presets. Why is this and how can i rectify it?
hello jim_read!
please check your wiring, there is generally a red and a orange one, one is for permanent 12v the other for ignition, since your cdp does not get any 12volt after ignition turned off it can't keep memory.
regards
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Apr 06, 2011 | Sony CDX-MP40 CD Player
I bought an Alesis SR-16 drum machine from an online seller advertised as "new". I plugged it in, and it appears that my "new" machine has had all the factory preset patterns erased! Is there a way to...
Hi.
The SR-16 has 50 preset patterns that are built in, I do not think they can be deleted, if there are no patterns the unit may be defective, even if patterns can be reinstalled using an rmidi file or re-flashing the unit.
To reset an Alesis drum machine you have to hold down both Play and Erase buttons while you power on the machine at the same time.
If that does not work, the presets are held into an rmidi file , the Rmidi file is not available for download. I think it can be purchased contacting Alesis or Rmidi.
I quote from Alesis Rmidi page:
"A rMidi Import/Export File named 'Sr16PresetKits.xml' containing the Sr16 Preset Kits has been installed within the folder named 'Sr16' within the directory in which you installed the rMidi FrameWork software. You can Import these Kits into the rMidi Drums Control if you wish. "
Check if you have the file in the folder.
If not the Sr16 will allows you to export your User Drum patterns, but I do not think you can export factory patterns.
Nov 20, 2009 | Alesis Sr 16 Stereo Drum Machine
Memory not working
you may not have hooked up the extra wire for the memory back up on the radio... it will stay live when you shut off the radio.
Robert
Please take a moment to rate this solution thanks
Feb 01, 2009 | Pioneer DEH-2300 CD Player
JVC kd-s590
you need to have whoever installed the unit connect the YELLOW (memory) wire on the back to a constant 12 volt power source. It is hooked up right now to only have power when the key is on. this is why when you turn off the key, you loose memory.
what kind of car is this in... I can tell you what wire goes to what color if you cant figure it out.
Jan 12, 2009 | JVC KD-S570 CD Player
Radio Station Presets wont hold
hi girlygirl 1
the problem is your ignition and your permanant battery live wires are the wrong way round all you have to do is remove the stereo and you will usually see a red wire plug into another red wire and a yellow wire into another yellow wire all you have to do is change the red to the yellow and the yellow to the red and it will hold the memories fine hope that helps !
Nov 19, 2008 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
My presets reset each time i turn on the car and the cd gets ejected if one is in there
ok did u install your self?
black is ground
red is power if going to ignition only power when car ignition is on
and yellow memory straight power
yello is what holds the memory
Sep 15, 2008 | Car Audio & Video
Pioneer DEH 225 car radio instructio booklet
Actually, there a re a bunch of hits when you Google it.
Here's the answer I found straight from Pioneer:
If your car CD player is a 2006 model or newer:
  • With the ignition on and radio OFF,
  • Press and hold the MULTI-CONTROL button for 2 seconds
  • Rotate MULTI-CONTROL button until display reads CLOCK.
  • Push MULTI-CONTROL button up or down to adjust hour and minutes.
  • Press ESCAPE or SOURCE button to exit
If your car CD player is newer than 2000 but older than 2006:
  • With the ignition on and radio OFF, press and hold the FUNCTION button, until the display pops up, then release the button.
  • (If you do not have a function button, use the AUDIO button instead).
  • Press the FUNCTION button again until the clock shows on the display.
  • Press the UP and DOWN buttons to adjust the hours.
  • Press the LEFT and RIGHT arrows to move to the minutes.
  • Press the UP and DOWN to adjust the minutes.
    When you've completed all the steps, just press the SOURCE button to exit
If your car CD player is 1999 or older:
  • While holding down the CLOCK button, press the number preset button to set the hour.
  • While holding down the CLOCK button, press the number 2 preset button to set the minutes.
  • Pressing the respective buttons consecutively or continuously will advance the hour and minute.
For further assistance please consult your user manual.
Here are some other answers from around the web:
Hold down the source button till the unit switches off. Press thefunction button until it says clock. Use the tuner/volume controls tochange the time. Left/right switches between hour and minute. Up/downchanges the actual numbers.The website I'm including has all the old manuals on it if this doesnot work for you. Problem is, you may not know your model # so willhave to click through the links till you see a pic of one that lookslike yours. Hope this helps. I'm stoked that my clock is finally right!
turn the radio OFF with the car ON
then its easy to set the clock.
Most folks try to figure it out with the radio on
and it cant be done with the radio on,
Turn it off. Hold down "func" or "function" until something happens.
Then press the arrow keys still something else happens. When you're done, press "func" or "function" till nothing happens. Turn it on.
Dec 03, 2007 | Pioneer DEH-225 CD Changer
Pioneer DEH 435 CD player
Same as all Pioneers. With the car on or in ACC position press and hold SOURCE until the radio turns off. Press and hold FUNC to enter the menu. Use the four arrow keys to navigate and make changes.
Nov 30, 2007 | Pioneer DEH-27MP CD Receiver w/ MP3/WMA...
Alpine CDA-9884 Car CD/ MP3 Player Logo
49 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
