How do i replace the belt
The drive belt broke i would like to know how do i replace the belt .
  • 491 Answers
FIRST MAKE SURE THE POWER IS OFF THEN REMOVE ALL THE SKREWS IN THE PANEL AND REMOVE IT , LOCATE THE DRIVE BELT TENSOINER AND LOOSEN REMOVE THE BELT AND TAKE IT TO A PLUMMERS SUPLY STORE FOR REPLACEMENT WHEN FITTING THE NEW BELT MAKE SURE THE TENSION IS TIGHT BUT GIVES A LITTLE .
Posted on Nov 16, 2009
The drive belt on my Honda HRT broke. I replaced it and within a few seconds the new belt broke. I know the blades are turning, but I'm wondering if the wheel on the transmission is not turning thus the...
could be rear end is locked up you will have to get another belt try turning wheels by hand if loose see if there are broken bearings anywhere on the drive usally thats the case with the belt bearing goes out and shreds thr belt try those ideals
Jul 30, 2013 | Garden
Replace drive belt 98 lumina w/o fixing a/c compressor?
Yes as long as the a/c pulley spins freely. You should be able to spin all pulleys by hand, except for crank pulley
Apr 03, 2013 | 1997 Chevrolet Lumina
I need a timing belt diagram for a 1995 dodge caravan 3.3
The 3.3 L Caravan engine does not use a timing belt.. It is timing chain set up. What belt are you talking about that broke?? The serpentine belt that drives all the accessories??
Jan 30, 2013 | 1995 Dodge Caravan
Johndeere gx75 drive belt diagram
I broke a drive belt on my gx75 and need to know proper routing and installation for new one AmanStino Ultra Slim Lightweight Smart shell Stand Cover with Auto Wake...
Jun 15, 2012 | Cars & Trucks
My Volvo S40 timing belt broke when replced with a new one
its either not been fitted correctly ( im not saying you dont know what your doing ) or a faulty belt ( unlikely ) check every pulley and make sure they spin freely ( except crank and cam obviously ) if 1 of the pulleys is jammed. theres your problem
Dec 10, 2011 | Cars & Trucks
I was driving my 1991 honda accord an timing belt broke iam woorried that it might have damaged engine what should i look for i was going to replace belt an try to get back running any advice thanks
Honda engines are what they call interference engines. This means when a timing belt breaks, the pistons hit the valves and bend them. You will need to remove the cylinder head and get the bent valves replaced if you want it to run correctly. Impossible to know how many valves are bent, depends on how fast the engine was turning when the belt broke.
Aug 19, 2011 | 1992 Honda Accord
My belt broke and now my car wont start why not?
Ok. If your car was running and then the belt broke and you continued to drive it. The case may be that you drained the battery because the alternator runs on the belt and the alternator keeps battery charged and if belt broke and you continued to drive then you may need to jump start vehicle. I guess I shouldve asked earlier but have you replaced belt yet?
Jan 30, 2011 | 1995 Mercury Cougar
Driving and the timing belt broke can i just replace the belt? 2003 chrysler 300m
If the timing belt broke, than you heard a big banging noise from your engine and that is it, your valves met with pistons and they are more than likely to be bend, unfortunately this situation calls for engine recondition. But are you sure the belt broke as some of these 300M's were on a chain drive.
Dec 15, 2010 | 2003 Chrysler 300M
Yard Machine posessed by devil
there are to belts the lower belt drives the blades ,the belt above it drives the mower that's mabey where your problem is.
May 23, 2009 | Garden
Washing Machines Logo
295 people viewed this question
Top Washing Machines Experts
