Question about GE Profile Spacemaker JVM1871 Microwave Oven
When turning on and within a few seconds the oven smells hot. Perhaps a electircal problem? We stopped it immediately; tried again with the same results. Serial # GL906529B
  • mmtoch Nov 16, 2009
    Is taking the oven apart easily done and easy to repair? Where are parts purchased. Would an electrician be needed?
    I understand that there is a waranty for 5 years to cover the magnetron tube if it fails. Is this a possiblity?
    Margaret Harris
  • mmtoch Nov 17, 2009
    Thank you for your prompt replys. I will use this service again.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It means that the temperature censor has gone bad and it is not cutting off automatically. It might have also happened due to some burnt component/wire inside the oven because of the over heating.
To check this you’ll need to disassemble the oven and look for any burnt component or wire inside the oven. Also check for dark/black spots near any component which indicates that there was an internal mal function.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 16, 2009
  • Rylee Smith
    Rylee Smith Nov 16, 2009
    It could be fatal to open the microwave as it contains 10000 volt current in the capacitors. Even when in off conditions the voltage is still there and is very risky to disassemble it and if you touch any component, it will be shorted and may create more troubles. That's why I recommend that it should be done by a professional repair tech. If the magnetron has gone bad, they will not charge you any thing as it is under warranty.
    Thanks
    Rylee
The Microwave shut off after a few seconds. I removed it from the wall and took the cover off. I fired it up and initially it behaved the same. I checked wire connectors that were readily available. Did...
It will get hot in a very short period of time. Could you have set the time for a few seconds instead of a few minutes? Thermal issues normally take the unit out until replaced. They are one shot thermal protect devices.
Sep 06, 2013 | GE SpaceMaker Microwave Ovens
Burning smell and loud grinding noise
If that grinding noise sounds a little like gargling into a coffee cup, that's a defective magnetron.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jan 09, 2013 | GE JVM1441 Microwave Oven
I have a Jvm1090aw. After using the convection oven the microwave will not function. Is this a moisture sensor or?
I have a jvm1090aw microwave oven and for some reason it just stopped working. It will still count down the timer but it won't light up and turn on. Also there is a small microwave icon flashing at the bottom right of the screen. Any ideas? Today I tested it again and started it for 30 seconds. The first 8-10 seconds nothing but silent counting down then it turned on for the last 20 seconds. It then turned on again when I tried it immediately after that but nothing 5 minutes later.
May 01, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Our microwave has stopped working for the second time in two years. When you try to heat something, it hums but not quite like it is heating. There is also a funny smell.
SAFTY FIRST
UN -PLUG IT,,,,, THAT "FUNNY SMELL" SOUNDS LIKE IT IS SHORTING OUT
PERHAPS THE MEGATRON HAS GONE BAD, THE MEGATRON IS THE
HEART OF ANY MICROWAVE
AS A EX- FIREMAN, I KNOW FROM FIRST HAND EXPERIENCE THAT
"A FUNNY SMELL " OR " UN-USUALL SMELL COMING FROM AN ELECTRICAL
ITEM IS A SIGN OF DANGER
Feb 05, 2011 | GE Profile Spacemaker JVM1871 Microwave...
The microwave starts, then stops after a few seconds, and smells
Remove the cover after pulling the power plug. Check the transformer and large capacitor for signs of overheating. If they look ok, then remove the sheet metal wave-guide from the area where the energy enters the cooking cavity. Under the wave guide is a fan-like device called a stirrer that has a plastic bearing. This stirrer bearing is commonly arced over (when the oven is operated with nothing to heat in it). Usually the bearing looks good, but has arced internally. Replace the stirrer as a unit. The machine can be operated with the case off and a cup of water for a load, but keep you hands clear. Look for smoke.
Sep 07, 2009 | Panasonic NN-H504WF Microwave Oven
Bosch HMT8655GB, after being used no heat and cuts out at 22 secs
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
e6tuwe
May 12, 2009 | Bosch HMT8655GB Microwave Oven
GE JVM1650 Microwave Suddenly Stops
Your magnetron tube is leaking RF energy inside and zapping the main board. It is NOT dangerous as any leakage will be contained inside the unit. You will need a new mag tube and it is covered by a 5 or 10 year parts warranty. Call GE Factory Service at 1-800-432-2737or schedule online at www.geappliances.com
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Burning smell , Microwave not turning off
the control circuit shorted out from the cleaning session and kept the microwave on so long with nothing to cook that it has cooked itself I'm sorry to tell you. Probably not worth repairing
Dec 27, 2007 | Kenmore 62702 Microwave Oven
Microwave works for a few seconds and then the lights and turn table inside shuts off.
hi the light and turntable work of a common relay located on main pc board.relay probably dry jointed or sticky or check switches behind door catches
Feb 27, 2007 | Maytag MMV5000 Microwave Oven
GE Profile Spacemaker JVM1871 Microwave Oven Logo
27 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
