Question about Western Digital MyBook Studio 1 TB USB Hard Drive
I have a 2TB external usb wd drive. When I hook up the drive it installed and you can see it in disk manager and my computer. After a short period of time you no longer see them in dm or mc. The only way to see them again is to turn off the drive and reboot the computer and then turn the drive back on and there they are for a short period of time.
  • rlochmann Nov 16, 2009
    It's a brand new disk drive.
    Genius:
  • 1,341 Answers
It seems you may have a hard drive that could be reaching its last moment of its life.Try to test the disk with a different pc and if the same thing happens then you probably need a new one.Remember that hard disk dies at any time and these things happen.But before you make up you mind test it with a different pc.
Posted on Nov 16, 2009
  • heeman mohun Nov 16, 2009
    It does not matter if it is brand new as these things happen with my experience..If it does the same with a different pc then go back to the seller and request an exchange.
My computer doesn't recognize my hooked in to 3.0 USB port on my ASUS laptop, initialized, SATA 2TG internal drive that's within an external case.
depends on the operating system but normally if you can see the drive in pc manager (right click mycomputer icon, select manage, select disk management in windows) if the drive is listed then format it and allow automatic drive letter assingment
Mar 20, 2014 | Western Digital WD Caviar Blue WD3200AAJS...
My Lenovo laptop won't recognize my seagate desktop 1TB external hard drive. Got any ideas?
Can you see it under "Device Manager" or "Disk Management"?
To get to device manager and disk management click "Start"-> Type in "management" in the little white bar at the bottom and click "Computer Management".
Aug 07, 2013 | Seagate FreeAgent 2TB GoFlex Desktop USB...
3tb external imation expert d300 not working with windows xp
Windows XP does not have support for any disk-drive larger than 2TB. So, your 3TB disk-drive will not work. Upgrade your computer, or buy a 2TB disk-drive.
Jan 09, 2013 | Imation Apollo Expert D300 External Hard...
Iomega 2tb drive not being detected properly on windows 7 PC or laptop.
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Aug 28, 2011 | Iomega 2TB Prestige External Hard Drive
My Fantom 1G GForce is not recognized by my computer, the drive isn't spinning and it is making a ticking sound. Help!
if your computer came with a motherboard disk the drivers could be on it
check all leads that are attached to this external hard drive make sure they are securely seated
click strart control panel administrive tools computer management device manager scroll through all of the devices if you see a yellow question exclamtion ? ! mark or a red X you will need to reinstall the driver right click on the mark select update driver if you can see the usb drive and its
not working ports(com&lpt)right click update driver
if this fails to fix the problem you might need to install a usb 2 or 3 card they can be easily installed and are very cheap
hope this helps
Aug 04, 2011 | Fantom Drives FD GForce MegaDisk 2TB ...
Hi . I have a 2TB WD (Western Digital) elements drive connected to my MacBook Pro. At first it seemed to go to sleep or unmount occasionally.-and caused programs to lock up. Now I can't get it to mount at...
Is it still under warranty?
Try connecting it to a different USB port on your computer.
Try connecting it to a USB port on a different computer.
If it still is not detected, then either exercise the warranty,
or disassemble the case, to find two major parts:
* a disk-drive
* a USB-to-disk-drive adapter
Disconnect the disk-drive and connect it as a "slave" disk-drive in some desktop computer, to see if it is recognized, i.e., if it was the USB-to-disk-drive adapter that has failed.
If it still is not recognized, then it is "dead". You could buy a similar disk-drive, install it into the enclosure, and thus create another external storage device.
Note that Western Digital's web-site has a "Customer Loyalty" program, even for out-of-warranty disk-drives, i.e., when you buy a new 2TB disk-drive from their web-site, quote the serial-number of your current W.D. product, and you get a discount on your purchase of another W.D. product.
Oct 19, 2010 | Computers & Internet
My wd elements external hd is not recognized under windows 7. The pc diagnostics say that the device is working properly and the correct drivers are installed?
Go to Administrative Tools in Control Panel. Computer Management then Storage, Disk Management. You'll probably have to recognise it and assign a drive number.
Jun 18, 2010 | Western Digital Elements powered by WD 320...
WD My Book Studio Ed. (Mac) - 2TB - stopped working for no reason
plug your drive in to your computer, right click
on my computer and bring up disk manager,
open disk manager and see if your wd drive
shows up. then reinitialize the drive and this
will hopefully solve your problem.
Aug 21, 2009 | Western Digital My Book Home Edition 500...
External USB Disk is installed but not visible under Mu Computer
Go to manage, refresh, and then asign a letter to it.
--- tuljo
Feb 23, 2009 | Western Digital External USB 2.0 80 GB...
Open Questions:
Western Digital MyBook Studio 1 TB USB Hard Drive Logo
43 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
