Question about Sony Ericsson Cyber-shot C905 Cell Phone
I have just downloaded bloover2 on to my phone. it has installed cause i can view it, however when in the menu i cannot choose anything. it gives me the option but pressing the button on my phone dont do nothing! i cant work it out? it says its saved on in my application on memory card and it loads like a real game. please help
How do I download a new android version to my phone
Hi Angelo
Checking for Android updates
  1. Power up the phone and press "Menu" to unlock it
  2. Push the "Home" key
  3. Push the "Menu" button.
  4. Touch the screen or use the navigator wheel to select the "Settings" option.
  5. Within the "Settings" menu, select the "About phone" option that is found towards the bottom of the list. This option displays the version number and build number of Android that is running on the phone.
  6. Touch the "System updates" option. This causes the phone to look for any new Android updates. If an update is available, the phone will download and install it.
Creating a shortcut
  1. There is an application available called AnyCut that can help simplify the update process by creating a shortcut to "Device info."
  2. Install AnyCut by going to Android Market, and then touch "Search" and type in "AnyCut."
  3. Create a shortcut on the phone's desktop.
  4. Choose "AnyCut" from the list and choose "Device Info" as the "Activity."
  5. Scroll to the end of the list and press "Check for updates."
  6. Once the process has completed, exit to the home screen where you will be prompted to install the update.
Apr 04, 2016 | Android Cell Phones
Install youtube
In order to install Youtube to your phone you will need to access the market from your apps menu.Click on the market and then type in Youtube in the search line provided.The YouTube application will show up and then you click on it to download it.Once it is downloaded you will be asked if you will give permission to install it.Give the permission to it and it will automatically install to your phone.Once it is done it will prompt you to open the application.You will be able to find the Youtube application in your apps menu.
Thank you for choosing Fixya!!
Jul 02, 2012 | LG GD510 Cell Phone
Pantech cellular, Where I found the manual for this phone?
Go to http://www.pantechusa.com/support/ and use the drop-down menu to select your particular Pantech model. You'll see the manual as a .PDF download. You can view the manual on your web browser, or you can also choose to install it onto your PC.
Mar 17, 2011 | AT&T Cell Phones
I need an instruction manual for a binatone symphony 2200 telephone
I fund one here. You can view it or print it out if you wish. Make sure you have adobe reader installed.
On the website that opens. click on the download link, answer a few questions or input numbers if you choose and you will be taken to the download menu. If you have any problem, give me your e-mail and I'll send it to you.
Oct 30, 2010 | Cell Phones
How do you set the alarm clock on a motorola clutch i465?
There's an option in "Download Apps" from the "Java Apps" Menu called "Factory Preloads." Choose that option instead of the "New Purchases" option that you usually choose when installing other/new apps and it will give you a list of the default apps the phone came with. Alarm Clock Plus will be in the list.
You'll have the ability to re-download any of them, Alarm Clock Plus included. Make sure to uninstall the existing installation of Alarm Clock Plus first before doing so.
Mar 29, 2010 | Motorola Mobility Clutch i465 Cell Phone
I am trying to download pictures off my camera card to the computer, I have the card in the computer but can't seem to find anything that will let me download. Please help Ann
Remove card.
Place card back in reader. Screen should come up with menu for you too choose which means you wish to view contents.
Click my computer/and if card is registering/it will be listed with your other drives.
Double click, this hould then open card to view contents, it will also show you which programme you have installed to view your pics. If no pics means you have not setup poota to view your camera pics.
You need to install a viewer prog.
Nov 15, 2009 | Computers & Internet
How do i put music on my i776 phone from the computer
Plug the USB cord into both, once the computer recognizes it it should ask you what you want to do, choose the option the says something like view, download the music to the computer, then highlight it, right click it, then it should give you a drop down menu and it should have the option to "send to" and you'll wanna send it to E
Oct 29, 2009 | Motorola Mobility i776 Cell Phone
I need to download bloover2.jar to my cell phone
Can you please help I would like to transfer to my Cell phone Palm Centro?
Apr 18, 2009 | Computers & Internet
How to install a themes or skin for motorola RAZR v3x???
IF YOU WANT TO INSTALL SKINS/THEMES on your phone. Get Skin Manager v.0.51..
you need skin manager v0.51 also the driver for motorola. downloads themes then extract it. open skin manager wait until it reads your fone then choose menu files,
if downloads button is clickable
HERE IS SOME GUIDE
click it choose the extracted skin just click the file you will see specially the .SKI
then go to SKIN on upper left corner
look for install dont check anything
look for the file on your skin extracted file then install it.
wallahhhh installed
after it click "more" button on lower right then click restart phone
make sure the skin is compatible to your UNIT or model of fone. good luck...
Feb 20, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Please help me
download P2K tools software which is compatible for all motorola phones... it is having in built drivers also so install the driver by giving the location where the p2k tools is located in that select folder "drv" ... this folder have all drivers when u connect ur cell to pc through cable just install this... then u can upload or download anything from pc to cell & vice versa & you can flash the cell by using the flex option....
you flash the cell even when it is turned off from this software ..
it is available in some of these websites
p2ktools-mod.en.softonic.com/java/download
www.e398mod.com/content/view/165/28/
gsmhosting.com/vbb/archive/index.php/t-41842.html
forums.mobiledia.com/topic48216-0-asc-10.html
rate my solution
Dec 22, 2006 | Motorola Mobility C650
Sony Ericsson Cyber-shot C905 Cell Phone Logo
161 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
