Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
The Line( command on my Calculator does not erase
The Line( command on my TI-84+SE calculator does not erase even though I have the synrtax correct.
  • ironwizard Nov 17, 2009
    I am using that exact syntax, but my calculator draws the line it was supposed to erase instead. Is my calculator just glitching? Or is there some hidden setting I need to change to allow the line( command to erase a line correctly?
  • Texas Instru... Master
  • 8,046 Answers
If your calculator is drawing lines in response to the Line( command, there is no objective reason why it would fail to obey the same command with a different argument.
To make sure we are talking about the same thing, let me restate the correct syntax for both usages.
Line(X1,Y1,X5,Y5) draws a line joining the points A(X1,Y1) to point E(X5,Y5).
With the foregoing line already drawn, running the command
Line(X3,Y3,X4,Y4,0) will erase the segment of the already drawn line that lies between the points C(X3,Y3) and D(X4,Y4)
  1. To be sure to obtain the intended effect, draw your graph and press [2nd][QUIT] to go to the main calculator screen.
  2. Then you press [2nd][CATALOG] L to jump to the first command that starts with L.
  3. Find the Line( command and press [ENTER].
  4. The command echoes on main screen.
  5. Complete the command by supplying the coordinates of the points, the 5th argument 0 if needed for erasure, and press [ENTER].
  6. The graph is redrawn with the relevant segment missing.
In this exemple it is understood that the points C and D belong to the line drawn. The erasing is effected by the additional argument with value 0. If the points are not on the line, the segment erased may be shorter and may even be of length 0 (no erasure).
If the command still misbehaves, you may have to use the [2nd][DRAW][1:ClrDraw] to clear the drawing and start again.
I trust you will forgive me for all this information that you already know, but I am thinking about other visitors who might not know how to use the command correctly.
Hope it helps.
Posted on Nov 16, 2009
  • k24674 Nov 18, 2009
    I do not know what to tell you. You say you are using the right syntax. There is no hidden configuration setting.
    Erase all graphs with [2nd][DRAW][1:ClrDraw] and try
    Line(0,0,3,6,0) and you will see that it draws nothing: The graph remains blank (except for the axes). yhat is what mine does.
    Remove the last zero from the command line and it will draw a segment between (0,0) and (3,6)
    If you still have problems, you may want to reset the calculator by
    [2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER][ENTER]
    If all else fails, contact TI by email at ti-cares@ti.com
SOURCE: how to restore applications on TI-84 Plus Calculator
Go onto www.education.ti.com, find the downloads column, and click on apps and operating systems. Then you can click on the different lists and find out which apps you accidentally deleted. You do this by (after clicking on it) looking under the "Pre-Loaded On" column. If you find the name of your calculator there, this is one application that was deleted. Hope this helps!
Posted on Aug 05, 2008
SOURCE: None of the buttons on my TI-84 Plus calculator are working.
The normal typing cursor
Posted on Sep 28, 2008
SOURCE: TI 84 Change brightness command
Couldnt you just do 2nd up or down multiple times
Posted on Oct 25, 2008
  • 49 Answers
SOURCE: My TI 84 will not turn on. All batteries have been
try adjusting the contrast up using 2nd + up
just keep pressing it and it should turn back
Posted on Jul 28, 2009
  • 88 Answers
SOURCE: TI-84 calculator root problem
Press 4 then press math. Select #5. You'll be back at the home screen now type 90 and press enter. You can use this for any root.
Posted on Aug 06, 2009
TI-84 Silver Edition blank screen with cursor in top left hand corner blinking. Keys not responding
The command line is full. Use the left arrow key to clear the command line. Then erase all previous entries, or reset the RAM
Sep 07, 2014 | Texas Instruments TI-84 Plus Silver...
List 1 and list 2
If you are truly talking about the the TI89 calculator there is no command to set Diagnostics ON. This is a command for the TI 83/84 Plus. In the TI 89, the correlation coefficient is displayed by default in the statistical result screen.
In the Ti83/84 open the catalog: Press [2nd][0] (CATALOG).
Press D, then scroll from there until the line DiagnosticOn. Select the line and press ENTER.
