Question about John Deere ?rear Lift Pipe Master Crank Disk Tillers: 1
Old 5 disc j-d disk tiller
I have a 5 disc j-d disk tiller with a "dog" handle to lift it up for transprt on its 3 wheels. the front left wheel is supposed to do the "Lift". However, when i get that wheel off the ground by lifting the tiller with my tractor loader, that whhel just freewheels, theres no catch or click that would indicate action.
could it be that the internal lift arrest latch is "frozen" somehow?
  • 110 Answers
SOURCE: '07 5403 John Deere Tractor lift arm will not lower
some-times the 3pt linkage can go past the top position.
When this happens - you will need to force! the linkage arms down.
Posted on Jul 02, 2009
  • 61 Answers
SOURCE: My John Deere 2010 tractors lift does not work.
Here is a link to the John Deere web site for the manuals.
The hydraulics on a 2010 are part of the transmission oil system. There is a bolt looking plug on the right side of the transmission, about half way up, about where your feet rest when your foot is not on the brake. Fill up the transmission until the oil is level with the top of the hole and is about to run out. Using HyGuard hydraulic/transmission oil or one that meets the same spec for the 2010.
Posted on Sep 10, 2009
  • 486 Answers
SOURCE: how to connect hydrolic lift to the 214 tractor
Part of the blower when new and first installed was a
1) pivot bar
2) lift link from blower to pivot
3) lift link from pivot to center of the tractor
the pivot was to be installed on a pre-made bracket on the frame just inside the front grille. A hole in the front part of the frame allowed the longer lift link to attach to that bar and go to the center of the tractor. Those two pieces remain on the tractor as permanent, and the lift link from the blower to the pivot bar to be removed or installed as you intend to use the blower. If you have purchased the blower used, the original tractor it was installed on still has those pieces on it. Your local Deere dealer can provide the pieces if needed.
Posted on Dec 06, 2009
  • 1627 Answers
SOURCE: Are enclosed cabs available for a 1985 model 1050?
I have never seen a 1050 with a cab other than homemade ones but if anyone makes one it would be Lauren Cabs.Try googling them for a dealer near you that you can call,it's worth a shot.
Posted on Dec 22, 2009
  • 43501 Answers
SOURCE: I have an LX178 tractor
The clutch is engaging, but it cannot turn the pulley, so the engine bogs down....
No, I don't think it is a clutch problem... it sounds more like you have a bering out on one of the mower deck blades, or the belt has jumped off and is pinched... at any rate the belt is not able to turn so it bogs the engine down...
To find the problem, you will probably need to remove the mower deck, then take the cover off over the belt and then check out all of the blade and idler pulleys to make sure that they all turn will find one that is frozen up....
BTW... you should be able to spin the belt...with the engine off....grab the belt and check it out....
Posted on Sep 04, 2011
I need a detailed instruction on how to fold a combi stroller
1. Lock both front swivel wheels. Not locking the swivel wheels before folding the stroller can damage the wheels 2. Empty the basket. 3. Fold the canopy by lifting the canopy levers. 4. Remove your player from the canopy. 5. Lift and hold the folding levers up on both sides of the handle. 6. Tilt the stroller onto its back wheels and roll it forward and then pull it back quickly and the front guardrail will fold inward. 7. Turn handle inward with an underhand hold to latch and lock.
Jun 02, 2011 | Combi Cosmo DX Stroller
My 3 wheeled mobility scooter cuts out almost every time I turn the handle to the left. I think it may have a kinked wire.
This typically happens when the front to rear wiring harness has a damaged internal wire or wires. The front to rear harness runs from the front control console, down through the tiller (T part) through the front wheel frame and angle adjustment collar, and through the bottom frame to the controller. There is a wear area of the wiring at the front bearing of the steering tiller. There are 8 or more wires in a covered jacket that run through this area. Over time they rub and get pinched or kinked and broken. The test for bad wiring is exactly what you describe. Usually the broken internal wiring cannot be seen.
The best solution is to replace the entire front to rear harness with the new connectors at each end. The harness is relatively inexpensive and labor should be about 1 hour. Hope this helps.
Jan 30, 2011 | Electric Mobility 3 Wheel Motorized...
The pull string broke how. how do i put the new one on?
Go to a hardware store and ask them if they have ant bulk pull starter rope. Buy about 3 feet or so of the small stuff (it is only 30 or 40 cents a foot, cheaper that the kits) Remove the motor cover with the pull start and turn it so you can see the wheel inside. Remove the knot that held the old rope in the handle and then cut the knot on the starter wheel and pull out the tag left in there.
Now the fun part. The wheel is spring loaded and the spring has no tension on it after the rope broke. Wind it up like a clock spring until it is tight then back off until the holes where the cord goes line up. Stick a small screw driver, nail, ect in the slot to keep it from unwinding . Do not tie the handle to the cord yet. Slide the new cord through the hole in the cover and wheel and then tie a knot in the cord and pull it snug in the wheel. Hold the rope and remove the pin and let the cord slowly wind itself up. Run the cord through the hole in the handle, Adjust to the length of pull you want and tie another knot.
Reinstall the motor cover (if it binds and wont go on, pull the rope just a little bit to line up the crank with starter wheel and it will slide down.)
It sounds a bit windy but it really is a simple fix.
Jun 09, 2010 | Troy Bilt Tiller/Edger 26cc, Model No....
Drive wheels not ternning
Tillers have a handle that you "squeeze to go". The handle activates a clutch, usually through a flexible cable. Does that handle offer resistance about halfway up as you squeeze it?
