Electrical buzzing sound in a/c, furnace
What is the electrical buzzing sound coming from my Lenox furnace? Does it mean anything?
  • raven1950 Nov 17, 2009
    It's a relay causing the buzzing sound? Is this a dangerous situation?
    I just bought this house in July and it's only eight years old. I noticed the sound when the a/c was on and now again with the furnace.
    Thank you!
  • intisarkhan2
    intisarkhan2 May 11, 2010
    Relay sound must replace.
  • 43,501 Answers
What you hear is the trnasformer that cuts the voltage from 120 to 24v for the thermostat and the furnace control system. Dpending on the frequency of the house current somedays it may hum louder than other days. This is nothing to be concerned about but can get annoying sometimes if your furnace is where you can hear it easily. I have not found and quick cure for it so unfortunately you will have to just deal with it.
Posted on Nov 16, 2009
Testimonial: "Thank you so much! I just bought this 8 yr old house in July so everything here is new to me. I can live with noise that isn't dangerous."
  • 22 Answers
If this noise is comming from your control transformer or possibly a control relay you may be able to isolate it from the metal housing it is secured to with a rubber mount. Some times the noise resonates and is amplified by the screws or bolts used to secure it in place. If it is a contactor makeing the noise it may be losing its magnetic capability due to rust on its solinoid iron core.
Posted on Nov 24, 2009
Testimonial: "Thank you very much. This house came with a one year homeowners warranty so it may be well to get this checked out while it's still covered."
My American Standard Furnace light blinks 3 times stops and blinks 3 times again and so on.
Look inside of service panel for trouble shooting codes and solutions
Feb 13, 2016 | Heating & Cooling
I have a LENOX furnace and the fan comes on and furnace will lite then go out
Lenox furnace are a bear to work on if all the world isn't right that day. The sensor is not proofing to the control module.
Nov 13, 2015 | Honeywell Furnace Gas Valve Sv9501h2409
Heat Pump makes a surging/buzzing sound every 20 seconds
You might have a short going to your reversing valve. Check the temperature of all three lines out of the valve. The one on the left should be cold and the one on the left should be warm hot. . Check voltage to the valve.if it fluctuates that might be the reason for the buzz.
Mar 04, 2015 | Heating & Cooling
Furnace is blowing cold air.
You must have an electric furnace, gas furnaces only come on when the heater is warm. Electric heaters come on with the use of a sequencer. Your sequencer, tstat, and blower is fine, which means you must have broken heating element. I have a nice pictoral of how to restring one HERE
Feb 21, 2011 | Carrier Heating & Cooling
I have a Lenox furnace. Before this igniter kicks off, there is a loud noise comes from furnace. Where is that noise from? Thanks.
This is what we call a "delayed ignition",(gas is not being ignited right away), gas builds up in the chamber and then lights causing a boom. The cause of this problem could be from having dirty burners or ignitor not position to ignite the gas right away or your ignitor may not being glowing enough to ignite the gas being released, check all, Good luck.
Jan 08, 2010 | Goodman GMS90703BXA Heater
How do I clean a flame sensor on a 1993 Lennox Whisper Heat furnace. It heats,then the gas valve clicks and the flame briefly stops and starts again then the valve clicks again and the flame briefly stops...
You can sand the flame sensor but it sounds like another problem. Sounds like a limit switch or something in the control circuit, You need to have a service tech look at this. Ask for free estimate on repair. I have worked on hundreds of these units and they are sometimes tricky to work on. Lenox has come up with new controls for the whisper heat furnace to replace the old ones. If the flame sensor is bad the unit will try to light a few times and lock out and you ahve to kull power to the furnace to reset. If this is whats happening clean the sensor nd you should be ok If not you need help from a service tech.Rus
Nov 11, 2009 | Heating & Cooling
Lenox Gas Furance Summer Fan Not Working
Just curious, there sometimes is a safety switch on the door to the fan unit so no one gets hurt opening it to change filters ...etc... make sure all the doors are on tightly
Jul 30, 2009 | Dryers
Water is continually flowing out of my Lenox G26 series furnace
You mean the main plumbing supply to the house? NO WAY! Something is terribly wrong somewhere but not in your unit.
Apr 08, 2009 | Heating & Cooling
Heating & Cooling Logo
1,374 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
