Question about Nintendo Wii Console
It starts running in the middle of the night. Also, does not rceognize the remote control now.
    Problem Solver:
  • 5 Answers
Does the blue light just turn on where the disk goes in? That just means it's connected to the internet.
For the WiiMote, open the little door under the power button on the Wii and press the red button. Then take the cap off the wiimote, the on covering the battery and press that red button too :)
Posted on Nov 16, 2009
My remote is starting my engine all by itself. I'm afraid it is starting in the middle of the night. And run out of gas
I would bring it to where or who installed it to find out why its doing that. The installer will know better on what they did.
Jul 06, 2017 | Cars & Trucks
Alarm goes off middle of night for no reason. viper model 5704V
u seem to hav a computer/module system issue--get a data stream run that shows values so a good tech can decyfer-need factory gear not a 20dollar scanner--stay away from dealers-------1st tho try anothr remote or changn batts--or even disconnect car batt fora minute
Nov 07, 2013 | Cars & Trucks
Opening car with key sets off alarm.
Open up your key and dry it first of all.
Then retry.
Or you could try using your spare set of keys.
Nov 13, 2012 | 2006 Kia Sportage
TV turns on in the middle of the night
  1. If the TV has a timer option, ensure it is disabled.
  2. Check the remote control to see if any of the buttons are stuck that may be interfering with the TV.
  3. Unplug the power cord of the TV from the AC wall outlet for 60 seconds.
  4. Plug the power cord back into the AC outlet.
  5. Attempt to turn on the TV.
  6. Remove all remote controls from the room where the TV is located.
OR
unplug all HDMI sources to see if a device is sending signals in the middle of the night
Oct 03, 2012 | Toymax Magnavox 37MF231D 37 in. LCD TV
My Hunter remote controlled fan worked great for the first few years, but now the the light comes on and the fan turns off at the same time without me touching the remote or the switch on the wall. Wakes...
Sorry to read about your problem, I hope this helps you out.
you may have a defective remote reciver or even a bad remote.
Take the battery's out of the remote for a couple of days, if the fan turns on, the remote is good.
you can have the remote receiver replaced, they run around $60.00
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Hunter 52" Ceiling Fan With Light And...
We had an electrician install a Hunter ceiling fan in our daughter's bedroom along with a Hunter remote control. The light will randomly turn on in the middle of the night. It seems to occur only when...
Before I did anything else I would try changing the code on the problem fan. Change the dip switches in the fan and in the remote controller unit to a different code. It is not impossible that a neighbor has the same code in their unit or a device in the area is operating off the same code. Probably the cheapest thing to try next.
Sep 06, 2010 | Hunter Dryers
One night the fan turned off as we slept and last night, it's lights came on in the middle of the night.
The electronic control unit in the fan might be going/has gone bad. Depending on the amount of money a new one might be, it may be adviseable on getting a new fan.
Aug 12, 2010 | Hunter 52" Ceiling Fan With Light And...
I think our house is haunted. Just installed
See my post below: (Sorry, we're in the same boat!) Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code/channel on the remote due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!!
- P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Mar 20, 2010 | Hunter 52" Ceiling Fan With Light And...
2007 silverado keyless entry will start randomly
sounds like they had the timer controlled start activated on this unit. If you had them install it at bestbuy bring it back to them and tell them it starts randomly and its a easy fix for them
Mar 01, 2009 | Car APS921 Remote Starter - Keyless Entry
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