Dec 09, 2013 | Texas Instruments TI-89 Calculator
Complex number
Try entering on the same command line your calculation followed by the ToFrac command. That should work. Here is a screen capture from a TI83Plus in complex mode (a+ib).
Aug 26, 2013 | Texas Instruments TI-84 Plus Calculator
Binompdf ( says n:......p:.....x:..... How can I enable this guided input on my TI-84?
In the older versions of the OS, the command binompdf( displays a command line where the user is expected to enter the arguments respecting the syntax of the command. In the more recent versions of the OS (the most recent is 2.55 MP) the user enters the input over three lines.
I suggest you upgrade the OS of your calculator to the latest version available on the education.ti.com website.
To upgrade, insert fresh AA batteries (or just good batteries), run TI connect on your computer, connect the calculator to the computer and click the update button on TI connect main screen. It will download and update the OS.
Jun 25, 2012 | Texas Instruments TI-84 Plus Calculator
Is it possible to change the faceplate of the TI-84 Plus calculator?
Yes, you can change the faceplate of the TI 84PLUS Silver Edition only, not the TI 84 Plus. Face plates are available for purchase at the TI online store.When you go the online store, select the country, then the calculator model. You will find them under accessories for the TI 84 Plus SE.
Aug 15, 2011 | Texas Instruments TI-84 Plus Silver...
What is ERR:SYNTAX on ti-84 plus calculator
If you want to correct the error you will have to disclose what you were trying to calculate.
Anyway, each command has to be written in a specific way ( a specific sequence of symbols) to be understood by the calculator.
Foe example, if the command is sin(X) you cannot write it as sin() X or X sin. You must respect the way a command is to be entered, otherwise you get rubbish or a SYNTAX ERROR message.
Usually the calculator will ask you GO TO or QUIT. If you choose GO TO the cursor will jump to the place where the error occurred and you may be able to correct the syntax.
Apr 14, 2011 | Texas Instruments TI-84 Plus Calculator
How do I enter 5 and 1/8 into the calculator?
Just as your wrote it: 5 + 1 / 8
The TI-84 doesn't really work with fractions, though there are commands to convert between decimal and fractional representation.
Aug 30, 2010 | Texas Instruments TI-84 Plus Calculator
How do i do a fraction on a TI-83 plus calculator
  1. Enter a numerator, the division sign /, then the denominator.
  2. Instead of pressing the [ENTER] key, press [MATH] and [1:|=>Frac]
  3. The command line displays the fraction you entered, followed by the [|=>Frac] command.
  4. Press [ENTER] to display a reduced (equivalent) fraction.
  5. If you keep using the sequence [1:|=>Frac][ENTER] with all your fractions you can keep getting fraction results.
The OS of the calculators Ti84PLUS and TI84Plus SE has been upgraded recently to the 2.53MP (math Print) version, which provides some significant improvement to the handling of Fractions, Logarithms, etc. Unfortunately for you, the upgrade is not compatible with the TI83PLUS
May 10, 2010 | Texas Instruments TI-84 Plus Calculator
My TI-84 Plus calculator won't work. It won't switch off by itself. When the batteries are reinserted, it says that all RAM has been cleared. When i press the 'ON' button again, the screen clears. but...
The Ram cleared message is normal after you change batteries. When you see this message you press the CLEAR button to erase it. You do not press the ON button again because the calculator is already ON. If you want to turn calculator OFF you press [2nd][ON] (OFF).
On certain calculators, pressing the ON button when calculator is already ON is interpreted as INTERRUPT the current command.
Jan 04, 2010 | Texas Instruments TI-84 Plus Calculator
How do I clear the table on a t-i 84?
To clear the memory of your calculator
Press [2nd][+] to acces the memory management screen, scroll down to 4:or just press 4 then ENTER.
The Home screen appears, displaying your command.
Press ENTER, the calculator responds with Done. And you are done.
On the same screen where you find ClrAllLists, you can also execute the Clear Entries command, and it will erase all the things that you entered through the keyboard.
Hope it helps
Apr 09, 2009 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
109 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
