Question about GE Profile Spectra JGBP90 Gas Kitchen Range
MY BOTTOM HEAT ELIMENT DOSNT WORK - GE Profile Spectra JGBP90 Gas Kitchen Range
  • 11,896 Answers
You can check with a voltmeter and test the power to the element to make sure it is getting power. If not, then you may have a bad relay or wire or circuit. Testing with ohmmeter you can test circuit and relay.
If there is power to the element, then element is likely faulty. You can get parts, manual, and more at repairclinic.com or partselect.com
Posted on Nov 16, 2009
Inside fan is working but heat exchanger ices up and fan freezes and unit won't cool.
This means the heating eliments are not coming on. Usually in this case I change out the heating timer, eliments, and thermostat. All as a set.
Aug 29, 2015 | Haier HRT02WNC 1.7 cu ft Compact Counter...
Questions regarding an outside mirror
Heated mirrors have a swtch in the car. That operates the eliment that is stuck to the glass.This eliment heats the mirror when turned on.It is used to defrost or demist the mirror.A none heated mirror has no wires going to it and no eliment at the back off the glass.OK.
Aug 01, 2009 | 2004 Nissan Maxima
Electric dryer model LER6611PQ0 will not heat up - only 4 years old
Could be a fuse..
Could be a heating eliment..
A way to check the eliment is -- remove the exuast hose.. Put a mirror to see inside the hole.. Whenrunning the eliment should glow hot..
Hope this helps !!
rate me good ;o)
Jul 14, 2009 | Dryers
Wirlpool dryer heating eliment keeps braking
Sounds like you use dryer sheets. If you do, try cleaning your lint screen with vinegar. Dryer sheets leave a film on the screen that the dryer eventually can't breathe through, the dryer overheats and burns up the elements.
May 26, 2009 | Whirlpool LER5636P Electric Dryer
How do you know if it is the element that is bad or the therm-o-
Disconnect the electric for the unit. Disconnect the two wires from the two eliments. Place a battery type test light or Ohm meter is more conclusive if you have one, Light should light when placing the two test leads to the two eliment contacts(while they are disconnect for the water heater wiring) should be dim but glowing. If no light the the eliment is open. If an Ohm meter the Wattage is written on the heater the heater. E=IR P=IE. It should work out to about 1200 -1400 ohms if 220 volt heater. If the light is bright just as if you had put the two test leads together,then you can say that the eliment is likely shorted. Either no light or a Very bright light requires the eliment to be changed.   To check the thermostats, Raise the ajustment one one at a time, until it clicks. Listen for the heater to be heating. Turn that one back down and do the other one the same way. I hope I have been clear enough. About one gallon of water should be drained for the bottom of the tank once a year along with checking the preasure/tempature safety relief valve by  operating it ,using the leaver,for  a few moments as preventive maintenance.
Feb 11, 2009 | Element Chromalox SG1353-430326 Electric...
Intertherm furnace mac2460 heating eliment continues to heat
Sounds like a bad blower relay,intertherm will sometimes use a control board
Jan 15, 2009 | Heating & Cooling
Kenmore elite he3 dryer
take the bottom panel off the washer it is held in by two or three screws the heating element is off to the right
Dec 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
103 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
