Question about Dishwashers
Dishwasher does not drain. the suport screws are
Dishwasher does not drain. the suport screws are out, will that cause no draining. also making a clicking noise
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 16, 2009
Dishwasher 15701
Is it a new install? If so check the drain inlet under the sink. There is a round plug in the drain ( if it's new ) where the dishwasher drain line connects to the pic pipe under your sink.( use screw driver to pop it inward don't worry it won't clog your drain )
If it's not a new install the drain pump may just be worn out. Or the butterfly valve above the pump may not be opening. Manually open this valve, using a screw driver while it's running spin the dial until it's in drain mode. You will see a solenoid that pops up and down connected to the butterfly. Use the screwdriver to push the valve lever open all the way. Usually downward. hope this helps.
Apr 08, 2014 | Kenmore Dishwashers
Maytag dishwasher won't drain
Drainage problem of some sort is usually the cause. Could be blockage before your drain pump, in your drain pump, or in your drain hose. One possibility is that you just installed a garbage disposal and forgot to remove the "knock-out" plug for the dishwasher drain line. Another cause can be that you have not looped your dishwasher drainline under your sink and water from your sink is flowing back into you dishwasher. You must attach your dishwasher drain line under your sink so it is higher then your sink drain lines, creating a trap for your dishwasher. Your drain sump could be plugged, not letting the water get to your drain pump easily. This is caused by not getting loose or hard debris off your dishes before putting them in the unit. Also make sure your drain pump is getting the right voltage when it is supposed to.God bless youfa618d8b-d0fd-412a-b0d5-a88d44bf89d3.giffb1320dc-7bec-4cb0-98ed-c24cf54e5e3b.jpg
Apr 02, 2013 | Dishwashers
It seems like the dishwasher didn't drain and water pours out onto the floor.
might be helpful if you provide the make and model number of the dishwasher.
It is possible either the drain hose has bursted or the kitchen drain is blocked causing the drain water to backflow. Do you hear the drain pump operate?
Jan 06, 2011 | Dishwashers
Dishwasher won't drain properly
Common cause of this issue is a partially blocked drain line. Disconnect the drain line and make sure the entire path is clear, including where it hooks into the sink drain or garbage disposal. Also make sure the screens at the bottom of the dishwasher are free of debris.
Jun 09, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Water is draining instead of going to spray arm. what should i check next or how do i fix this problem?
I would check to see if the dishwasher is syphoning the water out. This is caused by an improperly installed drain hose. Check to make sure that the drain hose goes about the level of the main drain. Sometimes dishwasher are installed with teh drain hose going into a crawl space, or into a drain below the dishwasher.
Apr 06, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Water is not draining after wash. What might be the cause?
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit ( there are others, this is just an example )
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock-out plug at connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Apr 01, 2010 | Jenn-Air 24 in. DW861 Built-in Dishwasher
How can I do to repair lost water in the door?, When the machine wash the dihes, it lost water between the front door
dishwasher is not draining quick enough.. inside the dishwasher on the bottom is a plastic screen that has 2 screws...remove the 2 screws....clean out inside there....usually theres broken glass, food and other debris....if that doesnt work..look under the kitchen sink follow the dishwasher drain line to the sink drain and make sure all lines are not clogged
Dec 25, 2009 | Dishwashers
GE profile dishwasher won't drain
Common cause of this problem is a partially blocked drain line. Disconnect drain line and make sure entire path is clear, including where it connects to the sink drain or garbage disposal. Also, make sure all screens and the drain area at the bottom of the dishwasher are completely clear.
Sep 21, 2009 | GE 24 in. Profile PDW7800 Built-in...
THE DISHWASHER DOES NOT DRAIN. THE PIPES ARE OK . EVERYTHING LOOKS FINE .
Check the following:
Debris that may be interfering with the drain in the bottom of the dishwasher - especially if the unit has a soft disposal. You may have to remove the lower wash arm and housing cover.
Check the drain line and be sure it's clear to the sink drain spur and that there are no kinks or other obstructions
Check the check valve on the discharge from the dishwasher - even small obstructions can cause this valve to plug or jam -this usually requires removal of the front lower panel - look for the drain line connection to the dishwasher - the check valve is usually screwed into a housing. Be careful un-screwing it. You may need a shallow pan to drain water into when you remove the drain line and check valve if there is still water in the dishwasher
It also could be the pump, but check all of the above first.
Finally, it could be the circuit board, but you didn't indicate there were any other problems with the dishwasher other than the drain
May 03, 2009 | Dishwashers
Wont drain
Pull out the bottom rack and make sure strainer is clear. If the outer strainer is clear remove the few screws around it to get to the other strainer to make sure it is also clear.
Dec 31, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
99 people viewed this question
Top Dishwashers Experts
