Question about Canon P23-DHV Calculator
How do you get ink and apply it so that it will make a clearer print?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my understanding, the Canon P23-DH V portable printing calculator uses an ink roller inside a cartridge (P/N CP-13). As per manufacturer's instructions, "change the ink roller after 8 rolls of paper" to maintain clear printing. CP-13 ink roll set is available from:
The instruction sheet provides ink installation with illustrations.
Good luck and thank you for asking FixYa.
Posted on Nov 16, 2009
Printing lines on the photo using bulk ink
Good Day!
Please follow the instructions:
1. open a blank document (word,excel,) 2. control P 3. under printer properties hit on maintenance tab. 4. then hot on head cleaning. once done, "print check pattern" 5. please continue doing this until the print out goes clearer. 6. then, try to print. i hope this helps.
Jul 20, 2011 | Epson Stylus R290 InkJet Printer
My Epson T13 Printer Black Ink 75% is finish But Print Out only 13 so why black ink is 75% finished.
It depends on the percentage coverage you applied to the paper. Inkjets use a tremendous amount of ink and the cartridges are not very page. Also, the indicator is only their estimate of the remaining ink and not very accurate. Carry on printing until you see the print losing density, you may be surprised how much you can still print, but avoid printing pages that have a high ink coverages, these cost mega bucks.
Jan 28, 2011 | Office Equipment & Supplies
HI, I have full ink cartridges, but magenta does not print. I have done cleaning and deep cleaning. The cartridges are fully unpacked (no tape over ink heads). There are no error messages, but no...
The ink may have settled and may be somewhat dry - shake the cartridge vigorously to loosen the ink and apply denatured alcohol to the print head nozzles on the cartridge - apply a generous amount and let it soak for a few minutes.
Jan 07, 2011 | Canon MP610 Photo All-In-One Printer
My Epson R230 printer does print Light magenta and yellow ink
1. open a document. 2. control-P - shortcut for print. then click properties, click maintenance, then click head cleaning. after this print check pattern. continue doing this until your light magenta and yellow ink gets clearer. if it didn't work replace your light magenta and yellow cartridge.
Nov 18, 2010 | Epson Stylus Photo R300 InkJet Printer
Im working on a hp 26009n and the magenta isnt printing its light and the inks and cartridges were replaced. Whats the procedure to manually clean the printheads and restore the magenta
Hi! Have you tried running cleaning? Running cleaning can help resolve this. When running cleaning the ink flows massively and can result to clearer printouts. HOpe this helps and thank you for using FixYa!
Sep 01, 2010 | Office Equipment & Supplies
Poor printing / The print is hard to read. Just put in new ink
pls perform a cleaning cycle, this will greatly improve your print out to be much more clearer and readable
you could perform the cleaning cycle 2 ways 1 is by computer while your printer is turned on and 1 is by your printer itself.
always do a cleaning cycle for about 3 to 4 times....it will be indicated as head cleaning on your printer driver
Oct 15, 2009 | Epson Stylus CX3810 All-In-One InkJet...
No black and white a4
naturally on all printers there is only black . as for the other colors installed in it, they will still be consumed even though you are using black ink only or black and white prints only due to a process called color mixing which makes the output much more finer and clearer.
unfortunately it does cost you more money
Sep 11, 2009 | Office Equipment & Supplies
Printer printing balnk pages
HI i am Vortash .. chances are that the head jets have become blocked , if the printer maintance system ( ink purge and clean etc ) does not cure the problem you may try what I do periodicaly to keep my printer clean ..
  1. Get an old cartrige and make a small hole in the top ( same as you would do if you bought a universal ink kit ) then instead ok ink fill it with either Ink flush , or alchahol .. then put it in the printer and print a few test pages ..this cleans and purges all old ink and makes the printer print clearer ... hope this helps regards Vortash
Jul 21, 2009 | HP LaserJet P2015 Printer
How can I get a clearer print? Everytime I print
Beleive it or not, sometimes a new cartridge comes with the ink clogged too, put both color cartridges over a wet towel with windows cleaner by 5 minutes, then clean both with a dry towel, try to print, if the quality print stay bad, you have to suspect the printer cartridge contacts, check if are clean (if you have to clean it, do that with the printer off), if the fail continues try to use the manufacturer warranty
Jul 20, 2009 | HP PSC 1410 All-In-One InkJet Printer
After being abroad for 3 months i can home to find printer not printing correctly i replaced the 5 ink cartridges but only 2 working Black and cyan
The ink has dried in the print head. If the print head comes out, remove it and apply rubbing alcohol or water with a paper towel to the nozels to disolve the ink. Once the ink seems to be fluid, replace the print head and ink cartridges, do a head cleaning and try printing again.
If the print head cannot be removed, get a childs medicine syringe, draw in some rubbing alcohol. Remove the non printing carts and apply a couple of small drops of alcohol to each ink port on the print head. apply some more drops to the ink port of the carts and replace and try a head cleaning and print.
If this does not work, continue to ask for help. The aim is to save the print head, not buy a new printer.
May 29, 2009 | Brother DCP 115C All-In-One InkJet Printer
Canon P23-DHV Calculator Logo
151 people viewed this question
old marine
old marine