If not, that cable may have stretched a bit. Try adjusting the clutch by turning the nuts on the threaded sleeve where the cable comes out near the handle, until you get resistance when you squeeze the handle. The cable could also be broken, in which case adjusting won't help, but replacing the cable isn't expensive.
There's something else to check. Tillers have a pin to lock the wheels to the axle. It's right at the wheel hub. The pin can be pulled out to make it easy to move the tiller without running the motor. If you can push the tiller around easily with the motor off, then you may just have a missing wheel pin.
If it's not these simple things, it could be something worse like a problem in the transmission. If reverse works, but not forward, then it's probably the transmission, which is bad news. I hope it's one of the simple problems above.
Please rate if this was helpful, thanks and good luck!.
Jun 04, 2010 | Troy-Bilt 21AE682L766 Big Red 10 HP...
My toro 20016 self propel is only turning the right wheel
Remove the left wheel and check the gears inside the wheel and the drive sheft. They might be worn or sheared and need renewing or maybe they just need oiling. Spray them with WD 40.
May 20, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Brake pad replacement 1996 ford thunderbird front and rear disc
1. Raise and support the vehicle
2. Remove the desired wheel
3. Loosen/remove the two caliper retaining bolts.
4. Remove the caliper from the wheel
5. Using a C-clamp, depress the caliper piston until it's completely recessed.
6. Remove the old brake pads
7. Install the new brake bads on the caliper
8. Reinstall caliper on the disc
9. Reinstall/tighten the calpier bolts
10. Put the wheel back on
11. Lower the vehicle.
*** When you are getting set let the car roll a few revolutions of the wheel to keep the pads off the disc. It will make it easier to get the caliper off.
Nov 05, 2009 | Ford Thunderbird Cars & Trucks
Audi a4 how to remove brake disc
Don't disconnect any brake line from caliper!
Don't disconnect any ABS sensor!
For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow: 1. Do not disconnect the brake hose from the caliper, and do not allow the caliper to hang by the brake hose! 2. Remove top and bottom caps (on back side of the caliper) for access to guide pins, then unbolt and remove them from the brake carrier. Remove the caliper. 3. Now you must thoroughly clean the brake calipers (free of grease). 4. Remove outer brake pad from brake carrier. 5. Pull inner brake pad out of brake caliper piston. 6. Remove brake carrier from wheel bearing housing (two ribbed bolts). 125 Nm 7. Remove brake disc from wheel hub. 8. Install brake carrier on wheel bearing housing. Tightening torque for two ribbed bolts = 125 Nm. 9. Check up the brake fluid level on the reservor, and emptying if neccessary! 10. Push piston back into brake caliper housing. 11. Install inner brake pad (with expanding spring) in brake caliper piston. (Arrow marked on pad - if exist, must point in direction of brake disc rotation when vehicle is moving forward). 12. Install outer brake pad into brake carrier. 13. Bolt brake caliper housing to brake carrier using two guide pins. Tightening torque is 25 Nm. 14. Install both caps. 15. Insert retaining spring into brake caliper housing. Important: Depress the brake pedal firmly several times while the car is stationary so that the brake pads adjust to their normal operating positions!!! Check brake fluid level and top up if neccessary!!! Please Rate my Response! Thanks!
Oct 08, 2009 | 2004 Audi A4
Cant remove wheel hub
here is procedure
Section 04-01: Suspension and Wheel Hubs, Front 1996 Taurus, Sable Workshop Manual
  1. Raise vehicle on hoist.
  1. Remove wheel and tire assembly. Refer to Section 04-04 .
  1. Remove disc brake caliper (2B120), and front disc brake rotor (1125). Refer to Section 06-03 .
Brake Shoe and Lining Removal
  1. Remove brake master cylinder filler cap (2162). Check fluid level in brake master cylinder reservoir (2K478). Remove brake fluid until brake master cylinder reservoir is half full. Discard removed fluid.
  1. Raise vehicle on hoist. Refer to Section 00-02 .
  1. Remove wheel and tire assembly from front disc brake rotor mounting face. Use care to avoid damage or interference with disc brake caliper (2B120), front disc brake rotor shield (2K004) or front wheel knuckle (3K185).
  1. Remove rear brake pin retainers (2N386). ( I think it is a T 40 torx bit you need)
  1. NOTE: It is not necessary to disconnect hydraulic connections.
    Lift disc brake caliper from front disc brake caliper anchor plate (2B292) and front disc brake rotor (1125). Do not pry directly against metal caliper piston or damage will occur.
  1. Position disc brake caliper out of the way and support with wire to avoid damaging the disc brake caliper and front brake hose (2078).
  1. Remove outer brake shoe and lining (2001) assembly from front disc brake caliper anchor plate.
  1. Remove inner brake shoe and lining assembly.
  1. Position lug bolt (1107) to clear front wheel knuckle (3K185).
  1. Remove lug bolt from wheel hub (1104).
  1. Install lug bolt into wheel hub.
  1. Using a lug nut (1012), seat wheel hub bolt into wheel hub.
  1. Install front disc brake rotor and disc brake caliper. Refer to Section 06-03 .
  1. Install wheel and tire assembly. Tighten lug nut to 115-142Nm (85-104 lb-ft).
May 25, 2009 | 1996 Mercury Sable
Front wheels not aligned
it sounds like your drag link is bent.look under the front.the rod connecting the two tires should be straight.if not,straighten it and slide a slightly larger piece of galvanized pipe over the rod to stop it from bending again
Apr 29, 2009 | Troy-Bilt Pony Garden Tiller
John Deere ?rear Lift Pipe Master Crank  Disk Tillers: 1 Logo
131 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
